I2C CONFUSION, Help needed please
Page 1 of 2 12 LastLast
Results 1 to 40 of 43
    Exclamation I2C CONFUSION, Help needed please
    I am trying to communicate with an I2C device. I have done almost everything I could think of but it is not working. The manual mentions stuff but not exactly matching with the datasheet of the device. The device datasheet mentions something about ACK/NACK which the pbp manual does not mention even once. On top my lack of understanding of I2C has left me with no other option to ask here about what I am doing wrong.
    What I have done:
    I have tried the following commands:
    Value var byte
    I2CREAD SDA,SCL,%000110100,0,[Value] ' Tried this
    I2CREAD SDA,SCL,$1B0,0,[Value] ' Tried this
    I2CREAD SDA,SCL,$1B,0,0,[Value] ' Tried this
    Then When I do this:
    debug HEX Value ' I am expecting '2E' on my screen. But I am not getting it.
    (Location Zero will read 2E in the device)
    I attach the section explaining the I2C from the datasheet. The device address is $1B.
    Many thanks in advance
    (Using 16F688 @ 4 MHz)
    Miami, Florida USA
    Default Re: I2C CONFUSION, Help needed please
    Did you put the two pull-up 4.7k resistors in the SDA and SCL lines?
    Anonymous
    Miami, Florida USA
    Also, you don't need to worry about anything that you highlighted in red. The I2CREAD and I2CWRITE commands take care of that for you.
    Anonymous
    Yes, pull ups are there @ 3.2k.
    I tried the statement : I2CREAD SDA,SCL,$1B,0,[VALUE] (is it correct? because I don't had any luck)
    My Code is this:
    Include "modedefs.bas"
    ifdef PM_USED
    device pic16F688, intrc_osc_noclkout, wdt_on, mclr_on, protect_off
    __config _XT_OSC & _WDT_OFF & _PWRTE_ON & _MCLRE_ON & _CP_ON & _CPD_ON & _BOD_ON & _IESO_ON & _FCMEN_ON
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 3
    DEFINE DEBUG_BAUD 2400
    DEFINE DEBUG_MODE 1
    DEFINE I2C_SLOW 1
    'DEFINE I2C_HOLD 1
    PORTA=0
    PORTC=0
    TRISA = %000100
    TRISC = %110000
    CMCON0 = 7
    ANSEL = 0
    OPTION_REG = 128
    INTCON=128
    Value Var word
    SCL Var PortC.5
    SDA Var PortC.4
    Change Var PortA.2
    LED Var PortC.0
    Pause 500
    DEBUG "Start......",13,10
    value=0
    High Led : Pause 1000: Low Led : PAUSE 1000
    I2CREAD SDA,SCL,$1B,0,[VALUE],Fail
    PAUSE 25
    DEBUG HEX Value,13,10
    PAUSE 250
    DEBUG "Done....",13,10
    Goto Main
    Fail:
    toggle portc.2
    PortC.2 keeps toggling along with normal LED.
    I have also attached the device datasheet. I really appreciate the help in this.
    From PBP manual about I2CREAD:
    "Constants should not be used for address..."
    Don't know if this can help.
    I added two bytes - Addr & Loc
    Addr=$1B
    Loc=0
    Sent - I2CREAD SDA,SCL,Addr,Loc,[Value],Fail
    No Luck
    What is also confusing me is the control byte in the manual, the device datasheet does not mention any control byte.
    I have an address $1B which I am sending as control and location in the device is being sent as Address according to the manual.
    May 2008
    Italy
    The device you are using is a fast mode device (400 khz) so you have to remove the "DEFINE I2C_SLOW 1" and very likely you have to increase your clock speed (4 MHz could be too slow). Also change the variable into byte (you are using word).
    Good luck
    Al.
    I thought I saw 9 bits used from control in the datasheet you linked.
    Maybe you're supposed to use a word and ignore the other 7 bits? Or that could be handled by PBP for I2C?
    Do you get only a byte back, word, multiple bytes?
    Your circuit does make address 0 right?
