Hi Henrik,
Thank you for pointing out my stupid mistake. I knew it must be something I overlooked.
In my defense I have to say that after copying the code from 683 I made the necessary changes on the top of the code to apply it to 819. In the process I removed the TRISIO line from the old code and look up the corresponding line for 819. I got distracted (which is quite easy at my age) and did not finish it. My mind was set that I did it so I was looking for something else.
I will add extra configs and test it again after work tonight.
To answer your question why I’m using an external oscillator: I would like to experiment with higher frequencies and I have plenty of 819 (some of them on PCBs ready to use as prototyping boards).
I will order some more oscillators (or try to locate the ones I have somewhere in my garage) for all PBP supported frequencies and have a wide range of available frequencies in the range of 250KHz to 5MHz. Also I could not find any PIC supported by my setup that will do more than 8MHz on internal oscillator.
After Art’s post I realized that my signal generator outputs only signals lower than 2MHz so I have to compensate for the difference.
I’m doing the same thing with the 683 (recycling old rev boards) but the 683 version is extremely small (less than 1² inch) and they do not have the padding for the oscillator.
For the working project I’m still using the low part count concept.
Nick
