Can you use the same pin as input/output and control led load?
Results 1 to 7 of 7
    Nov 2007
    West Covina, CA
    Default Re: Can you use the same pin as input/output and control led load?
    To answer your question and your concern,
    Yes, you can monitor that circuit then switch to an output without over driving it.
    Louie
    I believe most pic16's and PIC18's have a 20mA source or sink limit so a resistor on the pin would not be required.
    So FromTheCockpit's diagram above will work, though you will not get 5V to feed the LED so you'll need to trim the LED's resistor if you want a brighter LED.
    Also on that note... an LED consumes more than 20mA (~33mA at desired voltage i believe) so... you may not need a resistor on the LED. Instead, if you up the voltage divider resistance values ~ 2K each the LED would not come on but you would still have your /2 voltage divider.
    Dec 2010
    What are you trying to accomplish with this circuit?
    Is the objective to have the LED on dimly and be able to confirm it has not failed, then be able to have the PIC turn it on brightly or off completely?
    Is the PIC also powered by 5V?
    If so, R3 does not serve any purpose...
  1. Replies: 1
    Last Post: - 6th April 2007, 11:50
  2. Input / output using same pin
    By leonel in forum mel PIC BASIC Pro
    Last Post: - 4th March 2007, 22:19
  3. WPU - Input - Output pin triangle
    By sayzer in forum mel PIC BASIC Pro
    Last Post: - 1st July 2006, 12:43
  4. Replies: 1
    Last Post: - 3rd June 2005, 13:17
  5. Using 4 input to control 10 output
    Last Post: - 5th November 2004, 13:08
