Code check and refinement suggestions?
Results 1 to 24 of 24
    Dec 2005
    Salt Lake City, Ut, USA
    Default Code check and refinement suggestions?
    Hello all,
    Can you fine folks peruse my code to see if it's viable, and possibly offer suggestions for refinement.
    Thanks a ton,
    Chris
    '*  Name    : SIMPLE TACH.BAS                                                            *
    '*  Author  : Kevlar        *
    '*  Notice  : Copyright (c) 2012 Lightspeed Engineering                                  *
    '*          : All Rights Reserved                                                        *
    '*  Date    : 12/9/2012        *
    '*  Version : 1.0        *
    '*  Notes   : PIC16F1936 (on-chip vref)                                                  *
    @ ERRORLEVEL -230
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
    @ ERRORLEVEL -303   ; suppress Program word too large
    '                               PIC16F1936
    '                               -----U-----
    '   MCLR                E.3     |1      28|     B.7      PULSE INPUT
    '   OUT 2               A.0     |2      27|     B.6      LCD RS
    '   OUT 1               A.1     |3      26|     B.5      LCD E
    '   VREF-               A.2     |4      25|     B.4      LCD DB4
    '   150 VDC             A.3/AN3 |5      24|     B.3      LCD DB5
    '   OUT 3               A.4     |6      23|     B.2      LCD DB6
    '   50 AMPS             A.5/AN4 |7      22|     B.1      LCD DB7
    '   VSS                         |8      21|     B.0/AN12 LM34 TEMP (N/A in this design)
    '   OSC 1               A.7     |9      20|              VDD
    '   OSC 2               A.6     |10     19|              VSS
    '   Heartbeat LED       C.0     |11     18|     C.7      232 Rx
    '   GPIO 1              C.1     |12     17|     C.6      232 Tx
    '   GPIO 2              C.2     |13     16|     C.5      Tx LED
    '   GPIO 3, 1 WIRE IO   C.3     |14     15|     C.4      Rx LED
    '*********************************INCLUDES************************************************
    INCLUDE "DT_INTS-14.bas"        ' Base Interrupt System
    INCLUDE "ReEnterPBP.bas"        ' Include if using PBP interrupts
    '*********************************INTERRUPTS**********************************************
        INT_Handler    IOC_INT,     _PulseINT,   PBP,  yes
        INT_Handler   TMR1_INT,     _Overflow,   PBP,  yes
        INT_Handler     RX_INT,      _RS232in,   PBP,  yes
    '**********************************ENABLE INTS********************************************
    @ INT_ENABLE  IOC_INT             ; enable Port B Change interrupts
    @ INT_ENABLE  TMR1_INT            ; enable Timer 1 interrupts
    @ INT_ENABLE  RX_INT              ; enable 232 Rx interrupts
    '*********************************OSCILLATOR**********************************************
    DEFINE OSC 20                   ' Change these to match your Hardware
    '*********************************TIMER1**************************************************
    Preload  var word
    preload  = 3036      '(Preload for 100mS Interrupts)
    TimerOn  con 49
    TimerOff con 48
    T1CON    = TimerOff  '7=GateInv,6=GateEn,5-4=Prescale(8),3=LPosc,2=T1Sync,1=ClkSrc,0=TmrON
    TMR1H    = preload.highbyte'preload.HIGHBYTE
    TMR1L    = Preload.lowbyte 'preload.LOWBYTE
    '*********************************USART***************************************************
    DEFINE HSER_RCSTA 90h           ' Enable serial port & continuous receive
    DEFINE HSER_TXSTA 24h           ' Enable transmit, BRGH = 1
    DEFINE HSER_CLROERR 1           ' Clear overflow automatically
    DEFINE HSER_SPBRG 86            ' 57600 Baud @ 20MHz, -0.22%
    SPBRGH = 0
    BAUDCON.3 = 1                   ' Enable 16 bit baudrate generator
    '*********************************LCD*****************************************************
    DEFINE  LCD4X20  1
    LCD_DB4 VAR PORTB.4
    LCD_DB5 VAR PORTB.3
    LCD_DB6 VAR PORTB.2
    LCD_DB7 VAR PORTB.1
    LCD_RS VAR PORTB.6
    LCD_E VAR PORTB.5
    LCD_Lines CON 2                 ' use "2" for 4 lines)
    LCD_DATAUS CON 50
    LCD_COMMANDUS CON 2000
    INCLUDE "LCD_AnyPin.pbp"        ' Will NOT compile without a "LCDOUT" command
    Line1 con 2                     'LCD Line 1
