DS1337 - 12h to 24h mode
Results 1 to 31 of 31
    Sep 2006
    Default DS1337 - 12h to 24h mode
    Hello,
    I am trying to convert from 12h mode to 25H mode and vice versa with a Ds1337 chip. Not getting great results for now.
    What I understand Bit 5 and 6 or the hours plays a role in converting. Her is a clip from the datasheet:
    The DS1337 can be run in either 12-hour or 24-hour mode. Bit 6 of the hours register is defined as the 12- or 24-
    hour mode-select bit. When high, the 12-hour mode is selected. In the 12-hour mode, bit 5 is the AM/PM bit with
    logic high being PM. In the 24-hour mode, bit 5 is the second 10-hour bit (20–23 hours).
    I am configuring it so that when two buttons are pressed down for over 1.5 seconds, the conversion between 12h mode to 24h mode is done. From what I understan, I also need to convert the time myself example: from 20H to 8H. The code for me should work but keeps giving me random values, any ideas ?
    thanks
            If (PortC.5 = 1) & (PortC.6 = 1) then Pause 1500
                'IF hourly mode = AM
                I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
                Pause 10
                     if RTCHour.6 = 1 then      'turn into 24h mode   therefore 1 to 11 converts to 13 to 23
                     point =2
                     gosub bcd_to_bin
                     RTCHour = TempVal + 12
                     RTCHour.6 = 0
                     if RTCHour.6 = 0 then      'turn into 12h mode   therefore 13 to 23 converts to 1 to 11
                     point =3
                     gosub bcd_to_bin
                     RTCHour = TempVal - 12
                     RTCHour.6 = 1
                I2cwrite SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
                Pause 100
    Jan 2013
    Texas USA
    Default Re: DS1337 - 12h to 24h mode
    I could see a couple of issues here, but without additional information it's a guess.
    1. You do not post your RTC Initialization routine so how are you setting up the RTC 12 Hour or 24 Hour mode initially?
    1a. After initialization does your project display the correct values before you enter your 12/24 Hour configuration routine?
    Note: If you change the 12/24 hour mode at any time with a write to the RTC, you will need to perform a second write to the RTCHour register (noted in the DS Pg 9 last paragraph under "Clock and Calendar").
    2. I see that you are looking at the 12/24 hour bit, but I do not see that you are checking/setting the AM/PM bit (RTCHour.5). When the RTC is set for 12 hour mode you might want to set this or the calendar values of the RTC will be off.
    3. You did not include your bcd_bin routine so there may be issues there, can't tell without seeing it.
    3a. You seem to be converting from BCD to BIN (gosub bcd_bin) when you read and are wanting to change to the other mode (12/24 Hr) but...
    I do not see where you are converting from BIN back to BCD before you write back to the RTC.
    Unless you are using the "point" variable in a IF/Then or Select Case structure in the bcd_bin routine to select BcdToBin or BinToBcd, again hard to tell without seeing the code. I also assume the TempVar variable holds the converted value from the bcd_bin routine??
    Also, if you are using and LCD or other output device, try and display out the variables at different stages of your configuration routine to make sure that the values are what you expect.
    Perhaps you might want to post more of your code to see if we can help further.
    Just my thoughts.
    TABSoft
    I think your becoming a good case for the snippets are us award
    but if you intention is to just to set/reset 24 h mode on the chip
     If(PortC.5 = 1) & (PortC.6 = 1) then Pause 1500
       I2CRead SDApin,SCLpin,$D0,$02,[RTCHour]
       RTCHour.6 = ! RTCHour.6
       I2cwrite SDApin,SCLpin,$D0,$02,[RTCHour]
    Sep 2006
    Here is the full code.
    The display gosub is not being used, will be used when display in a 7 segment display.
