One LED not light up
Results 1 to 3 of 3
    Jul 2013
    Malaysia
    Default One LED not light up
    hi all,
    i trying to make a running light LED on dsPIC33FJ64MC802 and this is my code
    void main (void){
        TRISA=0x0000; //portA as output
        unsigned int data;
        unsigned int n;
        unsigned int m;
        while (1){
             data=0x01;
            for(n=0;n<5;n++){  //make a loop for led to on
                LATA=data;    //to confugure which led to on
                data=data<<1;  //change the value in data
                delay1s();
            data=0x10;          //Change value in data to make led light on backwork
            for(m=0;m<5;m++){    //make a loop for led to on
                data=data>>1;   //change the value in data
                delay1s();
    my question is, why my LED 4 not light up while other run as what i want.
    Default Re: One LED not light up
    1. This is a PicBasic Forum and not C.
    2. The above compiler does not support 24 or 32 series PICs.
    3. Maybe your PortA is input only, so check your PICs datasheet.
    May 2008
    Italy
    Very likely porta for led 4 is an open collector port. In such a case, you just need to change the way the led is connected.
    (Check the data sheet for confirmation)
    Cheers
    Al.
  1. PIC16F1825 unable to Light an LED
    By Lestat in forum mel PIC BASIC Pro
    Last Post: - 16th March 2013, 19:38
  2. sweeping LED light effect
    Last Post: - 14th July 2012, 07:04
  3. LED Light Sensor - Need Help Please
    By Heckler in forum General
    Last Post: - 22nd January 2012, 05:53
  4. LED Light Controller
    By lightwaveengine in forum mel PIC BASIC
    Last Post: - 18th June 2006, 16:46
  5. An LED as a light Sensor
    By Funky Gibbon in forum General
    Last Post: - 10th April 2006, 19:43
