I continuous search article about this Display (TM1640) on internet, if find any thing about this device, I post he!
I see you are using USB loader and are stuck with 48mHz. Perhaps this is too fast for TM1640. Have you got a slower PIC to try with.
My code does work at 4mHz.
Have you got the datasheet for TM1640?
Phil
Exact, I've use Bootloader with 48MHz. I have the Datasheet. I'll try with 16F628A and return.
Hi Joćo
Have ordered a JY-MCU 16X display. I should get it in about 2 weeks. Will let you know how I get on.
Phil
Hi Phil,
I tried buy other display on dx.com but is sold out. Where you buy? Do you have an PIC18F with clock 48Mhz famile for make this new test ?
Just set the DEFINE SHIFT_PAUSEUS 3 which will set the clock to a minimum of 3 us. that will slow it down to 333 Khz. which is just below the maximum of 450 Khz.
EN82fn
Hi Dave Purola,
I tried set this but nothing happens, I need buy other display for sure if my is good or no I think my display is bad, I don't have sure.
Thank you for your attention.
