18F6680 and portd problems.
Results 1 to 11 of 11
    jkbh's Avatar
    jkbh Guest
    If I use ASM code in Picbasic it works.
    I did like this!!
    Startup:
    asm
    bsf LATD,5
    endasm
    asm
    bcf LATD,5
    endasm
    adcin 1,AN1
    adcin 2,AN2
    adcin 3,AN3
    ADCIN 5,AN4
    goto startup
    WHY does it not work if I simple use HIGH and LOW LATD.5
    Is it a bug in PBP 2.44???
    /Jimmy
    jkbh's Avatar
    jkbh Guest
    I solved the problem!
    I had bad through plating holes on my PCB.Almost all PortD bits had bad connection on the second layer.Hav fix it now and the portD works great.
    Thanks anyway!!
    /Jimmy
