When variable may not fits into WORD limitations
Results 1 to 5 of 5
    Default When variable may not fits into WORD limitations
    Hello.
    I have a situation when a equation like (a*b*c*d)/(a+b+c+d) to be solved. Variables may change from 1 to 100), so result may be well out of allowed range. How to workaround such situation?
    Sep 2009
    Default Re: When variable may not fits into WORD limitations
    Result=(a*b)/(a+b+c+d)
    Result=Result*c*d
    And another question. I need to have X divided by 3.6 , since we don't have fractions, I can do X*10/36. But, X*10>65536, so this also does not works. The partial workaround is X*5/18. But still, won't work for large X values. Any ideas how to do conversion?
    IF your numbers are <= 100 ... a*b*c*d maximum value is ???
    that is outside or inside the compiler limitations ???
    just my two cents ...
    As with most things it depends....on the resolution and accuracy you need and/or can live with it. Try X */ 71 or X ** 18204 or use DIV32 or switch to a LONG (if using 18 series).
  1. Word variable and storing correct value
    By Scampy in forum mel PIC BASIC Pro
    Last Post: - 28th December 2012, 13:04
  2. How to isolate 10 bits from word variable?
    By rcbandwidth123 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 21:18
  3. adding new word variable ?
    By iugmoh in forum General
    Last Post: - 21st February 2008, 01:26
  4. Convert a word variable to decimal
    Last Post: - 4th December 2004, 21:02
  5. word variable to 25lc640
    Last Post: - 6th July 2004, 20:59