    Line2 con 192                   'LCD Line 2
    Line3 con 148                   'LCD Line 3
    Line4 con 212                   'LCD Line 4
    '*********************************PINS & ALIASES******************************************
    HrtbtLED    var PORTC.0         'Active LOW
    Rx232       var PORTC.7
    Tx232       var PORTC.6
    INVOLT      VAR PORTA.3
    INTEMP      VAR PORTB.0
    INAMPS      VAR PORTA.5
    OUT1        VAR PORTA.1         'Active HIGH
    OUT2        VAR PORTA.0         'Active HIGH
    OUT3        VAR PORTA.4         'Active HIGH
    INDEX       VAR PORTB.7
    GPIO1       VAR PORTC.1
    GPIO2       VAR PORTC.2
    GPIO3       VAR PORTC.3
    RxLED       var PORTC.4         'Active LOW
    TxLED       var PORTC.5         'Active LOW
    '*********************************REGISTERS***********************************************
    TRISA  = %11101000      '7=Osc1,6=Osc2,5=AN4(AMPS),4=OUT3,3=AN2(VOLTS),2=VREF-,1=OUT1,0=OUT2
    TRISB  = %10000001      '7=INDEX INPUT,6=LCDrs,5=LCDe,4=LCDd4,3=LCDd5,2=LCDd6,1=LCDd7,0=AN12(TEMP)
    TRISC  = %10000000      '7=Rx232,6=Tx232,5=TxLED,4=RxLED,3=GPIO3,2=GPIO2,1=GPIO1,0=HrtbtLED
    ANSELA = %00011000      '7=N/A,6=N/A,5=AN5,4=AN4(AMPS),3=AN3(VOLTS),2=AN2,1=AN1,0=AN0
    ANSELB = %00000001      '7=N/A,6=N/A,5=AN13,4=AN11,3=AN9,2=AN8,1=AN10,0=AN12(TEMP)
    IOCBP  = %10000000      '7=PULSE INPUT
    FVRCON = %11000010      '7=FVR On,6=FVR Ready,5=Temp En,4=Temp Range,3-2=Comp/DAC On,1-0=ADC Ref (2.048)
    ADCON1 = %10100011      '7=Right Justify,6-4=Fosc,3=N/A,2=ADC Ref-,1-0=ADC Ref+
    DEFINE ADC_BITS 10      'ADCIN resolution  (Bits)
    DEFINE ADC_CLOCK 2      'ADC clock source  (Fosc/32)
    DEFINE ADC_SAMPLEUS 11  'ADC sampling time (uSec)
    '*********************************VARIABLES***********************************************
    wsave   VAR BYTE    $70     SYSTEM      ' alternate save location for W
    'wsave1  VAR BYTE    $A0     SYSTEM      ' location for W if in bank1
    'wsave2  VAR BYTE    $120    SYSTEM      ' location for W if in bank2
    wsave3  VAR BYTE    $1A0    SYSTEM      ' location for W if in bank3
    PulseCNT  VAR WORD          'Pulse Count per 6 Timer1 Interrupts
    LoopCNT     con 5           'Count for ADC Averaging AND TIMER1 Overflows
    wTemp       var word        'Universal WORD Sized Variable
    Busy        VAR BIT         'One Wire Bus Busy Flag
    Volts       var word        'Actual Voltage
    VHolder     Var WORD
    VCurrentCNT var byte
    QVolts      con 1466        '150/1023=.1466, Ex: 750(ADVAL)*1466=1099500, Volts=DIV32 1000 (1099)
    Amps        var word
    AHolder     Var WORD
    ACurrentCNT var byte
    QAmps       con 489         '50/1023=.0489, Ex: 512(ADVAL)*489=250368, Amps=DIV32 1000 (250)
    TempC       var word
    TempF       var word
    R_Temp      VAR	WORD
    TempDigits  VAR BYTE
    Dummy       VAR BYTE
    RPM var word
    BufferJunk  VAR BYTE
    Address VAR byte                        ' byte var for module address
    SerialIn var byte
    CmdAddress var byte                     ' commanded address
    CmdPrefix var byte
    CmdOutput var byte                      ' commanded output
    Command var byte                        ' will hold "Q" or "O"
    EEPromLoc VAR byte
    TripVal Var byte
    ReReadVals Var bit
    OvflReadNow con 6
    OvflCNT var byte
    TripVoltsLow1 var byte      'EEProm Location 10
    TripVoltsHigh1 var byte     'EEProm Location 11
    TripTempLow1 var byte       'EEProm Location 12
    TripTempHigh1 var byte      'EEProm Location 13
    TripAmpsLow1 var byte       'EEProm Location 14
    TripAmpsHigh1 var byte      'EEProm Location 15
    TripVoltsLow2 var byte      'EEProm Location 20
    TripVoltsHigh2 var byte     'EEProm Location 21
    TripTempLow2 var byte       'EEProm Location 22
    TripTempHigh2 var byte      'EEProm Location 23
    TripAmpsLow2 var byte       'EEProm Location 24
    TripAmpsHigh2 var byte      'EEProm Location 25
    TripVoltsLow3 var byte      'EEProm Location 30
    TripVoltsHigh3 var byte     'EEProm Location 31
    TripTempLow3 var byte       'EEProm Location 32
    TripTempHigh3 var byte      'EEProm Location 33
    TripAmpsLow3 var byte       'EEProm Location 34
    TripAmpsHigh3 var byte      'EEProm Location 35
