Suggestions for Boosting Current Output?
Results 1 to 2 of 2
    RossW's Avatar
    RossW Guest
    Default Suggestions for Boosting Current Output?
    I'm working on a circuit that will have 6-8 white LEDs connected to one pin. Since this is drawing more than the max. sink of 20 mA, does anyone have some suggestions on how to boost the current? I've used NPN transistors in the past, but I'm not sure if I need a resistor between the base and the PIC pin, what tranny to use, etc. Would a hex driver be better?
    Drivers like UNL2003 are not better than any BJT transistor like 2N4401, but easier to use and take, in man case less pcb space and component count. you'll never need any external resistor between your PIC and those driver. Plug-N-Play.
  1. Output current to a DC motor
    By bigbanner in forum General
    Last Post: - 6th April 2009, 07:29
  2. Serious Serial Situation Setbacks...
    Last Post: - 7th February 2007, 03:46
  3. HSEROUT Newbie question/problem
    By Mark Scotford in forum mel PIC BASIC Pro
    Last Post: - 11th July 2006, 14:44
  4. High current switching output
    Last Post: - 8th September 2005, 14:06
  5. Can I combine outputs for more current?
    By jswayze in forum Off Topic
    Last Post: - 28th May 2005, 15:52
