TM1640 (16 digit display) with PicBAsic Pro, possible is? How?
Results 1 to 36 of 36
    Sep 2010
    Las Vegas, NV
    Default Re: TM1640 (16 digit display) with PicBAsic Pro, possible is? How?
    Every link I find about this display is coupled with Arduino and they always reference a library. I wasn't able to find any libraries written for PBP so it might never work on Basic until you can find the library for it.
    Aug 2011
    Manaus - Brazil
    I continuous search article about this Display (TM1640) on internet, if find any thing about this device, I post he!
    Oct 2011
    I see you are using USB loader and are stuck with 48mHz. Perhaps this is too fast for TM1640. Have you got a slower PIC to try with.
    My code does work at 4mHz.
    Have you got the datasheet for TM1640?
    Phil
    Aug 2011
    Manaus - Brazil
    Exact, I've use Bootloader with 48MHz. I have the Datasheet. I'll try with 16F628A and return.
    Oct 2011
    Hi Joćo
    Have ordered a JY-MCU 16X display. I should get it in about 2 weeks. Will let you know how I get on.
    Phil
    Aug 2011
    Manaus - Brazil
    Hi Phil,
    I tried buy other display on dx.com but is sold out. Where you buy? Do you have an PIC18F with clock 48Mhz famile for make this new test ?
    Just set the DEFINE SHIFT_PAUSEUS 3 which will set the clock to a minimum of 3 us. that will slow it down to 333 Khz. which is just below the maximum of 450 Khz.
    EN82fn
    Aug 2011
    Manaus - Brazil
    Hi Dave Purola,
    I tried set this but nothing happens, I need buy other display for sure if my is good or no I think my display is bad, I don't have sure.
    Thank you for your attention.
  1. HSEROUT full 3 digit display of variable howto ?
    Last Post: - 24th October 2008, 14:53
  2. Replies: 2
    Last Post: - 14th July 2008, 23:11
  3. Replies: 2
    Last Post: - 22nd January 2008, 15:25
  4. How to display dot on 7-seg , 4 digit
    Last Post: - 19th January 2007, 19:17
  5. SMART Serial 4 Digit LCD Display (SMARD4)
    By paul borgmeier in forum Adverts
    Last Post: - 5th January 2005, 06:50