    Now I am using a LCDout command to view my numbers
    '////////////////// PROGRAM /////////////////////////
     I2CWRITE SDApin,SCLpin,$D0,$00,[$56,$59,$20,$00,$00,$00,$00,$00] ' Write to DS1337 to initialize RTC
     pause 10
                 I2CRead SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]     ' bit 5 of hour is 1 for PM  , 0 for AM
                 pause 10
                 'RTCHour.5 = 1      'bit 5 is the AM/PM bit with logic high being PM   AND NOT USED
                ' RTCHour.6 = 0   '24h selected    ' for 12 or 24 h  mode ,  when high 12h mode is selected
                 'in 24 hour mode (=0)  bit 5 is used for hours 20 to 23
                      I2CwRITE SDApin,SCLpin,$D0,$00,[RTCSec,RTCMin,RTCHour]
                       pause 10
    Mainloop:
            gosub bcd_to_bin
                Pause 10
                     point =2
                     RTCHour.6 = 0
                     point =3
                     RTCHour.6 = 1
                Pause 100
            temp1_min = RTCMin_temp1
            m = temp1_min
            'PortA.0 =1
            'gosub display
          '  PortA.0 =0
            temp2_min = RTCMin_temp2
            n = temp2_min
          '  PortA.1 =1
          '  gosub display
         '   PortA.1 =0
            temp1_sec = RTCSec_temp1
            o = temp1_sec
           ' PortA.2 =1
           ' gosub display
           ' PortA.2 =0
            temp2_sec = RTCSec_temp2
            p = temp2_sec
           ' PortA.4 =1
            'gosub display
            'PortA.4 =0
            		lcdout $FE,1, "Time: ",  HEX2 RTCHour, ":", hex2 RTCmin ,":", HEX2 RTCsec 'in decimals... wow
    				lcdout $FE,$C0, dec TempVal , " :" ,dec RTCHour_temp1,":", dec RTCHour_temp2,":", dec point
    				Pause 150
        goto Mainloop
        bcd_to_bin:
         if (RTCHour.6 = 1 ) then      'bit 5 is used if RTCHour.6 = 0   ; 24h selected
           RTCHour.6 = 0
           RTCHour.5 = 0
         RTCHour_temp2 = $0F & RTCHour
         RTCHour_temp1= RTCHour >> 4
         if (RTCHour.6 = 0 ) then
         RTCHour_temp2 = %00001111 & RTCHour
         RTCHour_temp1= RTCHour >> 4                        ' Shift down four to read 2 BCD value
         TempVal = RTCHour_temp1 * 10 + RTCHour_temp2       ' this calculate the hours in decima
          if ( TempVal > 19 ) then
             RTCHour.5 = 0
         RTCMin_temp2 = $0F & RTCMin               ' Clear off the top four bits
         RTCMin_temp1= RTCMin >> 4                       ' Shift down four to read 2 BCD value
         RTCSec_temp2 = $0F & RTCSec                     ' Clear off the top four bits
         RTCSec_temp1= RTCSec >> 4                       ' Shift down four to read 2 BCD value
    this may be better
       temp1 = ((RTCHour>> 4) * 10) + (RTCHour& $0f)    , to binary
       if RTCHour.6=1  then   ' 12h mode
            if RTCHour.5=1then  temp1=temp1+12  ' pm
             if temp1 > 12 then
             temp1=temp1-12
      rtcHOUR = ((temp1 / 10) << 4) + (tEmp1 // 10)  ' to bcd
     RTCHour.6 = ! RTCHour.6  '  set/reset   24h mode
    no I'm still wrong, why is time so complicated
    try
      if RTCHour.6=1 then
           temp1 = (((RTCHour&$1f)>> 4) * 10) + (RTCHour& $0f)    ' to binary  mask off am/pm
           temp1 = ((RTCHour>> 4) * 10) + (RTCHour& $0f)    ' to binary
             if temp1 > 12 then
             temp1=temp1-12
      rtcHOUR = ((temp1 / 10) << 4) + (temp1 // 10)  ' to bcd
    Sep 2006
    Hi Richard,
    Trie both code with same error,
    It does seem to go from 19h to 7h.