    '**********************************EEPROM VALUES******************************************
    EEPROM 10,[0]
    EEPROM 12,[0]
    EEPROM 14,[0]
    EEPROM 20,[0]
    EEPROM 22,[0]
    EEPROM 24,[0]
    EEPROM 30,[0]
    EEPROM 32,[0]
    EEPROM 34,[0]
    '*********************************Initialize Variables************************************
    PulseCNT        = 0
    VCurrentCNT     = 0
    VHolder         = 0
    ACurrentCNT     = 0
    AHolder         = 0
    OvflCNT         = 0
    '*********************************Code Goes Here First************************************
    ReadTripVals:
        read 10,TripVoltsLow1   'Default will be 0
        read 11,TripVoltsHIGH1  'Default will be 255
        read 12,TripTempLow1    'Default will be 0
        read 13,TripTempHigh1   'Default will be 255
        read 14,TripAmpsLow1    'Default will be 0
        read 15,TripAmpsHigh1   'Default will be 255
        read 20,TripVoltsLow2   'Default will be 0
        read 21,TripVoltsHIGH2  'Default will be 255
        read 22,TripTempLow2    'Default will be 0
        read 23,TripTempHigh2   'Default will be 255
        read 24,TripAmpsLow2    'Default will be 0
        read 25,TripAmpsHigh2   'Default will be 255
        read 30,TripVoltsLow3   'Default will be 0
        read 31,TripVoltsHigh3  'Default will be 255
        read 32,TripTempLow3    'Default will be 0
        read 33,TripTempHigh3   'Default will be 255
        read 34,TripAmpsLow3    'Default will be 0
        read 35,TripAmpsHigh3   'Default will be 255
        ReReadVals = 0
    T1CON   = timeron           'Timer ON
        if ReReadVals = 1 then      'If ANY Trip Values were changed,
            goto ReadTripVals       'reload ALL Trip Values
        GOSUB GetVoltage
        GOSUB GetTemp
        GOSUB GetCurrent
        '----------------------------VOLTAGE-------------------------------
        if (volts/10 < TripVoltsLow1) OR  (volts/10 < TripVoltsLow2) OR (volts/10 < TripVoltsLow3) then
            HIGH OUT1   'ON
            LOW OUT1    'OFF
        IF (VOLTS/10 > TRIPVOLTSHIGH1) OR (VOLTS/10 > TRIPVOLTSHIGH2) OR (VOLTS/10 > TRIPVOLTSHIGH3) THEN
            HIGH OUT1   'ON
            LOW OUT1    'OFF
        '----------------------------TEMPERATURE---------------------------
        if (tempf/100 < triptemplow1) OR (tempf/100 < triptemplow2) OR (tempf/100 < triptemplow3) then
            HIGH out2
            LOW OUT2
        if (tempf/100 > triptempHigh1) OR (tempf/100 > triptemphigh2) OR (tempf/100 > triptemphigh3) then
            high out2
            LOW OUT2
        '----------------------------AMPERAGE------------------------------
       if (amps/10 < tripampslow1) OR (amps/10 < tripampslow2) OR (amps/10 < tripampslow3) then
           HIGH out3
            LOW OUT3
       if (amps/10 > tripampshigh1) OR (amps/10 > tripampshigh2) OR (amps/10 > tripampshigh3) then
           High out3
            LOW OUT3
        LCDout $fe, 1   ' XXXXXXXXXXXXXXXXXXXX  <-- 20 DIGITS
            'Voltage Display
            If Volts = 0 then
                Lcdout $fe, LINE1, "VOLTAGE:       0.0 V"
            if (Volts > 0) AND (Volts < 10) then
                Lcdout $fe, LINE1, "VOLTAGE:       0.",DEC Volts," V"
            if (Volts > 9) AND (Volts < 100) then
                Lcdout $fe, LINE1, "VOLTAGE:       ",DEC Volts DIG 1,".",DEC Volts DIG 0," V"
            if (Volts > 99) AND (Volts < 1000) then
                Lcdout $fe, LINE1, "VOLTAGE:      ",DEC Volts DIG 2,DEC Volts DIG 1,".",DEC Volts DIG 0," V"
            if Volts > 1000 then
                Lcdout $fe, LINE1, "VOLTAGE:     ",DEC Volts DIG 3,DEC Volts DIG 2,DEC Volts DIG 1,".",DEC Volts DIG 0," V"
            'Temperature Display
            If TempF < 10000 then
                Lcdout $fe, LINE2, "TEMP   :     ",DEC TempF DIG 3,DEC TempF DIG 2,".",DEC2 TempF," F"
            If TempF > 9999 then
                Lcdout $fe, LINE2, "TEMP   :    ",DEC TempF DIG 4,DEC TempF DIG 3,DEC TempF DIG 2,".",DEC2 TempF," F"
            'Current Display
            If Amps = 0 then
                Lcdout $fe, LINE3, "CURRENT:       0.0 A"
            if (Amps > 0) AND (Amps < 10) then
                Lcdout $fe, LINE3, "CURRENT:       0.",DEC Amps," A"
            if (Amps > 9) AND (Amps < 100) then
