I2C CONFUSION, Help needed please
Results 1 to 40 of 43
    Default Re: I2C CONFUSION, Help needed please
    Did the above, no luck.
    Doesn't like it straight, giving it $37/$36 direct sends it to Fail1 routine. So write statement fails.
    Funny thing is that when it goes to Fail1, though there should be no output of data, IT does output some of the data. This looks like half the data compared to when cycle runs normally.
    The code only run once and then I reset the PIC to run it again, so though it won't make any effect resetting the values in the main loop, I still tried with no luck. I am losing hairs on my head because of this now.
    Nov 2007
    West Covina, CA
    Still Debugging after failing is strange. There is something else being introduced corrupting your instructions.
    Use the Addr variables and see what happens when it free runs:
    x VAR BYTE
    RD_Addr = $37
    WR_Addr = $36
    High Led : Pause 500: Low Led : PAUSE 500
        I2CWRITE SDA,SCL,WR_Addr,[LOC],Fail1
        I2CREAD SDA,SCL,RD_Addr,[VALUE] ,Fail2
        PAUSE 25
        DEBUG  Value,13,10
        PAUSE 250
        DEBUG "Done....",13,10
    WHILE 1 : WEND
    Goto Main
    Fail1:
    FOR x = 0 TO 10
        toggle portc.2 : pause 50
    NEXT x
    Fail2:
    FOR x = 0 TO 10
    	High Portc.2 : Pause 250 : Low PortC.2 : Pause 250
    NEXT x
    GOTO Main
    Going to church now, BBL
    Louie
    Is that Write only an initialisation?
    Shouldn't it be outside the Main loop?
    This is a Touch IC. So shouldn't you check the device ID once, then check at another address within the loop to detect a touch? (not sure of trigger yet)
    I'm dense, won't WHILE 1: WEND loop endlessly?
    Edit: I see it now; 1 to 7 keys max for I2C, triggers lines out.
    Also, looking in datasheet if it says 400kHz max. I think you might have to run fast.
    4.1.1 max 400kHz, so you should be able to run slower.
  1. Sample code for I2C text LCD needed
    By Alexey in forum Code Examples
    Last Post: - 15th September 2011, 02:29
  2. TMR0 Confusion
    Last Post: - 19th August 2011, 12:55
  3. HPWM confusion
    By lerameur in forum General
    Last Post: - 5th November 2006, 11:09
  4. HPWM confusion
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 17:50
  5. DIV32 confusion
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 22:24