    When I attempt to go back to 19H I get a four appearing before the hours .. like so : 7:01:01 to 47:01:01 then the four disappear to come back to 7:01:01 ( yes minutes and seconds are still incrementing. But this is weird that the four would just leave by its own !
    Also the datasheet specifies that the bit 5 hour.5 is used for the hours between the 20 to 23 hours.
    the "4 " probably comes from the fact that temp1 is used in you display routine and its getting messed with by my code
    make a new byte var temp12 for use in the 12/24 routine in place of temp1
    but it should go to 19h not stay at 7h check if the am/pm is getting cleared when 24h mode is selected
    I have to go to work for a while
    Jan 2013
    Texas USA
    Give this a whirl.
    rtcAMPM    var bit   ' Storage flag to indicate AM or PM ; 0=AM, 1=PM
    hourmode  var bit   ' Storage flag for RTC 12/24 hour mode ; 0=24Hr, 1=12Hr
    BCDResult  var byte  ' Storage for temporary result for BCD Conversions
       hourmode = RTCHour.6
       if hourmode = 1 then          ' Is the RTC set for 12-hour mode
        rtcAMPM = RTCHour.5          ' Assign AM/PM
        RTCHour = RTCHour & %00011111  ' Bits 4-0 = Hours  0-12
      BCDResult = RTCHour
      gosub Bcd2Dec
      if hourmode = 1 then  '12Hr
        if rtcAMPM = 1 then 'PM
            BCDResult = BCDResult + 12  'PM
        if BCDResult > 12 then
            BCDResult = BCDResult - 12
            rtcAMPM = 1
            rtcAMPM = 0
      gosub Dec2Bcd
      RTCHour = BCDResult
      hourmode = ! hourmode
      pause 10
      I2cwrite SDApin,SCLpin,$D0,$02,[RTCHour]  ' Need to write twice because you changed the mode bit
     Bcd2Dec:
    ' Subroutine to convert BCD (2 hex digits) to Decimal
    ' Make sure to set BCDResult with parameter value before calling this sub
    ' Result is stored in BCDResult
        BCDResult = (((BCDResult >> 4) * 10) + (BCDResult & $0f))
    Dec2Bcd:
    ' Subroutine to convert Decimal to BCD (2 hex digits)
        BCDResult = (((BCDResult / 10) << 4) | (BCDResult // 10))
    TABSoft
    Sep 2006
    Thanks for all the help.
    I just tried your code tabsoft, work very good from 18H to 7H, but not the opposite.
    hourmode = not hourmode
    but still I print out on the LCD that specific bit and I always get a 1 ...
    wird.. I also have RTChour output in binary and I only get 111 (7) and not 100111 as I thought ..
    Sep 2006
    I try these lines:
    if RTCHour.6 =0 then RTCHour.6 =1
    if RTCHour.6 =1 then RTCHour.6 =0
    instead of hourmode = ! hourmode
    hourmode is always showing 0 after going from 19 to 7 . and stays at 7 even with buttons pressed
    Jan 2013
    Texas USA
    See if this works for you. I can't try it on the HW, but I think this will do it for you
      BCDResult = RTCHour
      gosub Bcd2Dec
      if hourmode = 1 then  '12Hr Convert to 24Hr
        hourmode = 0    ' change to 24Hr
      else  '24Hr Convert to 12Hr
        hourmode = 1
            rtcAMPM = 1
            rtcAMPM = 0
      gosub Dec2Bcd
      RTCHour = BCDResult
      RTCHour.6 = hourmode
      RTCHour.5 = rtcAMPM
      pause 10
     Bcd2Dec:
    Dec2Bcd:
    TABSoft
    Sep 2006
    Starting with 19H pushing button attempts shows (4 trials one after the other) :
    - 87 very briefly then 7H. ok, good enough..
    - 1H
    -23H
    -73H briefly then 13H
    I really need to sit down and look at the problem more closely.
    But in this case the hourmode bit changes heyyyy !!
