Maximum frequency output from a PIC
Results 1 to 40 of 69
    Oct 2012
    Default Re: Maximum frequency output from a PIC
    Hi Art,
    Thank you for your input.
    Please do not take my reply the wrong way and try to understand my points that follow.
    The exercise was to keep the design to a minimum component count, explore unknown features of the PIC processors (unknown to me at the time), be able to modulate a high frequency carrier with the same PIC 10F or 12F family and finally have the most flexibility over the output frequency and duty cycle output. You can not bit the accuracy of the internal clock of the newer PICs if you are trying to use any RC timing circuits and employing any kind of external crystal oscillator defeats the purpose of the exercise.
    As Henrik pointed it to me I love having the opportunity to use “the hammer” when it comes to replacing older ways of doing things. I grew up with doing things the hard way and I am convinced now that employing different caliber PICs the job is much easier.
    Just to give you a stupid example: try designing an oscillator with a flexible frequency and duty cycle in a wide range using discrete components and you will find yourself in a deep trouble especially when one of the parameters changes.
    Use the results of this thread exercise and you will find that all it takes to change one parameter is one or two lines of code. You can use the same hardware over and over for one or multiple projects and all it takes is code changes.
    I’m old. My eyes are failing me and even though I can still replace a 100 pin SMD chip with 0.5 mm pitch (that means remove the old chip and install the new one) in less than 3 minutes with 100% success (my personal record about 15 years ago was 87 seconds) I do want to keep using this skill to a minimum.
    So to answer your question:
    The external clock divided by 4 gives only 50 / 50 duty cycle and only one output frequency for any given main clock. Second part of your question goes in the territory that I’m trying to escape from and gives very little flexibility when changing any parameter because it has to be done in the hardware.
    I’m not being lazy I’m just trying to be more efficient when it comes to using my time especially when the clock is ticking for me on the down side.
    Thanks for your suggestions and keep up the good work. I’ve been following your posts in this forum and I commend you for your great contributions.
    Nick
    Aug 2003
    Hi Nick,
    Great post, and objective I've never tried to get out of using an Xtal before,
    so hadn't previously considered some of the difficulties coming up with your own timing.
    I know what you mean, playing with a phone that almost does everything doesn't motivate
    me to build my own computers,
    I do have to come back very soon for a project... kind of have to because I want the thing I'm making
    If it is just a perfectly linear program that can boss the chip out of running any other program,
    such as for a power supply or something... I think as things warm up you lose timing of the internal clock,
    same as if there was voltage fluctuation.
    but for the exercise... with the new rules as I understand them,
    I would try a program that can interrupt itself with an output pin
    connected to the portB interrupt pin. Then you could introduce a linear delay at the interrupt
    vector, and control the delay before turning the interrupt back on.
    I don't know if the jump to the interrupt vector is essentially a GOTO or not.
    It jumps to vector 4, which would not be as fast as resetting the program counter to zero vector.
    and potentially some inaccuracy caused if there's any variation in the response time to the interrupt.
    Cheers, B.
    Oct 2012
    Hi Art,
    I agree with you on your points. One must be careful when simplifying things, like we’ve been doing in this thread, depending on the application.
    For my application 10% accuracy on frequency and duty cycle will be fine. The beauty of what we did here is that instead of doing it the old fashion way, trying to match RC values for target frequency and duty cycle, we used the built in oscillator (which in my opinion is more precise and reliable than RC setup even when using 1% components) and use the code to make any changes. In the process the component count, board space and I’m sure cost went down. I didn’t dream when I started this that (excluding PSU section) with only two PICs, a couple of resistors and capacitors and one Mosfet I can wirelessly transfer power with good efficiency and have the grounds ready for data transfer.
    As for your suggestion at the end of your post you used the magic word (again I’m talking for myself only) INTERRUPTS.
    Yes, they are next on my list and I will start researching how to use them. As soon as I have a clearer image of interrupts I will try to see if they will do any better on my Rx module. I have the feeling that they will eliminate some if not all the jitter but not the delay.
    Nick
    Aug 2003
    If you are still going on it, you probably know not to bother looking at BASIC interrupt in this case.
    Usually there is time taken saving and restoring context, but that could likely be avoided
    if the program is under 2K, and doesn't care where it was up to when the interrupt was called.
    I will be writing for a 16F877 soon, and would see how fast I could just cycle a pin,
    but don't have anything to measure it with.
    Oct 2012
    As the wise man once said “necessity is the mother of invention”.
    I’m sure that it will take you no time to build a “tool” to solve your problem. What about employing one more PIC to do the job for you? Set it up to count incoming pulses from your DUT for a set period of time and send the results to a LCD or to your preferred PC communication terminal for a visual. You just built yourself a home made, dirty cheap frequency counter ready to solve your problem now and help you in the future.
    Just a thought.
    Some experimenting and results in that matter were done in the beginning of this thread but unless you are starting with a really high clock flexibility is not that great. I’m not sure if the Assembly approach will bring any more advantage but, again it is out of my league.
    Nick
    Aug 2003
    Looks like I'll have to.
    I always thought if I have a 5 Volt square wave,
    that my multimeter would measure it as 2.5 Volts.
    I never considered the sampling frequency of the multimeter has
    no connection with the frequency of the signal being measured.
    Oct 2012
    Hi again,
    I’m trying to move what I learned last week to a larger PIC (PIC16F819) which I have a lot of leftovers and I’m trying to make use of. I’m also trying to increase my output frequency by using a 16MHz oscillator.
    Based on what the data sheet shows I should have about the same setup as I had with PIC12F683 except that I could select between RB2 and RB3 as my output.
    With the above code I get good output on RB1 (led out which proves that the system is running) but I do not get any output on RB2 or RB3. I was hoping that it will go by default on one of them.
    @	device  pic16F819, wdt_off, hs_osc, pwrt_on, mclr_off, lvp_off, protect_on
    DEFINE OSC 16         ' We're running at 16 Mhz
    ADCON1=%01001110            ' Digital only for all pins
    led     var         PORTB.1
    i       var         byte
    CCP1CON = %00001100     ' Normal PWM
    PR2 = 3
    CCPR1L =0
    CCP1CON.5 = 1
    CCP1CON.4 =1
    For i = 0 to 9
        Toggle LED
        Pause 500
    NEXT
        high led
        CCP1CON = %00001100     ' Normal PWM mode
        T2CON.2 = 1             ' Timebase ON
        PAUSE 15
        low led
        T2CON.2 = 0             ' Timebase OFF
        CCP1CON = %00000000     ' Disable PWM to regain control of PortA.2
        PAUSE 5
    Goto Main
    The data sheet states:
    The CCP module’s input/output pin (CCP1) can be
    configured as RB2 or RB3. This selection is set in bit 12
    (CCPMX) of the Configuration Word register.
    I have no idea how to change this setting and if this is the reason why I get no output.
    Is there anything that I should do differently?
    Thank you in advance for any input.
    Nick
  1. internal TMR for frequency output
    By Samoele in forum mel PIC BASIC Pro
    Last Post: - 15th January 2009, 10:38
  2. How to calculate PIC sampling frequency
    By minmin in forum General
    Last Post: - 26th September 2006, 19:02
  3. Replies: 2
    Last Post: - 20th January 2006, 22:09
  4. Maximum frequency count on 16F628/4MHz
    By solara in forum mel PIC BASIC Pro
    Last Post: - 23rd May 2005, 11:38
  5. Low frequency output
    By barkerben in forum General
    Last Post: - 16th November 2004, 16:25
