Computer Display?
Results 1 to 30 of 30
    Default Re: Computer Display?
    Do you have VERY large speakers near your desk? Or possibly industrial power cables?
    (just a silly idea)
    Mar 2011
    Los Angeles, California
    Hi Robert!
    Not silly, great idea and no, no big speakers as I also worked with a digital compass and try to stay with only brass for everything including the pressure sensor. Once in a great while aluminum which is difficult to solder! Yes, there is aluminum solder and it takes a lot of heat. Typically I take the aluminum soldering rods and cut them down so they are thinner than what I am trying to solder. While the specs for the TXB0104 states it can handle upto a 70nf (.07mf) load there is some other factor. Another problem was with my code. I had a "gosub" that should have been a "goto" which fixed a lot of issues. I have not tried longer cable lenght(s) again, just working with short lenghts.
    What I would really love to know is what code to use and what the code would look like so I can run the PIC at full speed and not delayed using ICD to see the parameters. Maybe assign some pins to feed a MAX232 and use hyperterminal or similar? Second, I know this is probably been asked a million times and is there a simple way to tell at what speed the code is really running?
    So many questions, so little time!
    Best to all, Ed
  1. Two Versions of MPASM in the Same Computer???
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 11th July 2011, 21:24
  2. PIC16F877A interface with computer
    By jonil22 in forum Serial
    Last Post: - 19th February 2008, 21:29
  3. Computer crash and PBP V2.45
    Last Post: - 24th January 2008, 21:57
  4. Some HID devcie on one computer
    By Shamir in forum USB
    Last Post: - 19th February 2007, 07:52
  5. read signal from computer
    By menhwa in forum Serial
    Last Post: - 18th February 2006, 05:28