                Lcdout $fe, LINE3, "CURRENT:       ",DEC Amps DIG 1,".",DEC Amps DIG 0," A"
                Lcdout $fe, LINE3, "CURRENT:      ",DEC Amps DIG 2,DEC Amps DIG 1,".",DEC Amps DIG 0," A"
            'RPM Display
            If RPM = 0 then
                Lcdout $fe, LINE4, "RPM    :         0 R"
            if (RPM > 0) AND (RPM < 10) then
                Lcdout $fe, LINE4, "RPM    :         ",DEC RPM," R"
            if (RPM > 9) AND (RPM < 100) then
                Lcdout $fe, LINE4, "RPM    :        ",DEC2 RPM," R"
            if (RPM > 99) AND (RPM < 1000) then
                Lcdout $fe, LINE4, "RPM    :       ",DEC3 RPM," R"
            if RPM > 1000 then
                Lcdout $fe, LINE4, "RPM    :      ",DEC4 RPM," R"
    '************************************VOLTAGE SUB******************************************
    GetVoltage:
        'VOLTAGE TO BE FED THROUGH A 73.25:1 SCALER
        '150vdc / 73.25 = 2.0477vdc
        VCurrentCNT = VCurrentCNT + 1
        if VCurrentCNT > LoopCNT then
            Volts = VHolder / LoopCNT   '5453 / 5 = 1090
            VCurrentCNT = 0
            VHolder = 0
            ADCON0 = %10001111      '7=N/A,6-2=Channel,1=Go/Done,0=Enable
            WHILE ADCON0.1
            WEND
       	    wTemp.HighByte = ADRESH
       	    wTemp.LowByte = ADRESL
       	    Dummy = wTemp * QVolts
       	    Volts = DIV32 1000          '1099   1095    1088    1075    1096
       	    VHolder = VHolder + Volts   '1099   2194    3282    4375    5453
    '************************************TEMPERATURE SUB**************************************
    GetTemp:
        OWOUT GPIO3, 1, [$CC, $44]                          'Skip ROM search & do temp conversion
        Wait_Up:
            OWIN GPIO3, 4, [Busy]                           'Read busy-bit
            IF Busy = 0 THEN Wait_Up                        'Still busy..?, Wait_Up..!
        OWOUT GPIO3, 1, [$CC, $BE]                          'Skip ROM search & read scratchpad memory
        OWIN GPIO3, 2, [R_Temp.Lowbyte, R_Temp.Highbyte]    'Read two bytes / end comms
        Dummy = 1125 * R_Temp                               '
        TempF = DIV32 100
        TempF = TempF + 3200
    '************************************CURRENT SUB******************************************
    GetCurrent:
        'CURRENT SHUNT = 75mV @ 50A
        'VOLTAGE TO BE AMPLIFIED WITH A MAX4460, GAIN SET AT ~27.3
        '~27.3 * .075 = 2.0475
        ACurrentCNT = ACurrentCNT + 1
        if ACurrentCNT > LoopCNT then
            Amps = AHolder / LoopCNT
            ACurrentCNT = 0
            AHolder = 0
            ADCON0 = %10010011      '7=N/A,6-2=Channel,1=Go/Done,0=Enable
            WHILE ADCON0.1
            WEND
       	    Dummy = wTemp * QAmps
       	    Amps = DIV32 1000
       	    AHolder = AHolder + Amps
    '************************************PULSE INTERRUPT**************************************
    PulseINT:
        PulseCNT = PulseCNT + 1
    '************************************TIMER INTERRUPT**************************************
    Overflow:
    @ INT_DISABLE IOC_INT
            T1CON   = timeroff
            OvflCNT = OvflCNT + 1
            if OvflCNT = OvflReadNow then                       '1 PulseCNT in .6 Seconds
                'Read PulseCNT                                  'f (RPS) = 1 / t
                'Calculate RPM                                  'f (RPS) = 1 / .6
                RPM = PulseCNT * 100                            'f (RPS) = 1.666666
                'Reset OvflCNT to 0                             'RPM = RPS * 60
                OvflCNT = 0                                     'RPM = 100
                'Reset PulseCNT to 0
                PulseCNT = 0
                toggle HrtbtLED                                 'On Off every 600 mS
            T1CON = timeron
    '***********************************SERIAL INTERRUPT**************************************
    RS232in:
    @ INT_DISABLE TMR1_INT
    @ INT_DISABLE RX_INT
        low RxLED   'Rx LED ON
        HSERIN [dec3 SerialIn]
        If SerialIn = 255 then gosub SetupModule
        while PIR1.5
            SerialIn = RCREG
        wend
        high RxLED  'Rx LED OFF
    @ INT_ENABLE RX_INT
    SetupModule:
    HSERIN [CmdPrefix,dec3 CmdAddress]
