What if you assign the Read/Write addresses before hand?
Value Var BYTE
Addr Var byte
Loc Var Byte
Pause 500
DEBUG "Start......",13,10
Value=0
Loc=0
WR_Add CON $36
RD_Add CON $37
High Led : Pause 500: Low Led : PAUSE 500
'Addr=$36
I2CWRITE SDA,SCL,WR_Add,[LOC],Fail1
'Addr=$37 : pause 10 ' Sometimes it is failing, leaving pause 10 makes it better.
I2CREAD SDA,SCL,RD_Add,[VALUE] ,Fail2
PAUSE 25
DEBUG Value,13,10
PAUSE 250
DEBUG "Done....",13,10
WHILE 1 : WEND
Goto Main
Fail1:
while 1: toggle portc.2 : pause 50 : wend
Fail2:
WHILE 1
High Portc.2 : Pause 250 : Low PortC.2 : Pause 250
WEND
Question: Where is the "1" monitored at in these statements? Never seen it done this way before.
