RN41 Bluetooth Module
Results 1 to 4 of 4
    Default Re: RN41 Bluetooth Module
    been using for > 1 year, never skips a beat, uses SPP on PC.....serial port profile....... then just sends/receives serial data once 'paired'
    Don
    Sep 2005
    Hi Don,
    I have the unit working on the eval board, just going to hook it up to the UART of the PIC, just looks complicated hooking it up to a Micro considering what I had to do on the PC to get it all paired....do you have some set up code you could share?
    Gavin
    Hi Gavin,
    My 41 modules are a couple years old, so I don't know if the software has changed much....... but the UART part is pretty easy, just send/receive or serout/serin with standard UART polarity to and from your terminal program on PC. Have you used the " $$$ " command to view/change the parameters on the BT device over BT with hyperterm or other prog? You can set mode, Baud, device name, password etc.
    Don
  1. Bluetooth headset for non bluetooth devices?
    By Normnet in forum Bluetooth
    Last Post: - 26th September 2015, 12:22
  2. Bluetooth module for Ipod?
    By DanPBP in forum Bluetooth
    Last Post: - 10th October 2012, 17:16
  3. Bluetooth Module, SKKCA-21, Cytron
    By arson88 in forum Bluetooth
    Last Post: - 19th March 2012, 17:44
  4. Bluetooth module @ 3.3 volts
    By ardhuru in forum Bluetooth
    Last Post: - 22nd January 2012, 05:09
  5. What bluetooth module to choose?
    By mbox in forum mel PIC BASIC Pro
    Last Post: - 9th November 2009, 00:01