    Jan 2013
    Texas USA
    I would eliminate the key presses for testing. Setup a pause in your main loop and a just change a new bit variable to mimic the key press action. Just to isolate where the issue may be.
    Something like.
    Keypressbit var bit
    Keypressbit = 0
    Mainloop:
    Pause 1500
    If Keypressbit = 1 then
    ......... Etc
    ' at the end of Mainloop
    Keypressbit = ~ Keypressbit
    Pause 2000 ' 2 second pause
    GOTO Mainloop
    Btw, ! hourmode should have been ~ hourmode (bit wise not)
    Good luck
    TABSoft
    the code by tabsoft works fine with a ds1307 and the double write is not needed , I have not got a 1337 to test
    ' pic16f688
           __config _INTRC_OSC_NOCLKOUT & _CP_OFF & _WDT_OFF  &  _PWRTE_ON  &  _MCLRE_ON  & _BOD_ON    &  _BOR_ON
            DEFINE OSC 8
           DEFINE NO_CLRWDT 1
            CRC VAR BYTE   BANK0 SYSTEM    'CRC
                SDApin   var PORTC.0                'SDA
                SCLpin   var PORTC.1               'SCL
                tmp var byte
                pkt var byte[11]
     RTCHour    var byte
              osccon=$70    '8 mhz
              ansel=0       'dig i/o
              CMCON0=7        ' compare off
                     trisc=%100000
      portc=3
      pause 10
    i2cwrite  sdapin,sclpin,$D0,0,[$0,$14,$21,3,$14,1,$14]  'SANE TIME AND DATE
    'i2cwrite  sdapin,sclpin,$D0,0,[0]
     pause 3000
             serout2 porta.0,84, ["ready",13,10]
      i2cREAD  sdapin,sclpin,$D0,0,[str pkt \3 ]
          RTCHour = pkt[2]
       if  RTCHour.6 then
       serout2 porta.0,84, [hex2 (pkt[2]&$1f),":",hex2 pkt[1],":",hex2 pkt[0]]
        if   RTCHour.5 then serout2 porta.0,84, [" pm" ]
         serout2 porta.0,84, [13,10]
       serout2 porta.0,84, [hex2 pkt[2],":",hex2 pkt[1],":",hex2 pkt[0],13,10]
        pause 5000
      gosub ampm
    ampm:
      BCDResult = RTCHour
      gosub Bcd2Dec
        hourmode = 1
            rtcAMPM = 1
            rtcAMPM = 0
      gosub Dec2Bcd
      RTCHour = BCDResult
      RTCHour.5 = rtcAMPM
      'pause 10
      'I2cwrite SDApin,SCLpin,$D0,$02,[RTCHour]  ' Need to write twice because you changed the mode bit
     Bcd2Dec:
    Dec2Bcd:
    Sep 2006
    HI,
    I rework your code so I can read it on my LCD:
    Its works ! dont know what we did wrong in the previous version.
    Also works equally good on DS1337 and DS1307 !
    Thanks a lot to all
    Sep 2006
    HI,
    I am adding to the program and came across another difficulty,
    I used one button to increments hours and another to increments minutes. Minutes works fine.
    But hours, when I start with 19H, do a 24h to 12H conversion.. then when I increase the hours, no matter what time I have the output is 20H, with RTChour.6 = 0 and RTCHour.5 = 1.
    I'm stuck in this loop, anybody can see why??
    thanks
    I posted the complete code, the rest is working great.