    (just throwing ideas at you)
    Steps Taken:
    1) Configuration changed: _INTRC_OSC_NOCLKOUT
    2) Made 16f688 run at 8MHz : OSCCON=%01110001
    3) Commented DEFINE I2CSLOW 1
    4) Value changed to BYte (then to word again)
    I get a byte back from the device (from what I have understood). Yes there is an address 0 in the device. I should get back chip ID i.e-'2E' as per the datasheet.
    Still no Luck.
    Nov 2007
    West Covina, CA
    I couldn't find detailed info on the Write/Read bit of the device address. But I will guess it is bit 7.
    You need to Write to the device first using the address with the "Write" bit set.
    $1B or %00011011 becomes $9B or $10011011
    Without confirming the proper syntax of the commands, here's something off the top of my noodle:
    This will cover steps 1~4 of Section 4.3.2 of the datasheet
    I2CWRITE SDA,SCL,[Addr,Loc,]  ' Addr plus Write bit = $9B
    This will cover steps 5~7 of Section 4.3.2 of the datasheet
    I2CREAD SDA,SCL,[Addr,Loc]   ' Addr plus Read bit = $1B
    Putting it together should get you moving in the right direction.
    Here's a note to myself that might come in handy too:
    Last edited by LinkMTech; - 27th July 2013 at 16:53. Reason: Added I2C screen shot notes
    Louie
    Tried this:
    Pause 500
    Value=0
    Addr=$9B
    Loc=0
    High Led : Pause 500: Low Led : PAUSE 500
    	I2CWRITE SDA,SCL,ADDR,LOC
    Addr=$1B : PAUSE 50
    	I2CREAD SDA,SCL,ADDR,LOC,[VALUE],Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Didn't worked. (Value/Addr/Loc = Byte size)
    Can I not the Micro at 4MHz? The Datasheet says MAX speed is 400KHz, so I assume lower speeds are supported. Am I right?
    Nov 2007
    West Covina, CA
    Remove the PAUSE 50 after I2CWRITE because the device starts sending immediately if its happy.
    Then try bit 6 then 5 instead for the Write bit if the Write bit position was a wrong guess.
    Bit 6 = $5B
    Bit 5 = $3B
    Louie
    Nov 2007
    West Covina, CA
    Yeah, 400kHz is the max speed so at 4MHz it will run closer to 100kHz
    Louie
    OSCCON changed to set 4MHz, internal oscillator.
    I2CSLOW 1 stays commented
    I2CHOLD 1 stays commented
    LED 	Var PortC.0
    Value Var 	Byte
    Addr	Var	Byte
    Loc 	Var	Byte
    Pause 500
    Value=0
    Addr=$9B 'Tried $3B,$5B
    Loc=0
    	Addr=$1B
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    No Luck
    > It is bit 7 for R/W (Slave address + write bit)
    Nov 2007
    West Covina, CA
    How did you find that?
    Louie
    Picked up from the datasheet of the device. That is what I understood, am I wrong?
    Though I did tried $3B & $5B.
    Nov 2007
    West Covina, CA
    Not sure if you're wrong or not. I'm still trying to decipher that part in the datasheet because they don't make it easy. I've found that some information has to be gleaned from other devices of the same manufacturer to put the whole story together, kinda sucks!
    I also noticed the address stays at $1B after the first loop in your test program and if it works you might miss it.
    Note: I just found one of my programs on another I2C device that has bit 1=0 as the Write bit.
    $1B = $00011011 used for Read
    $1A = $00011010 used for Write
    Louie
    I read it again to confirm this, the attachment is my source. It also mentions 9 bits long address. Not sure who sends an ack. I see that in read statement the device send ack, so why add it to the address PIC is sending. Very confusing.
    Nov 2007
    West Covina, CA
    Ahhhh... okay
    Let's use this info then. Looks like the address is using bits 1~7 and the Read/Write control bit is 0.
    If control bit is set (=1) then Read, if bit cleared (=0) then Write
    So:
    %00110111 = $37 ' Read function
    %00110110 = $36 ' Write function
    Try that.
    By the way, the device sends the ACK, or acknowledges, by holding the Data line LOW on the 9th clock cycle. The PIC will see this and continue to send data.
    Louie
    Quote Originally Posted by LinkMTech View Post
    How do I implement this, like this below?
