Computer Display?
Results 1 to 30 of 30
    Mar 2011
    Los Angeles, California
    Default Re: Computer Display?
    Hi All!
    Basically the sensor goes into a TXB0104 at 3v and from the TXB0104 at 5v into the PIC. I have been trying to extend the 5v side from the TXB0104 to/from the PIC with Shiftin and Shiftout. This has clearly been a problem for others after several hours of searching the internet and no one seems to have published a solution. From the PIC 18F1320 through a MAX232CPE into Com1 using the ICD in PicBasic Pro you can see all the readings. While very difficult to do I did manage to place a 47mfd tant. cap to the back of the sensor so it could not be any closer/shorter! Attached is the drawing. Ed
    Hi Ed,
    Personally I would not trust the 3.3V power supply setup you've got going there. The current consumption of both the sensor and the "A-side" of the TXB0104 will most likely not be constant meaning the voltage drop across that resistive divider will change resulting in an unstable 3.3V supply rail. Now, the cap you fitted obviously will help but I still don't think it's good solution. I'm not saying it will fix your issue but I would at least try with a proper 3.3V supply for the sensor and the A-side of the TXB0104 - at least to rule it out.
    Also, make sure you have a decoupling capacitor on the VccB pin of the TXB0104. As you extend the cable length the capacitance of the cable increases, that capacitance will need to be charged and discharged by the driver circuitry in the TXP0104. It'll need proper decoupling.
    Are you generating the 32.768Hz clock for the sensor with the CCP module in the PIC?
    Apr 2011
    Parallel a 0.1uF capacitor across the 47uF. Whilst the 10k pot to derive the 3V supply is very crude you show no decoupling of the 5V supply itself or the attached ICs - all of which are required.
    The data lines to the PIC should be via twisted pair and, if necessary, decoupled to ground themselves.
    Dec 2010
    Quote Originally Posted by kellyseye View Post
    Good advice on decoupling 5V, but not good advice about adding 0.1 uF across the 47 uF. In some instances, for example using a large electrolytic capacitor with high ESR/ESL this could help with high frequency noise, however tantalum devices are likely as good as the ceramic in this case, so this will not do anything useful and will drive you crazy trying to solder it on. Worse, in some cases, you could introduce instability with a second pole in the filter, so this approach should be used with caution. And adding caps to the data lines will reduce the range and degrade the signal - very bad idea. Also twisted pair will be more harmful than helpful in this instance, since the signal is unbalanced.
    Honestly, the problem is most likely the poor 3V supply - fix that before investing any time in other approaches.
    Mar 2011
    Hi All!
    First thank all of you for all the great information, ideas, and opinions which are highly valued! I did find 3.0 volt regulators (MCP1700-3002E/TO) I would like to ask the group thier opinions on the best approach to decoupling. There are two methods possible using proto type boards (the boards with all the holes). First is to take the power and ground leads and run them parallel at the top of the board and then add connections to the I.C.'s from these "rails". The catch is that pin 1 is + power and pin 7 is ground. Thus the connection to ground would be long. The second approach is to take the ground and make a "C" shape buss with heavy ground wire so that the grounds would be shorter. What would be the advantages /disadvantages to either approach and is one approach better than the other when it comes to I.C. power and power supply decoupling? Thanks, Ed
    Hi Ed,
    In your case I'd keep the GND connection as short as possible, the connection to the positive rail then becomes whatever length is required. Then place the decoupling capacitor right across the supply pins of the device or as close to the supply pins as you possible can.
    Mar 2011
    Hi Henrik!
    Thanks! One idea was to use 18ga buss wire for ground while 22ga for power. If I understand correctly then the negatives leads of the capacitors would be short and the positives would be long? Wouldn't this be allowing any spikes or signals to be on the positive supply rail? Thanks, Ed
  1. Two Versions of MPASM in the Same Computer???
    By rsocor01 in forum mel PIC BASIC Pro
    Last Post: - 11th July 2011, 20:24
  2. PIC16F877A interface with computer
    By jonil22 in forum Serial
    Last Post: - 19th February 2008, 20:29
  3. Computer crash and PBP V2.45
    Last Post: - 24th January 2008, 20:57
  4. Some HID devcie on one computer
    By Shamir in forum USB
    Last Post: - 19th February 2007, 06:52
  5. read signal from computer
    By menhwa in forum Serial
    Last Post: - 18th February 2006, 04:28