    INCLUDE "modedefs.bas"
    Define OSC 8
    CM1CON0.7 = 0
    CM2CON0.7 = 0
    DEFINE BUTTON_PAUSE 50
    '////////////////// HPWM /////////////////////////
    DEFINE CCP1_REG PORTC
    DEFINE CCP1_BIT 2
    Pause 20
    '// LCD configuration //
    DEFINE LCD_DREG PORTA ' Set LCD Data port
    DEFINE LCD_DBIT 0 ' Set starting Data bit (0 or 4) if 4-bit bus RB.4, RB.5, RB.6, RB.7
    DEFINE LCD_RSREG PORTB ' Set LCD Register Select port
    DEFINE LCD_RSBIT 7 ' Set LCD Register Select bit
    DEFINE LCD_EREG PORTB ' Set LCD Enable port
    DEFINE LCD_EBIT 6 ' Set LCD Enable bit
    DEFINE LCD_BITS 4 ' Set LCD bus size (4 or 8 bits) '4 therefore put wire at 4, 5, 6 and 7 of LCD
    DEFINE LCD_LINES 2 ' Set number of lines on LCD
    DEFINE LCD_COMMANDUS 2500
    DEFINE LCD_DATAUS 250
    DEFINE CHAR_PACING 2000
    '// Variable Declaration and initialization //
    TrisB= 0
    TrisA= 0
    'TrisC=%00110000
    SDApin var PORTC.4 ' RTC data
    SCLpin var PORTC.3 ' RTC clock
    tmp var byte
    RTCSec var byte
    RTCMin var byte
    temp_hour var byte
    temp_min var byte
    pkt var byte[11]
    RTCHour var byte
    ' osccon=$70 '8 mhz
    ansel=0 'dig i/o
    ' CMCON0=7 ' compare off
    trisc=%1110000
    pause 10
    i2cwrite sdapin,sclpin,$D0,0,[$0,$14,$13,3,$14,1,$14] 'SANE TIME AND DATE
    lcdout $fe,$c0," Ready",13,10
    'serout2 porta.0,84, ["ready",13,10]
    Gosub gethour
    if PortC.6=1 then gosub ADDHour
    if PortC.5=1 then gosub ADDMin
    gethour:
    RTCHour = pkt[2]
    if RTCHour.6 then
    lcdout $fe,1,"Time=", hex2 (pkt[2]&$1f),":",hex2 pkt[1],":",hex2 pkt[0] 'bit 0=sec, bit 1=min, bit 2=hrs
    lcdout $FE,$C0, bin RTCHour.6, " : ", bin RTCHour.5
    if RTCHour.5 then lcdout $fe,$c0, bin RTCHour.6, " pm" 'serout2 porta.0,84, [" pm" ]
    else ' if RTCHour.6 =0
    lcdout $fe,1,"Time=", hex2 pkt[2],":",hex2 pkt[1],":",hex2 pkt[0]
    if PortC.5 & PortC.6 then gosub ampm
    ampm:
    Pause 500
    BCDResult = RTCHour
    gosub Bcd2Dec
    hourmode = 1
    rtcAMPM = 1
    rtcAMPM = 0
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    'pause 10
    Bcd2Dec:
    Dec2Bcd:
    ADDHour: 'increment hours
    pause 200
    if PortC.5=1 then return
    if PortC.6=1 then
    rtcAMPM = RTCHour.5
    BCDResult = RTCHour
    gosub Bcd2Dec
    if hourmode = 0 then ' this is 24H mode 0H to 23H
    hourmode = 1
    if BCDResult > 23 then BCDResult = 0
    Pause 2
    gosub Dec2Bcd
    RTCHour = BCDResult
    elseif hourmode = 1 then ' this is 12H mode 0H to 11H
    hourmode = 0
    if BCDResult > 11 then BCDResult = 0
    Pause 2
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    ' lcdout $FE,1, "RTCH2: ", bin RTCHour
    ' lcdout $FE,$C0, "BCDR: ", bin BCDResult
    ' pause 5000
    ADDMin: ' increment a minutes
    pause 200
    if PortC.6=1 then return
    if PortC.5=1 then
    ' I2CRead SDApin,SCLpin,$D0,$02,[RTCHour]
    BCDResult = RTCMin
    gosub Bcd2Dec
    if BCDResult > 59 then BCDResult = 0
    Pause 2
    gosub Dec2Bcd
    RTCMin = BCDResult
    I2cwrite SDApin,SCLpin,$D0,$01,[RTCMin]
    Sep 2006
    The bit RTCHour.5 is mixing the time up.. I think..