    	Addr=$36
    	Addr=$37 : pause 10                    ' OR If SDA=1 then main
    	I2CREAD SDA,SCL,loc,[VALUE],Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Nov 2007
    West Covina, CA
    Just notice the address missing on the Read function.
    Moved the Fail label after Write to test this part first. This will let you know if the Write address was recognized so the Pause 10 is not needed.
    	Addr=$36
    	I2CWRITE SDA,SCL,ADDR,LOC, Fail  ' Test here first
    	Addr=$37 ': pause 10                    ' OR If SDA=1 then main
    	I2CREAD SDA,SCL,ADDR,loc,[VALUE] ',Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Louie
    Checked it. It fails on the first write statement.
    Fails on the second statement if I swap the values of Addr. i.e. First $37, second Addr $36. First one goes fine.
    Nov 2007
    West Covina, CA
    Okay let's fix that first.
    Put brackets around the Loc as shown in the PBP manual to see if that helps.
    	Addr=$36
    	I2CWRITE SDA,SCL,ADDR,[LOC],Fail  ' Test here first
    	I2CREAD SDA,SCL,ADDR,[LOC,VALUE] ',Fail
    	PAUSE 25
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail:
    	toggle portc.2
    Louie
    Default Reaching there
    I did exactly the same as above and the sequence completed fine. BUT the values are not consistent with the datasheet, I should get '$2E' from location 0, but WHATEVER location I try to read, I am getting '$FF'
    Default Update
    Have a look at my real term serial monitor. I am actually getting a lot of unexpected data which I don't understand how is getting stored in just one byte. Though among all this, I can see '2E' (but it is swapped around so 'E2'). Note sure if I am trying to convince myself or the data is rubbish.
    Default Re: Update
    Better in nibble setting. I can see '2E' repeated a few times.
    Nov 2007
    West Covina, CA
    Default Re: Update
    My bad, change the Read statement:
    I2CREAD SDA,SCL,ADDR,[VALUE] ',Fail
    Louie
    Still getting the same with the following code:
    Value Var 	BYTE
    Addr	Var	byte
    Loc 	Var	Byte
    Pause 500
    Value=0
    Loc=0
    	Addr=$36
    	I2CWRITE SDA,SCL,ADDR,[LOC],Fail1
    	Addr=$37 : pause 10 ' Sometimes it is failing, leaving pause 10 makes it better.
    	I2CREAD SDA,SCL,ADDR,[VALUE] ,Fail2
    	PAUSE 25
    	DEBUG  Value,13,10
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail1:
    while 1:	toggle portc.2 : pause 50 : wend
    Fail2:
    WHILE 1
    	High Portc.2 : Pause 250 : Low PortC.2 : Pause 250
    WEND
    Nov 2007
    West Covina, CA
    What if you assign the Read/Write addresses before hand?
    Value Var 	BYTE
    Addr	Var	byte
    Loc 	Var	Byte
    Pause 500
    Value=0
    Loc=0
    WR_Add CON $36
    RD_Add CON $37
    	'Addr=$36
    	I2CWRITE SDA,SCL,WR_Add,[LOC],Fail1
    	'Addr=$37 : pause 10 ' Sometimes it is failing, leaving pause 10 makes it better.
    	I2CREAD SDA,SCL,RD_Add,[VALUE] ,Fail2
    	PAUSE 25
    	DEBUG  Value,13,10
    	PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail1:
    Fail2:
    WHILE 1
    WEND
    Question: Where is the "1" monitored at in these statements? Never seen it done this way before.
    WHILE 1: WEND
    Louie
    The manual says do not use constants for address.
    Though I tried the above but the result is the same.
    While 1 : Wend - I just put this just like that to halt the code.
    Nov 2007
    West Covina, CA
    Oh yeah, no Constants.
    Then give it to him straight!
    Have you tried clearing the LOC and Value variables at the beginning of each loop just in case? Start with a clean slate every time.
        Loc=0
        Value=0
        I2CWRITE SDA,SCL,$36,[LOC],Fail1
        I2CREAD SDA,SCL,$37,[VALUE] ,Fail2
        PAUSE 25
        DEBUG  Value,13,10
        PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail1:
    Fail2:
    WHILE 1
    WEND
    You're so close, I can smell it!
    Or was that someone in the room?
    Louie
    Did the above, no luck.
