Someone please help me out?
Results 1 to 4 of 4
    Default Re: Someone please help me out?
    Hello avanomi & welcome,
    ADCS1 is bit 7 of the ADCON0 register, you would " set " this bit as ADCON0.7 = 1 or ADCON0 = %10000000 Microchip Data sheet PP 129 .
    What it appears you are trying to do is to Disable the Synchronous Serial Port and use Port A as Digital I/O.
    Data sheet PP 83/84 SSPCON register bit 5 enables / disables SSP set it to zero and you are golden. Remember this chip has several
    Analog registers which have to be set to get digital I/O. ADCON0, ADCON1, ADRESH ADRESL . . . see page 43 for PortA registers, DO Use the index
    of the Data Sheet under registers.
    HTH
    EDIT:
    Page numbers could be off a bit due to Adobe reader showing different number from printed page, but close.
    EDIT EDIT: PortE ADCON1, TRISE 0:2 For port E, watch out for TRISE.4 if set will upset PortD's use as I/O. PP50:52
