Interupt driven servo PWM output
Results 1 to 10 of 10
    Aug 2013
    Post Re: Interupt driven servo PWM output
    The time between transit and interrupt handler is the main culprit here in your servo pulse width modulation. Sometimes the turn around time makes us wait more and it doesn't work in the end even though everything seems right. Happens with me all the time. Connected a lipo battery once as a power supply and it never worked because of misconfiguration.
    Good luck to you.
    Aug 2013
    Default Re: Interupt driven servo PWM output
    Quote Originally Posted by LettyLocke View Post
    Good luck to you.
    No more updates regrading the issue? I think the interval time of interrupts must be increased in order for it to work. Interrupt handlers are very tricky to work with.
  1. Servo and pwm
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 29th May 2009, 14:26
  2. how to change servo motor PWM
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 21st September 2008, 07:02
  3. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 05:02
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
  5. 16f73 pwm capture interupt
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2005, 22:22