        select case CmdPrefix
            '-------------------------Address Module----------------------------
            case "A"
                Address = CmdAddress
                write 0,Address
                LOW TxLED
                    HSEROUT ["ACK:A",DEC3 Address,13,10]
                HIGH TxLED
                read 0,Address
            '-------------------------Command Module----------------------------
            case "B"
                '--------------------Address Mismatch--------------------------
                if CmdAddress <> Address then
                    goto Junk
                hserin[command]     'O, Q, or M
                select case command
                    case "O"    '(OUTPUT)
                        HSERIN[dec CmdOutput]   ' "CmdOutput" is holding 1,2 or 3
                        select case CmdOutput
                            case 1
                                toggle OUT1
                                pause 1500
                                toggle OUT1
                            case 2
                                toggle OUT2
                                pause 1500
                                toggle OUT2
                            case 3
                                toggle OUT3
                                pause 1500
                                toggle OUT3
                            CASE ELSE
                                goto Junk
                            END SELECT
                    Case "Q"                                                '(QUERY)    '$BxxxQ
                        low TxLED                                           'Tx LED ON
                        HSEROUT ["ACK:B",DEC3 Address,":",13,10,_           'Send Address First
                                 "VOLTS: ",DEC VOLTS,13,10,_                'VOLTS: 10500
                                 "TEMP: ",DEC TempF,13,10,_                 'TEMP: 102.4
                                 "CURRENT: ",DEC Amps,13,10]                'AMPS: 2350
                                TRISA  = %11111011                          'A.4=OUT3,A.1=OUT1,A.0=OUT2
                                HSEROUT ["OUTPUT 1: ",dec PORTA.1,13,10,_   'OUTPUT 1: 0
                                         "OUTPUT 2: ",DEC PORTA.0,13,10,_   'OUTPUT 2: 1
                                         "OUTPUT 3: ",DEC PORTA.4,13,10]    'OUTPUT 3: 1
                                TRISA  = %11101000                          'A.4=OUT3,A.1=OUT1,A.0=OUT2
                        high TxLED                                          'Tx LED OFF
                    Case "M"                                                '$B001 "M" 11025511255
                        'Output 1
                        '10=LowVolts, 11=HighVolts, 12=LowTemp, 13=HighTemp, 14=LowCurrent, 15=HighCurrent
                        'Output 2
                        '20=LowVolts, 21=HighVolts, 22=LowTemp, 23=HighTemp, 24=LowCurrent, 25=HighCurrent
                        'Output 3
                        '30=LowVolts, 31=HighVolts, 32=LowTemp, 33=HighTemp, 34=LowCurrent, 35=HighCurrent
                        'Output 4
                        '40=LowVolts, 41=HighVolts, 42=LowTemp, 43=HighTemp, 44=LowCurrent, 45=HighCurrent
                        '255B001                  Board Address
                        '       M                 Map
                        '        10               EEProm Location (Low Trip)
                        '          255            Low Trip Value
                        '             11          EEProm Location (High Trip)
                        '               255       High Trip Value
                        HSERIN[dec2 eepromloc]
                        HSERIN[dec3 tripval]
                        write eepromloc,tripval
                        ReReadVals = 1
                    case else
                        goto junk
                    end select
            end select
    Junk:
    Default Re: Code check and refinement suggestions?
    Chris
    An new feature in the upcoming update of FineLineIDE "Unused" finds:
    Label Ln 405: PulseINT:
    Label Ln 411: Overflow:
    Label Ln 433: RS232in:
    Norm
    Dec 2012
    Tennessee
    Your useing a 1936 chip, really too old. How about upgrading it to a 2013 one!
