Interupt driven servo PWM output
Results 1 to 10 of 10
    Default Re: Interupt driven servo PWM output
    Mark, Thank you for the reply.
    perhaps i should have explained more.
    I'm using DT's interupts. SERVO_HANDLER is jumped to whenever TMR0 overflows and interrupts.
    The endif's after the @ INT_RETURN do not need to be 'executed' they just define the end if that IF statement. The @ INT_RETURN is placed within the IF statement so that it does not attempt to phrase the second IF statement after executing the first one thus saving time and eliminating a bug.
    MAIN: is their to make the servo move so that i can see it's throw and thus that it's working. Once the PC has setup itself, then it's vars it then needs to fall into the MAIN: loop. Once their it can interrupt into the SERVO_HANDLER when the TMR0 goes off...
    Vars TMR0_CON_PL1 & PRELOAD1 are the TMR0 settings for the 1000us initial on for the control signal to the servo.
    Vars TMR0_CON_PL2 & PRELOAD2 are the TMR0 setting for the PWM duration. This 4us duration is executed 255 times totalling over 1000us for the pwm period of the control signal to the servo.
    Vars TMR0_CON_PL3 & PRELOAD3 are the TMR0 setting for the sleet time after the PWM has finished to make a 50Hz signal (20000us total) to the servo.
    I think what Mark is saying is that there are parts of DT-Ints missing in your code, you don't seem to include the needed files and there's no place where you're actually defining/setting up the interrupts. Is that really the complete code you've posted? My guess is no since I don't think it would even compile like that.
    What's your oscillator speed? 8MHz? Do you have that defined somewhere in your code?
    I'm pretty sure that interrupting at 4us intervals isn't going to work, IF you're running at 8MHz that's only 8 instructions between each interrupt and it takes WAY WAY more than that for DT-Ints just to do the context save and restore, the interrupts are "running over them selves".
    ok, here is the full code... i didn't think the top bit was necessary...
    @ __config _CONFIG1H, _FOSC_INTIO67_1H & _PLLCFG_ON_1H & _PRICLKEN_ON_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __config _CONFIG2L, _PWRTEN_ON_2L & _BOREN_SBORDIS_2L & _BORV_220_2L
    @ __config _CONFIG2H, _WDTEN_OFF_2H & _WDTPS_32768_2H & _CCP2MX_PORTC1_3H & _PBADEN_OFF_3H
    @ __config _CONFIG3H, _CCP3MX_PORTE0_3H & _HFOFST_OFF_3H & _T3CMX_PORTC0_3H & _P2BMX_PORTC0_3H & _MCLRE_INTMCLR_3H
    @ __config _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    @ __config _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @ __config _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __config _CONFIG6L, _WRT0_OFF_6L
    @ __config _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @ __config _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __config _CONFIG7H, _EBTRB_OFF_7H
    INCLUDE "DT_INTS-18.bas" ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas" ; Include if using PBP interrupts
    INT_Handler TMR0_INT, _SERVO_HANDLER, PBP, yes
    Define OSC 64 ' Set clock speed
    OSCCON.7 = 0
    OSCCON.6 = 1
    OSCCON.5 = 1
    OSCCON.4 = 1
    OSCCON.1 = 0
    OSCCON.0 = 0
    OSCTUNE.6 = 1
    ANSELA = %00000000
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISB = 0
    PORTB = 0
    TRISC = 0
    PORTC = 0
    TRISD = 0
    PORTD = 0
    TRISE = 0
    PORTE = 0
    TRISA = 0
    ALOOP VAR WORD
    SERVO1 VAR LATD.0
    SERVO1POS VAR BYTE
    PRELOAD1 VAR WORD
    PRELOAD2 VAR WORD
    PRELOAD3 VAR WORD
    SERVOCMDMODE VAR BYTE
    SERVOPWMCOUNTER VAR WORD
    PRELOAD1 = 63556 ' 990us '63556
    TMR0_CON_PL1 CON %10000010 ' 1:8
    PRELOAD2 = 65528 ' 4us '65528
    TMR0_CON_PL2 CON %10000010 ' 1:8
    PRELOAD3 = 29556 ' 17990us '29556
    TMR0_CON_PL3 CON %10000010 ' 1:8
    @ INT_ENABLE TMR0_INT
    TMR0L = PRELOAD3.LOWBYTE
    TMR0H = PRELOAD3.HIGHBYTE
    T0CON = TMR0_CON_PL3
    SERVOCMDMODE = 1
    MAIN:
    SERVO1POS = 0
    PAUSE 5000
    SERVO1POS = 128
    PAUSE 5000
    SERVO1POS = 255
    PAUSE 5000
    GOTO MAIN
    SERVO_HANDLER:
    IF SERVOCMDMODE = 2 Then
    IF SERVOPWMCOUNTER < 256 THEN
    T0CON = TMR0_CON_PL2
    TMR0L = PRELOAD2.LOWBYTE
    TMR0H = PRELOAD2.HIGHBYTE
    IF SERVO1POS < SERVOPWMCOUNTER THEN
    SERVO1 = 0
    LATD.1 = 0
    LATD.2 = 0
    LATD.3 = 0
    SERVO1 = 1
    LATD.1 = 0
    LATD.2 = 1
    LATD.3 = 0
    SERVOPWMCOUNTER = SERVOPWMCOUNTER + 1
    SERVO1 = 0
    LATD.1 = 0
    LATD.2 = 0
    LATD.3 = 1
    SERVOCMDMODE = 1
    @ INT_RETURN
    IF SERVOCMDMODE = 1 Then
    T0CON = TMR0_CON_PL1
    TMR0L = PRELOAD1.LOWBYTE
    TMR0H = PRELOAD1.HIGHBYTE
    SERVOCMDMODE = 2
    SERVO1 = 1
    LATD.1 = 1
    LATD.2 = 0
    LATD.3 = 0
    SERVOPWMCOUNTER = 1
    @ INT_RETURN
    @ INT_RETURN
    OK, so you're running at 64MHz, that gives it bit more time but I still think that interrupting at 4us intervals is way to fast, there's only 64 instruction cycles between each interrupt and I think it takes more than that for the DT-Ints system just to save and later restore the system variables. And, even if it does work the code would spend most of its time in transit to and from the interrupt handler.
    Aug 2013
    Post Re: Interupt driven servo PWM output
    The time between transit and interrupt handler is the main culprit here in your servo pulse width modulation. Sometimes the turn around time makes us wait more and it doesn't work in the end even though everything seems right. Happens with me all the time. Connected a lipo battery once as a power supply and it never worked because of misconfiguration.
    Good luck to you.
    Aug 2013
    Quote Originally Posted by LettyLocke View Post
    Good luck to you.
    No more updates regrading the issue? I think the interval time of interrupts must be increased in order for it to work. Interrupt handlers are very tricky to work with.
  1. Servo and pwm
    By Meriachee in forum mel PIC BASIC Pro
    Last Post: - 29th May 2009, 14:26
  2. how to change servo motor PWM
    By dboy in forum mel PIC BASIC Pro
    Last Post: - 21st September 2008, 07:02
  3. Help needed - MOSFET driven by PWM
    By bcd in forum mel PIC BASIC Pro
    Last Post: - 2nd April 2008, 05:02
  4. 16F877a Interupt driven Hserin
    Last Post: - 3rd November 2006, 00:38
  5. 16f73 pwm capture interupt
    By EDWARD in forum mel PIC BASIC Pro
    Last Post: - 22nd July 2005, 22:22