    Why did they use it at a dual purpose.... !
    Jan 2013
    Texas USA
    Lerameur,
    So, just some basic high-level things to understand when dealing with these RTC ICs.
    The data in the RTC registers are in BCD format.
    When you make changes to them, say the Hours register you should follow some specific steps.
    Get the BCD Hours from the RTC
    Save the value of 12/24 mode in your code
    Save the value of the am/pm bit value in your code
    Mask out the am/pm and 12/24 bits if required
    Convert the BCD hours to Decimal hours
    Change the Decimal Hours to the value you want
    Convert the Decimal Hours to BCD Hours
    Set the 12/24 Bit correctly in the New BCD Hours value
    Set the am/pm Bit correctly in the New BCD Hours value
    Write the new BCD Hours value to the RTC
    Try not not intermix operations.
    Change the Hour value or change the 12/24 mode, but not both in the same action.
    When in 12hr mode, change the time the way you need to for that mode.
    When in 24hr mode, change the time the way you need to for that mode.
    Another suggestion is create yourself a table for hours in Excel or a text editor.
    List all the hours in 12hr mode and also for 24hr mode.
    Then for each hour record the byte (in binary) value for the RTC Hour register you would need for that time, making sure to set/clear the 12/24 mode and am/pm bits appropriately.
    Looking at that kind of table may help you visualize what you need in your code to change time values to/from different values and when changing 12/24 modes.
    Just some thoughts that I followed quite a while back to get a handle on using RTC ICs.
    TABSoft
    TABSoft
    Jan 2013
    Texas USA
    Some additional direction.
    12hr Mode
    Display Value to LCD:
    1. Mask off 12/24Hr mode bit
    2. Mask off am/pm bit
    3. Display new masked value with Hex2 modifier
    Change Hour Value in RTC:
    3. Convert new masked value from BCD to Decimal
    4. Change Hour value in Decimal
    5. Convert Decimal Hour back to BCD
    6. Set am/pm bit
    7. Set 12/24Hr mode bit
    8. Write new value to RTC Hour register
    24hr Mode
    1. Display value with Hex2 modifier
    1. Convert value from BCD to Decimal
    2. Change Hour value in Decimal
    3. Convert Decimal Hour back to BCD
    4. Write new value to RTC Hour register
    Here is a table that shows two hour values in their various permutations.
    SampleTable.txt
    Hope this helps.
    TABSoft
    Sep 2006
    I am having difficulty dealing with the bit 5 and 6 of the hours..
    using the subroutine add hours:
    I have 11 with bi6 and bit = 0
    click on addhour, brings me at hour 32 with bit 6 = 0 and bit 5 = 1
    pause 200
    if PortC.6=1 then
    rtcAMPM = RTCHour.5
    ' lcdout $FE,1, "RTCH1: ", bin RTCHour
    ' lcdout $FE,$C0, "BCDR: ", dec BCDResult
    ' pause 2000
    ' hourmode = 1
    BCDResult = RTCHour
    gosub Bcd2Dec
    Pause 2
    BCDResult_temp = BCDResult
    gosub Dec2Bcd
    RTCHour = BCDResult
    if BCDResult_temp > 12 then RTCHour.5 = 1
    elseif hourmode = 1 then ' this is 12H mode 0H to 12H
    ' hourmode = 0
    BCDResult = RTCHour
    ' pause 2000
    gosub Bcd2Dec
    BCDResult = BCDResult + 1 ' in decimal
    if BCDResult > 12 then BCDResult = 1
    Pause 2
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    ' pause 2000
    Sep 2006
    Concerning your table:
    With 12Hr 04PM $64 0110 0100 100
    Without 12Hr 04PM $4 0000 0100 4
    what do you mean with or without ? the AM PM bit ?? because bit 6 is a 1 on the first line, a one means 24H mode, you have 12H showing. What am I not getting ???
    Jan 2013
    Texas USA
    Reading the DS1337 Datasheet if bit 6 is High (1) 12hr mode is selected. See snippet from the Datasheet below.