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Hi Chris,
    That's quite a bit of code to go thru but one thing I noticed is code like this (which you have 3 sets of):
            HIGH OUT1   'ON
            LOW OUT1    'OFF
            HIGH OUT1   'ON
            LOW OUT1    'OFF
    Here you're making the calculation volts/10 no less than 6 times even though the result will be the same each time. It would be more efficient from a speed and program memory point to do the calculation one time and using the result of that calculation.
    More, HIGH/LOW are convenient commands but if have your TRIS-registers set correctly (and I think you have) you might as well do OUT1 = 1 or OUT1 = 0 etc, that's also more efficient both in execution time and program space.
    The display routine (or part of it):
            'Voltage Display
            If Volts = 0 then
    Here you are storing the string VOLTAGE: in program memory 5 times. It would be more effecient to first print out VOLTAGE: and then, depending on the value of Volts, print the rest. I also think that it can be optimzed quite a bit by using the modulo operator ( // ) instead of printing the individual digits like that but I'm not sure if you're achieving anything special by doing it the way you are. If Volts are in units of 0.1 volts (ie 1234 is 123.4V) then you could simply do
    LCDOUT $FE, 1
    LCDOUT $FE, LINE1, "Voltage: ", DEC3 Volts/10, ".", DEC Volts//10
    Well, that's a couple of ideas you might look into.
    Dec 2005
    Thank you a million Henrik,
    I can see all of your points. I'll work on those suggestions and further refine from there. BTW, I could not make heads or tails from the first two responses to this thread...I read them six times each and still felt like I had just entered the twilight zone ...but I sincerely appreciate your post and guidance.
    Thanks again,
    Chris
    Hi Chris,
    You're welcome.
    I think the other Chris (wdmagic) is just trying to be funny and I believe what Norm is saying is that you have a couple of labels which you aren't GOTO'ing or GOSUB'ing from anywhere in the code.
    However, FineLine (which is an IDE that Norm is developing) apparently isn't picking up on the fact that they ARE defined as interrupt handlers using DT-Ints and therefor ARE being "used".
    Even if they weren't "used" it wouldn't really matter - you can have a label at each and every line in the code if you wanted to, it won't take up any more space and it won't run any slower.
    I can see the unused feature in FineLine being good for finding variables which are declared but not used though.
    Keep it up!
    I think al the isr's need to end with @ INT_RETURN not return
    Definitely so, good catch!
    I think the ioc_int isr may need to reset its flag manually too , dt-ints can need some manual intervention for clearing ioc interrupt flags for some chips ,just ticking yes to clr the flag may not work . pays to read the data sheet
    I try to keep defines, registers, wsave and other critical stuff at the top.
    Dec 2005
    Thanks to all you guys,
    Fixed the Interrupt Returns, working on the LCD display routines and redundant math. Awesome suggestions!
    On the topic of the LCD routines, is this what you meant Henrik:
    Lcdout $fe, LINE1 + 15, DEC Volts/10,".",DEC Volts//10," V"
    That's for volts that are below 10...
    As far as post 2, I don't use Fineline so I wasn't aware of that caveat. Maybe I should check it out
    As far as post 3, I double checked the datasheet and I didn't see anywhere that it was originally designed for the W.O.P.R. computer, so I figured I was good
    Thanks again all,
    Chris
    Dec 2005
    Wow,
    With the refinements so far, I went from 4367 words used to 3153 words used! Happy, Happy, Happy
    Please let me know if I can put the code on a diet any further...
