OT: EEPROM setup in MPLAB ???
Results 1 to 5 of 5
    Aug 2003
    Default OT: EEPROM setup in MPLAB ???
    Hi Guys,
    I'm having a little trouble with the initial setup of a 12c serial eeprom
    in MPLAB. I've tried this:
    org (1 *256) ; block = 1
    DT b'00101100' ; 2c
    DT b'10101010' ; aa
    DT b'00000100' ; 04
    DT b'11001100' ; cc
    DT b'00011101' ; 1d
    DT b'01010010' ; 52
    DT b'10011000' ; 98
    DT b'01010011' ; 53 ..... and so on
    But when compiling it, I get
    "Undefined processor type" messages for every line.
    I could enter these values manualy into the pic programmer window,
    but I'm sure MPLAB can do it since there is provision to select eeproms
    as a processor type when creating new projects.
    Any ideas??
    Cheers, Art.
    I really want to help you but i'm really not sure of what you want to do so, could you give more details... wich EEPROM or PIC you want to program /edit.
    Aug 2003
    I've got a 24LC65B in this case, and I have pic routines that can read and
    write to I2C EEPROMS, but I have data to program to the EEPROM initialy
    so that the data on it can be used by the pic at run time.
    short version:
    I have a big table of values that I need to make a 24LC65 hex file out of using MPLAB.
    in this case MPLAB can't help you. You need a EEPROM programmer/reader like Elnec, BKPrecision or else. There's some free stuff and easy to build like IC-Prog or Pony Prog with SI interface or JDM.
    Free softwares:
    Pony Prog: http://www.lancos.com/prog.html
    IC-Prog:http://www.ic-prog.com/index1.htm
    SI interface :
    http://www.lancos.com/siprogsch.html
    JDM interface :
    OR, still use IC-Prog or Pony-Prog software to edit your EEPROM dump, use your PC to send the whole EEPROM dump to your PIC, then from your PIC to your EEPROM. In this case, some VB or else PC LANGUAGE knowledge are needed.
    Aug 2003
    Bummer,
    Funny how some seriasl eeproms are listed as devices in older vers of MPLAB.
    I think the next easiest approach without PC programming is to send the
    table out of a PC serial port with hyperterm to a pic who's sole job it is
    to listen for data and write the eeprom.
  1. Can't read sequential addresses in external EEPROM
    Last Post: - 18th February 2010, 14:46
  2. Problem with I2C EEPROM addressing
    By Atom058 in forum General
    Last Post: - 3rd November 2009, 03:17
  3. MPLAB / EEPROM Question
    By Art in forum General
    Last Post: - 14th April 2008, 06:16
  4. How to write/read strings EEPROM/LCD
    By g-hoot in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 06:26
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 19:59
