Yes, as I understand, the major delay per cycle is the "Goto Main".
It's not my suggestion that proves you wrong, it's you timing it
Then if you work out how long the Goto takes to execute, you can
subtract that from the 5 value in your PAUSE 5 command, and you're
fine until you put anything between the start of your program and the
end of main, or also if you use a beefy command like sound, or serin/out
etc., as they put code in the front of your program for the same reasons
(they want to execute fast also).
