Need some advise on making five PICs communicate to each other
Results 1 to 7 of 7
    Default Re: Need some advise on making two PICs communicate to each other
    Quote Originally Posted by gadelhas View Post
    I will do it over 485. You can use a PIC with 485 or an external chip, like the MAX485/LTC485 or any other.
    You can use many types of connectores, its reliable, and probably there is many examples on this forum.
    Do these RS485 cables connect to RJ45 connectors? (I am sorry this is my first time with them)
    Aug 2008
    Portugal
    Quote Originally Posted by FromTheCockpit View Post
    If you want you can use RJ45, however you can use any other connector, like this;
    http://www.ebay.es/itm/250672034637?...84.m1423.l2649
    Thanks and Regards;
    Gadelhas
    Thanks M8. Got one more for you.
    I have 4 slaves, lets say they all have RJ45 type connector (for easy application). So one wire comes out from them, 4 in total.
    How does one master connects with 4 slaves in terms of hardware. I have seen RJ45 splitters http://www.tvcables.co.uk/cgi-bin/tv...-splitter.html
    Will I need 3 of these? (two plugged into 1)
    Aug 2008
    Portugal
    Humm... i think you must read something about RS485 to clarify your doubts. Google for RS485, but in meanwhile, RS485 uses two wires ( BUS) and all the modules connect in parallel to this two wires.
    Check also the datasheet of the MAX485 or the LTC485 and you can see how it works.
    Thanks and Regards;
    Gadelhas
    Default Re: Need some advise on making five PICs communicate to each other
    Here's another approach using a somewhat proprietary protocol.
    http://jap.hu/electronic/pbus.html
    Anand
  1. Cheapest way to communicate
    By koossa in forum Off Topic
    Last Post: - 25th May 2009, 12:06
  2. Communicate PC-to-PC using PIC
    By aje_azam in forum USB
    Last Post: - 16th March 2009, 07:35
  3. Making the Lab X1 communicate with the Lab X2
    By MatthewM in forum mel PIC BASIC Pro
    Last Post: - 19th June 2008, 22:26
  4. What's the best way to communicate?
    By BobK in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2004, 06:54
  5. 256 Pics Communicate to 1 Master Pic
    By mazlan in forum mel PIC BASIC Pro
    Last Post: - 15th July 2004, 13:11
