Switching power sources, battery charging
Results 1 to 19 of 19
    Default Re: Switching between power source and battery
    There's a few reasons why I wanted to stay away from a relay:
    - they must be slower than transistors.
    - mechanical parts mean wear.
    - and I really was looking for an excuse to finally use mosfets.
    I don't know why the design I posted at the top uses 2 mosfets back-to-back. According to this site (and many others) P-channel mosfets are connected "backwards" and you only need one to act as a switch:
    http://www.electronics-tutorials.ws/...or/tran_7.html
    (scroll down to P-channel MOSFET Switch)
    EDIT: Updated design
    Name:  Modified HEXFET switch.JPG
    Apr 2011
    I sympathise with the 'excuse' but the first two resons don't parse..... a simple capacitor will prevent the volt drop for the millisecond(s) the relay switches and relay contact reliability is usually measured in the 'millions' (or 10's of millions) of operations....... Indeed, in this particular application you'll find most manufacturers use relays too - simple and cheap.
    Dec 2010
    First Robert, let me say sorry for starting to help and then falling off the internet. I had to be away for a couple days without access.
    The original problem... Based on what you've posted, just hook the float charger to the battery and power your circuit from that. Your siren won't care about voltage from about 10 V to about 15 V.
    A sealed lead acid battery can remain on a float charge forever without damage. Large commercial systems do it all the time - for example the telephone system works this way. Hook up your trickle charger to the battery and measure the voltage - if it's between 13.2 V and 14.4 V (2.2 - 2.4 volts per cell) you are good to go. Cars are usually 13.8 V.
    The current required for multiple LEDs is an old problem, and the reason "scanning" LEDs was invented. You basically switch them on and off fast enough that your eyes don't pick up the blinking (anything over about 100 Hz). You use about a 10% duty cycle and increase the current a little bit if you wish. You can experiment to adjust perceived brightness. You will end up with less current than the LCDs.
    I'll see if I can sketch you a VFET circuit when I have a second - still catching up on email.
    I'm concerned with this wallwart made-in-china trickle charger. I wanted it for testing and maintaining my new 12V battery, but I wouldn't trust it in permanent service in a metal enclosure. I've read reports of them overheating.
    I'm googling LM317 app notes and such looking for a reliable 12V 7Ah automatic charger.
    The DSC1000 runs without a battery connected (I ran it over 1 year when the battery died). That's why I wanted to run off mains first, and battery during blackouts.
    This charger seems interesting:
    http://www.sentex.ca/~mec1995/circ/lader.htm
    Dec 2010
    You can certainly roll your own - they are pretty simple. As I mentioned, you want a voltage between 13.2 V and 14.4 V. Limit current for thermal reasons because the battery can handle a lot more current than a simple charger can provide when it is really flat. If you want to get fancy, remove the charge every once in awhile and measure the voltage as this will give you the state of charge, or set it up so that you provide under 2A when the battery voltage is about 12.6V, then reduces as it rises further.
    The amp hour rating of your battery is not relevant to the design. and overheating is only a potential issue if you are charging a totally pancaked battery. In normal use you really don't need to worry.
    The 317 is a bit light, but conceptually you could use it as a reference with a couple power transistors that turn on as required.
    The circuit in the link seems fine.
    Quote Originally Posted by Charlie View Post
    ... overheating is only a potential issue if you are charging a totally pancaked battery. In normal use you really don't need to worry.
    What if the battery dies, sulfates, whatever?
    I'm open to using higher rated components, I'm not merchandising. I try to follow his math on how to select resistors but I get lost.
    I checked this, but I'd prefer to build and learn instead of using a charging module.
    http://www.picbasic.co.uk/forum/show...5713#post95713
    I could use a PIC as they did, but I haven't seen much on google or here that does exactly what I need.
    The PIC could do it all, switch between sources and auto charge. But I would need more hand holding going that route.
  1. SLA battery charging with PWM but which frequency
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 13th June 2017, 12:41
  2. Without resetting....Switching PIC over to Backup Battery
    By financecatalyst in forum Schematics
    Last Post: - 29th December 2010, 15:23
  3. 4.5V Battery charging circuit....
    By Megahertz in forum Schematics
    Last Post: - 2nd July 2010, 01:33
  4. Safe battery charging?
    By keymuu in forum General
    Last Post: - 29th November 2008, 09:45
  5. Read the level of the Charging battery
    By DragonBall_6 in forum General
    Last Post: - 30th November 2006, 04:47
