	SerialIN							;receive serial byte with pre-determined timeout
  movf		R6		,W				;move timeout delay to temp
  movwf		R0						;
  movf		R15		,W				;
  movwf		R9						;
  movlw		0x01						;
  movwf		R1						;set inside loop counter
  clrf		R10						;
serial_loop							;
  clrwdt							;keep watchdog timer clear
  call		SerinX						;get one bit
  btfss		status		,C				;wait for start bit
  goto		serinstart					;
  decfsz	R1		,F				;
  goto		serial_loop					;
  movlw		0xFF						;
  addwf		R10		,F				;
  btfsc		status		,C				;
  goto		serial_loop					;
  addwf		R0		,F				;
  btfss		status		,C				;
  addwf		R9		,F				;
  btfss		status		,C				;
  goto		DoneX						;time out
  movlw		0x32						;
  movwf		R1						;reset inside loop counter
  clrw								;
  movwf		R10						;
  goto		serial_loop					;
SerialIN_notimeout						;
  clrwdt							;receive byte serialy with no timeout
  btfsc		status		,C				;wait for start bit
  goto		SerialIN_notimeout				;
serinstart							;
  call		serialdelay					;wait 1/4 bit time
  clrf		R4						;zero parity accumulator
  movlw		0x08						;number of bits in one byte
  movwf		R10						;
serpar								;
  call		seroutdelay					;wait bit time
  btfsc		status		,C				;accumulate parity
  incf		R4		,F				;
  btfss		R14		,05				;if no parity...
  clrf		R4						;...keep it even
  rrf		R1		,F				;move bit into byte
  decfsz	R10		,F				;check for more bits
  goto		serpar						;
  btfsc		R14		,05				;if parity...
  bcf		R1		,07				;...clear top bit of result
  call		seroutdelay					;delay to stop bit
  bsf		status		,C				;carry shifts in clear
  movf		R1		,W				;get char to W
  return							;
SerinX								;
  movf		RR2		,W				;receive one bit for serial in
  movwf		fsr						;
  movf		RR1		,W				;
  bsf		fsr		,07				;
  iorwf		indf		,F				;
  bcf		fsr		,07				;
  andwf		indf		,W				;
  btfsc		R14		,06				;
  xorwf		RR1		,W				;
  addlw		0xFF						;
  return							;
SerialIN_skipbyte						;
  movf		R13		,W				;ignore received byte for serial in
  bsf		status		,C				;
  btfsc		status		,Z				;
  goto		DoneX						;
  call		skipX						;
  btfss		status		,C				;
  return							;
  decf		R13		,F				;
  goto		SerialIN_skipbyte				;
serialOUT							;transmit byte serialy from port pin
  movwf		R3						;save byte to send
  movf		RR2		,W				;get port to fsr
  movwf		fsr						;
  movlw		0x80						;zero parity accumulator (preserve blanking)
  andwf		RM2		,F				;
  movlw		0x08						;1 start bit + 7 data bits
  movwf		R12						;
  bcf		status		,C				;start bit low
seroutloop							;
  btfsc		status		,C				;accumulate parity bits
  incf		RM2		,F				;
  call		seroutbit					;send a bit and delay bit time
  rrf		R3		,F				;move to next bit
  decfsz	R12		,F				;do next bit, if any
  goto		seroutloop					;
  nop								;
  btfsc		R14		,05				;send parity
  rrf		RM2		,W				;get parity to carry
  call		seroutbit					;send parity or last bit and delay bit time
  call		Done						;
  bsf		status		,C				;stop bit high
  call		seroutbit					;send stop bit and delay bit time
  movf		R16		,W				;do pacing
  movwf		R10						;
  movf		R7		,W 				;
  goto		DelayX						;
seroutbit							;
  bcf		fsr		,07				;make sure we're pointing to the port
  btfss		R14		,07				;check for TRIS mode
  goto		seroutnorm					;handle normal mode
  movf		indf		,W				;get port data
  iorwf		RR1		,W				;set bit on
  btfss		R14		,06				;bit matches invert mode
  xorwf		RR1		,W				;set bit off
  movwf		indf						;write it out
  bsf		fsr		,07				;point fsr to port tris
  movf		indf		,W				;get tris data
  iorwf		RR1		,W				;make bit an input
  btfss		status		,C				;bit direction matches bit
  xorwf		RR1		,W				;make bit an output
  goto		seroutdelay					;wait remainder of bit time
seroutnorm							;
  btfss		status		,C				;skip if bit should be on
  btfsc		R14		,06				;invert if 'N' mode
  xorwf		RR1		,W				;flip for invert
  comf		RR1		,W				;get complemented bit mask to W
  andwf		indf		,F				;clear tris bit to set output
serialdelay							;
  bsf		RM2		,06				;
seroutdelay							;
  movf		R14		,W				;get high baud byte
  andlw		0x1F						;mask to our bits
  addlw		0xFF						;fix baud
  movwf		R9						;save it
  movf		R5		,W				;get low baud byte
  addlw		0xF5						;
  btfsc		status		,C				;bump up high byte if low overflowed
  incf		R9		,F				;
  btfss		RM2		,06				;
  goto		pauseUSL					;
  bcf		RM2		,06				;clear short delay mark
  movwf		R0						;save low part
  movlw		0x02						;divide time by 4
  call		shiftR						;
  goto		pauseUSL					;do 1/4 delay
 That's quite a lot of code asking to be placed in the first 2K code space (and kicking your code out).
	Delay
  clrf		R10						;delay 1
DelayX								;
  movwf		R1						;delay 2
DelayXX								;
  movlw		0xFF						;
  addwf		R1		,F				;
  btfss		status		,C				;
  addwf		R10		,F				;
  btfss		status		,C				;
  goto		DoneX						;
  movlw		0x03						;
  movwf		R9						;
  movlw		0xDF						;
  call		pauseUSL					;
  goto		DelayXX						;
  clrf		R9						;
pauseUSL							;
  addlw		0xE8						;
  movwf		R0						;
  comf		R9		,F				;
  movlw		0xFC						;
  btfss		status		,C				;
  goto		XpauseUSL					;
pauseX								;
  addwf		R0		,F				;
  btfsc		status		,C				;
  goto		pauseX						;
XpauseUSL							;
  addwf		R0		,F				;
  clrwdt							;
  incfsz	R9		,F				;
  goto		pauseX						;
  btfsc		R0		,00				;
  goto		pausedoneX					;
pausedoneX							;
  btfss		R0		,01				;
  goto		pausedone					;
  goto		Done						;
 or on chip-EEPROM Read/Write:
	EEPROMread							;read byte from on-chip EEPROM
  bsf		status		,rp0				;for bank 1
  movwf		EEADR						;set the EEPROM address
  bsf		EECON1		,0x0				;EECON1 in bank 3
  movf		EEDATA		,W				;read from data memory
  goto		DoneX						;done
EEPROMwrite							;write byte to on-chip EEPROM
  bsf		status		,rp0				;for EE in bank 1
  movwf		EEDATA						;set the EEPROM data
  bsf		EECON1		,02				;
  movlw		0x55						;unlock the door
  movwf		EECON2						;
  movlw		0xAA						;
  movwf		EECON2						;
  bsf		EECON1		,01				;do the write
writeloop							;
  btfsc		EECON1		,01				;wait for the write to complete
  goto		writeloop					;
  bcf		EECON1		,02				;lock up when we're done
  goto		DoneX						;
 So bottom line is if you are using any of these, insert them in your code once, straight away