    "The DS1337 can be run in either 12-hour or 24-hour mode. Bit 6 of the hours register is defined as the 12- or 24-hour mode-select bit. When high, the 12-hour mode is selected."
    With or without refers to the need, when in 12Hr mode, to mask off(set to 0) BOTH the 12/24Hr and AM/PM bits when using LCDOUT, SEROUT, HSEROUT, etc ; and when changing the value of the Hours in your code to be written back to the RTC. Such as when you allow the user to change the time via buttons.
    With = Bits ARE NOT masked ( leads to errors)
    Without = Bits ARE masked
    Not performing these actions when needed during hour value manipulation and displaying the values will lead to incorrect settings in the RTC and visually strange clock display. E.g. 44 being displayed on the LCD instead of the expected 4 AM or 64 being displayed on the LCD instead of expected 4 PM.
    Last edited by Tabsoft; - 15th January 2015 at 05:44. Reason: Clarified with or without
    TABSoft
    Jan 2013
    Texas USA
    Just for grins, try doing 2 successive writes to the RTC with a 10ms pause in between.
    I've ran into these kind of issues whenever the hours.6 bit is changed in the RTC.
    Do this when you 1st initialize the RTC on startup and every time you write to the RTC.
    The issue is when the 12/24hr mode bit is changed (hours.6).
    From the DS
    "All hours values, including the alarms, must be reinitialized whenever the 12/24-hour mode bit is changed."
    TABSoft
    Sep 2006
    Hello,
    I think I found the problem but I dont know how to get around it,
    I have bit 5 confusing me when in 24H mode. How do you remove it from calculation,
    The problem is this,
    You need to get only number between 20 and 23H used with bit 5.
    You also need to know what time you are now to do the calculation, at 18H hour you dont need it so RTCHour is 4 bits
    at 20H you need the 5 bits,
    So which and when to separate the two,... it seems to me like a chicken or egg issue.. which came first,, or in this case .. which to calculate first
    Jan 2013
    Texas USA
    The only time you should need to worry about bit 5 is when bit 6 = 1 (12 hour mode).
    When bit 6 = 0 (24 hour mode) you do not have to remove or mess with bit 5. Bit 5 is part of the number [B]not[B] an am/pm bit.
    24Hr mode
    Time is 11:00 hours, hours = %00010001 notice bit 5 is a zero which means the 2nd 10s is clear, and bit 4 (1st 10s) is a one which is set.
    Time is 21:00 hours, hours = %00100001 notice bit 5 is a one which means the 2nd 10s is set, and bit 4 (1st 10s) is zero which is clear.
    TABSoft
    Jan 2013
    Texas USA
    Try removing or commenting out the following line from your ADDHour routine within the "if hourmode = 0" block (24 hour mode)
    TABSoft
    Sep 2006
    Hi again,
    here is you example with different hours..
    24Hr mode
    Time is 23:00 hours, hours = %00100110 notice bit 5 is a one
    add 1 to 23
    Time is 00:00 hours, hours = %00000000 notice bit 5 is zero
    SO the bit 5 does changes int he 24H mode...
    maybe i'm still not seeing it good..
    Sep 2006
    HooHoo ! , got it all working now.
    Ya bit 5 was a bit confusing,
    thanks a million for your time
    Jan 2013
    Texas USA
    Great! Glad to help.
    The hour register of the RTC can be a bit confusing with its mix of hour mode and am/pm options/values.
    When I did this a while back I created a spreadsheet to to visual all of the possible values and how to deal with them.
    How about posting your final code so the readers can see your final solution?