    Thanks guys
    Chris
    '*  Version : 1.0        *
    @ ERRORLEVEL -230
    '                               PIC16F1936
    '                               -----U-----
    Preload  var word
    TimerOn  con 49
    TimerOff con 48
    SPBRGH = 0
    DEFINE  LCD4X20  1
    LCD_DB4 VAR PORTB.4
    LCD_DB5 VAR PORTB.3
    LCD_DB6 VAR PORTB.2
    LCD_DB7 VAR PORTB.1
    LCD_RS VAR PORTB.6
    LCD_E VAR PORTB.5
    LCD_DATAUS CON 50
    Rx232       var PORTC.7
    Tx232       var PORTC.6
    INVOLT      VAR PORTA.3
    INTEMP      VAR PORTB.0
    INAMPS      VAR PORTA.5
    INDEX       VAR PORTB.7
    GPIO1       VAR PORTC.1
    GPIO2       VAR PORTC.2
    GPIO3       VAR PORTC.3
    CompareVolts var byte
    VHolder     Var WORD
    Amps        var word
    CompareAmps var byte
    AHolder     Var WORD
    TempC       var word
    TempF       var word
    CompareTemp var byte
    R_Temp      VAR	WORD
    TempDigits  VAR BYTE
    Dummy       VAR BYTE
    RPM var word
    BufferJunk  VAR BYTE
    SerialIn var byte
    CmdPrefix var byte
    EEPromLoc VAR byte
    TripVal Var byte
    ReReadVals Var bit
    OvflReadNow con 6
    OvflCNT var byte
    EEPROM 10,[0]
    EEPROM 12,[0]
    EEPROM 14,[0]
    EEPROM 20,[0]
    EEPROM 22,[0]
    EEPROM 24,[0]
    EEPROM 30,[0]
    EEPROM 32,[0]
    EEPROM 34,[0]
    PulseCNT        = 0
    VCurrentCNT     = 0
    VHolder         = 0
    ACurrentCNT     = 0
    AHolder         = 0
    OvflCNT         = 0
    'Assign LCD static chars
    LCDout $fe, 1      'XXXXXXXXXXXXXXXXXXXX  <-- 20 DIGITS
    Lcdout $fe, LINE1, "VOLTAGE:"
    Lcdout $fe, LINE2, "TEMP   :"
    Lcdout $fe, LINE3, "CURRENT:"
    Lcdout $fe, LINE4, "RPM    :"
    ReadTripVals:
        ReReadVals = 0
            T1CON   = timeroff
        GOSUB GetVoltage
        GOSUB GetTemp
        GOSUB GetCurrent
        if (CompareVolts < TripVoltsLow1) OR  (CompareVolts < TripVoltsLow2) OR (CompareVolts < TripVoltsLow3) then
            OUT1 = 1    'ON
            OUT1 = 0    'OFF
        IF (CompareVolts > TRIPVOLTSHIGH1) OR (CompareVolts > TRIPVOLTSHIGH2) OR (CompareVolts > TRIPVOLTSHIGH3) THEN
            OUT1 = 1    'ON
            OUT1 = 0    'OFF
        if (CompareTemp < triptemplow1) OR (CompareTemp < triptemplow2) OR (CompareTemp < triptemplow3) then
            OUT2 = 1
            OUT2 = 0
        if (CompareTemp > triptempHigh1) OR (CompareTemp > triptemphigh2) OR (CompareTemp > triptemphigh3) then
            OUT2 = 1
            OUT2 = 0
       if (CompareAmps < tripampslow1) OR (CompareAmps < tripampslow2) OR (CompareAmps < tripampslow3) then
            OUT3 = 1
            OUT3 = 0
       if (CompareAmps > tripampshigh1) OR (CompareAmps > tripampshigh2) OR (CompareAmps > tripampshigh3) then
            OUT3 = 1
            OUT3 = 0
            'Voltage Display
            if Volts < 100 then                         '+15
                Lcdout $fe, LINE1 + 13,"  ", DEC Volts/10,".",DEC Volts//10," V"
            if (Volts > 99) AND (Volts < 1000) then     '+14
                Lcdout $fe, LINE1 + 13," ", DEC2 Volts/10,".",DEC Volts//10," V"
            if Volts > 1000 then                        '+13
                Lcdout $fe, LINE1 + 13, DEC3 Volts/10,".",DEC Volts//10," V"
            If TempF < 10000 then                       '+13
                Lcdout $fe, LINE2 + 12," ", DEC2 TempF/100,".",DEC2 TempF//100," F"
            If TempF > 9999 then                        '+12
                Lcdout $fe, LINE2 + 12, DEC3 TempF/100,".",DEC2 TempF//100," F"
            'Current Display
            if Amps < 100 then                          '+15
                Lcdout $fe, LINE3 + 14," ", DEC Amps/10,".",DEC Amps//10," A"
                Lcdout $fe, LINE3 + 14, DEC2 Amps/10,".",DEC Amps//10," A"
            'RPM Display
            if RPM < 1000 then                  '+15
                Lcdout $fe, LINE4 + 14," ", DEC3 RPM," R"
            if RPM > 1000 then                  '+14
                Lcdout $fe, LINE4 + 14, DEC4 RPM," R"
    GetVoltage:
            CompareVolts = Volts / 10
            VCurrentCNT = 0
            VHolder = 0
            WHILE ADCON0.1
            WEND
    GetTemp:
        Wait_Up:
        TempF = DIV32 100
        CompareTemp = tempf/100
    GetCurrent:
            CompareAmps = amps/10
            ACurrentCNT = 0
            AHolder = 0
            WHILE ADCON0.1
            WEND
       	    Amps = DIV32 1000
    PulseINT:
        IOCBF.7 = 0
    @ INT_RETURN
    Overflow:
            T1CON   = timeroff
                PulseCNT = 0
            T1CON = timeron
    @ INT_RETURN
    RS232in:
        while PIR1.5
            SerialIn = RCREG
        wend
    @ INT_ENABLE RX_INT
    @ INT_RETURN
    SetupModule:
            case "A"
                write 0,Address
                LOW TxLED
                HIGH TxLED
                read 0,Address
            case "B"
                    goto Junk
                select case command
                    case "O"    '(OUTPUT)
                            case 1
                                toggle OUT1
                                pause 1500
                                toggle OUT1
                            case 2
                                toggle OUT2
                                pause 1500
                                toggle OUT2
                            case 3
                                toggle OUT3
                                pause 1500
                                toggle OUT3
                            CASE ELSE
                                goto Junk
                            END SELECT
                        'Output 1
                        'Output 2
                        'Output 3
                        'Output 4
                        '       M                 Map
                        ReReadVals = 1
                    case else
                        goto junk
                    end select
            end select
    Junk:
    Dec 2005
    Doh, I spoke too soon! I can't believe I missed the WOPR Register
    Dec 2012
    Tennessee
    I just add 3-5 spaces at the end of my strings so any leftover characters are replaced with a space. I did have some code that forced a specific number of characters for a number so 123.5 would be displayed as that, however 57.1 would be displayed as 057.1, therefore no change in character location is needed. if I can find my code Ill post it. you might search for leading 0's? dont know. henrik or one of the other mods may help with this too.
