If I have a statement like below:
The jump to the label Fail is executed as a Goto or a GoSub instruction at the end of the above statement in case I2C fails?Code:I2C_Routine: I2CWRITE SDA,SCL,$36,[Loc], Fail Return
I am trying to avoid stack errors, my code does a 'GoSub I2C_Routine', I will have a stack left un'RETURN'ed in case the fail is executed as a goto. What should I do in this case? I don't think I can put a return at the end of the Fail function in case it is a goto jump. I hope I made my question clear.
