18F6680 and portd problems.
Results 1 to 11 of 11
    Mentor, Ohio
    Smile
    Thanks Bruce,
    I'll put that note in my handbook! That's what I like about this site. You always learn something!
    BobK
    jkbh's Avatar
    jkbh Guest
    I´m gonna check my config bits tomorrow,but I think I have got it right.
    I know I have set:
    HS PLL mode.
    Power on timer enabled.
    Turned off watchdog.
    What config bits shall I use if I just want to use PORTD as Digital I/Os.
    /Jimmy
    jkbh's Avatar
    jkbh Guest
    Hers my current Configuration Bits.
    I have put these in the 18F6680.INC file in the PBP directory.
    Is this the right way to do it?
    __CONFIG _CONFIG1H, _OSC_HSPLL_1H
    __CONFIG _CONFIG2L, _PWRT_ON_2L
    __CONFIG _CONFIG2H, _WDT_OFF_2H & _WDTPS_128_2H
    __CONFIG _CONFIG4L, _LVP_OFF_4L & _STVR_OFF_4L
    __CONFIG _CONFIG5H, _CPD_OFF_5H
    __CONFIG _CONFIG6H, _WRTD_OFF_6H
    /Jimmy
    jkbh's Avatar
    jkbh Guest
    I have now tested with a 18F6585 chip and it is same problem with this chip.
    The current drawn from each pin on portD is 0.2mA.Total of 1.6mA on portD so there is not to high load on the port.
    So I guess that there is something that I have forgotten to turn off or something.
    Now guys..Please help me!!
    /Jimmy
    jkbh's Avatar
    jkbh Guest
    If I use ASM code in Picbasic it works.
    I did like this!!
    Startup:
    asm
    bsf LATD,5
    endasm
    asm
    bcf LATD,5
    endasm
    adcin 1,AN1
    adcin 2,AN2
    adcin 3,AN3
    ADCIN 5,AN4
    goto startup
    WHY does it not work if I simple use HIGH and LOW LATD.5
    Is it a bug in PBP 2.44???
    /Jimmy
    jkbh's Avatar
    jkbh Guest
    I solved the problem!
    I had bad through plating holes on my PCB.Almost all PortD bits had bad connection on the second layer.Hav fix it now and the portD works great.
    Thanks anyway!!
    /Jimmy