    Chris
    Yes, if you want (or don't but can live with) leading zeros then use DEC3 (or DEC2, DEC4 etc) to specify the number of digits with which the number will be displayed. In Chris's case he's trying to right justify the displayed number (without leading zeros) so he's determining the number of digits in the number and then prints "leading spaces" to erases what ever might be there from before. Again - whatever works.
    Sep 2010
    Las Vegas, NV
    An approach I've used for adding ICSP on a thru hole project where one isn't installed is to solder the important leads ICSPDAT, ICSPCLK and MCLR to a socket that will go between the the chip and the circuit card. As long as the circuit won't inhibit the loading because of a lowish resistance on clk or data you can install this temporarily and remove it when you're finished. Though I've yet to figure out a work around for surface mount projects.
    I've learned it isn't much more expensive to add the ICSP header and a switch to isolate the chip when needed for loading a program. I know this approach isn't possible in all instances but if you've got the space why not use it.
    Finally I want to thank you guys for helping out Kevlar and explaining why your code helps/is faster/more accurate. Exactly what I need to improve my capabilities.
    Dec 2005
    Thanks WD, Henrik and Avionics,
    I was pondering the leading zero method, which certainly is not a deal breaker for me...I just thought it would be sexier to right justify If I find a need for a tad more speed, I'll definitely use leading zeros. On the ICSP thing, I think I might modify my board to have it. I think my short term pain in changing the etch would pay off well in the long term, which is usually the case in life isn't it... Did you guys happen to have any thoughts on the RPM Sub? Another thing I noticed is, what are the odds that I may miss an encoder index pulse while inside the Timer ISR (because I disable the IOC Interrupt)? Are there any ways that I could safeguard against this situation, or should I sweat it? This will obviously be a more critical situation at low rpm...
    I can't thank you guys enough for your thoughts and willingness to help (Ditto what Avionics wrote ),
    Chris
    EDIT: Sorry Henrik, I completely missed your previous post in regards to the RPM thing. I thought about that A or B channels, which would be way more accurate...if I only knew how many PPR they are (way old proprietary Renco's from a ct scan machine). I suppose it would be pretty simple to whip up some code to count the pulses as I rotate the motor by hand...hmmmm.
    Last edited by kevlar129bp; - 30th July 2013 at 23:51. Reason: Missed Henrik's first reply
    from the data sheet
    "The ISR determines the source of the interrupt by
    polling the interrupt flag bits. The interrupt flag bits must
    be cleared before exiting the ISR to avoid repeated
    interrupts. Because the GIE bit is cleared, any interrupt
    that occurs while executing the ISR will be recorded
    through its interrupt flag, but will not cause the
    processor to redirect to the interrupt vector."
    therefore since your overflow routine is an isr the int_disable lines are redundant and just waste time .
    since position is not important to lose a pulse woud probably not matter
  1. Replies: 3
    Last Post: - 13th September 2008, 17:40
  2. Your Suggestions: Assembly code material?
    By dw_picbasic in forum General
    Last Post: - 2nd February 2007, 17:33
  3. Can some one please check my code out thanks
    By Jhdgkss in forum mel PIC BASIC Pro
    Last Post: - 10th February 2006, 08:19
  4. Pushbutton code routine suggestions?
    Last Post: - 3rd September 2005, 01:02
  5. Code check (sorry)
    By barkerben in forum General
    Last Post: - 30th November 2004, 15:54