    TABSoft
    Sep 2006
    Here you go :
    '// Using the PIC16F886
    '// AM PM mode
    '// Increment Hour and Minutes
    '// Output to LCD 2x16
    '// Define section //
    Define OSC 8
    CM1CON0.7 = 0
    CM2CON0.7 = 0
    DEFINE CCP1_BIT 2
    Pause 20
    TrisB= 0
    TrisA= 0
    TrisC=%1110000
    tmp var byte
    pkt var byte[11]
    RTCHour var byte
    RTCMin var byte
    RTCSec var byte
    'The DS1337 can be run in either 12-hour or 24-hour mode. Bit 6 of the hours register is defined as the 12- or 24-
    'hour mode-select bit. When high, the 12-hour mode is selected. In the 12-hour mode, bit 5 is the AM/PM bit with
    'logic high being PM. In the 24-hour mode, bit 5 is the second 10-hour bit (20–23 hours).
    'The only time you should need to worry about bit 5 is when bit 6 = 1 (12 hour mode).
    ansel=0 'dig i/o
    trisc=%1110000
    'i2cwrite sdapin,sclpin,$D0,0,[$0,$14,$18,3,$14,1,$14] ' TIME AND DATE
    pause 10
    Gosub gethour
    if PortC.6 then gosub ADDHour
    if PortC.5 then gosub ADDMin
    Gethour:
    RTCHour = pkt[2]
    if RTCHour.6 then ' this is HIGH, therfore 12H mode
    lcdout $fe,1,"Time=", hex2 (pkt[2]& %00011111),":",hex2 pkt[1],":",hex2 pkt[0] 'bit 0=sec, bit 1=min, bit 2=hrs
    if RTCHour.5 then
    lcdout $fe,$c0, "pm:"' ,bin RTCHOUR.6,":", Bin RTCHOUR.5,":", bin RTCHOUR
    lcdout $fe,$c0, "am:"' ,bin RTCHOUR.6,":", Bin RTCHOUR.5,":", bin RTCHOUR
    lcdout $fe,1,"Time2=", hex2 pkt[2],":",hex2 pkt[1],":",hex2 pkt[0]
    ' lcdout $fe,$c0, " :" ,bin RTCHOUR.6,":", Bin RTCHOUR.5,":", bin RTCHOUR
    ampm:
    BCDResult = RTCHour
    gosub Bcd2Dec
    hourmode = 1
    rtcAMPM = 1
    rtcAMPM = 0
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    pause 10
    pause 10
    Bcd2Dec:
    Dec2Bcd:
    pause 200
    if PortC.6=1 then
    RTCHour = pkt[2]
    rtcAMPM = RTCHour.5
    '////////Selection Begins here
    if hourmode = 0 then ' this is 24H mode 0H to 23H and bit 5 is used to calculate hours
    RTCHour = RTCHour & $3F ' keeping the bit 5
    BCDResult = RTCHour
    gosub Bcd2Dec
    BCDResult = 0
    ' hourmode = 1
    rtcAMPM=0
    if BCDResult > 19 then ' bit 5 is needed for the hours 20h to 23h
    rtcAMPM=1
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    pause 10
    pause 10
    RTCHour = RTCHour & %00011111 ' keeping the bit 5
    BCDResult = RTCHour
    gosub Bcd2Dec
    BCDResult = 1
    rtcAMPM = not rtcAMPM ' 0 is for the AM mode
    gosub Dec2Bcd
    RTCHour = BCDResult
    RTCHour.5 = rtcAMPM
    pause 10
    pause 10
    pause 200
    if PortC.5=1 then
    BCDResult = RTCMin
    gosub Bcd2Dec
    Pause 2
    gosub Dec2Bcd
    RTCMin = BCDResult
  1. 12H format setting for DS1307
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2010, 08:34
  2. example code for DS1337
    Last Post: - 8th December 2009, 22:16
  3. Code for DS1337
    By Fernanda in forum Off Topic
    Last Post: - 21st July 2008, 21:18
  4. PBPro for 16-bit PICs (24F/24H/DSPICs)?
    By Sergeant in forum mel PIC BASIC Pro
    Last Post: - 20th April 2007, 21:18
  5. DS1337 Problem
    By snow in forum mel PIC BASIC Pro
    Last Post: - 9th January 2005, 13:17