    Doesn't like it straight, giving it $37/$36 direct sends it to Fail1 routine. So write statement fails.
    Funny thing is that when it goes to Fail1, though there should be no output of data, IT does output some of the data. This looks like half the data compared to when cycle runs normally.
    The code only run once and then I reset the PIC to run it again, so though it won't make any effect resetting the values in the main loop, I still tried with no luck. I am losing hairs on my head because of this now.
    Nov 2007
    West Covina, CA
    Still Debugging after failing is strange. There is something else being introduced corrupting your instructions.
    Use the Addr variables and see what happens when it free runs:
    x VAR BYTE
    RD_Addr = $37
    WR_Addr = $36
        I2CWRITE SDA,SCL,WR_Addr,[LOC],Fail1
        I2CREAD SDA,SCL,RD_Addr,[VALUE] ,Fail2
        PAUSE 25
        DEBUG  Value,13,10
        PAUSE 250
    WHILE 1 : WEND
    Goto Main
    Fail1:
    FOR x = 0 TO 10
    NEXT x
    Fail2:
    FOR x = 0 TO 10
    NEXT x
    GOTO Main
    Going to church now, BBL
    Louie
    Is that Write only an initialisation?
    Shouldn't it be outside the Main loop?
    This is a Touch IC. So shouldn't you check the device ID once, then check at another address within the loop to detect a touch? (not sure of trigger yet)
    I'm dense, won't WHILE 1: WEND loop endlessly?
    Edit: I see it now; 1 to 7 keys max for I2C, triggers lines out.
    Also, looking in datasheet if it says 400kHz max. I think you might have to run fast.
    4.1.1 max 400kHz, so you should be able to run slower.
    I would have thought:
    %00000001 = $37 ' Read function
    %00000000 = $36 ' Write function
    I don't see in this datasheet where you get the rest.
    Default Soooooo Close
    I just discovered, that the I am actually receiving only 1 byte as expected. Rest are just "Start......"13,10 and "Done",13,10. Yesterday got too exhausted and missed this mistake of mine.
    Here is the current code with
    Start:
    Loc=0
    Start_Again:
    	Value=0
    	PAUSE 250
    	DEBUG  Value
    	Loc=Loc+1
    	If Loc<4 then Start_Again		' Read first 4 locations
    	x=0
    WHILE !Change			' Stay here if Change Stays High
    		 Pause 500  : x=x+1
    		If x =10 then
    			LOC=3 : Goto Main ' Do another read
    		Endif
    WEND
    while Change : pause 100 : wend	' Stay here if change is Low
    Goto Start
    Fail1:					' Try Write again
    	For x=0 to 50
    		High Portc.2 : Pause 50 : Low PortC.2 : Pause 50
    	Next x
    Goto Start_again
    Fail2:					' Try read again
    	For x=0 to 5
    	Next x
    Goto Main
    Every time Change line goes low (detected something), I try to read first 4 memory locations. The communication fails a lot of times (both write and read (write more than read) )in this attempt but I do get the data on the screen finally. Secondly, the data which comes is wrong. For example, memory locations 0 does not read 2E for a start.
    Default Re: Soooooo Close
    Success but with one question.
    Finally, I put 20MHz clock. It started working with absolutely no problems.
    This leaves me with one MAJOR question - Is there any way, I can run the whole show at 4MHz, any settings I missed or anything I can do. I have got no extra pins on my PIC to put an external oscillator, I want to confirm the answer to this question before I start again and choose another suitable PIC. My task will get much much easier if there is a way to run it at 4 Sweet Megahertz.
    Many many many thanks to you guys for trying to helping me out on this. This forum is the best.
  1. Sample code for I2C text LCD needed
    By Alexey in forum Code Examples
    Last Post: - 15th September 2011, 01:29
  2. TMR0 Confusion
    Last Post: - 19th August 2011, 11:55
  3. HPWM confusion
    By lerameur in forum General
    Last Post: - 5th November 2006, 10:09
  4. HPWM confusion
    By rossfree in forum mel PIC BASIC Pro
    Last Post: - 3rd November 2005, 16:50
  5. DIV32 confusion
    By dmairspotter in forum mel PIC BASIC Pro
    Last Post: - 7th October 2005, 21:24
