Switching power sources, battery charging
Results 1 to 19 of 19
    Sep 2009
    Default Re: Switching between power source and battery
    You can't put 7812 when device is powered from accumulator. Because 7812 have voltage drop about 2V, so you need at least 14V on input to get 12Voutput, and 7812 is only 1A rated in to220 package, in to3 is 3A rated.
    If you need all ways 12V on output, use buck/bust regulator, or use boost to get 15V and then use buck regulator to get 12V from 15V. This way your input voltage may be from 5-6V to 30-40V, depending on device. You also have simular PSU on ebay
    http://www.ebay.com/itm/DC-Boost-Buc...item5af2b8bf04
    Dec 2010
    Robert, if your siren needs an absolute minimum of 12 V, it's likely not going to work anyway with a 12V battery, as the battery could get under 12V fairly quickly when being discharged depending on the load and it's capacity. I think you need a proper spec for what the circuit produces i.e. "Must operate from a 12V sealed lead acid battery and/or an external power supply between 12V and 16V and must produce 12 V regulated to +/- 0.5 V"... that sort of thing. Further, you need to specify with tolerances, the current needed and for how long, and under what conditions. If you plan to mount it outside in a garage or something, the temperature range will be important too.
    The circuit shown is way too complicated for what it does - effectively switching the load to one supply or another. You would not need 2 FETs for each leg - power VFETS have a saturated resistance of a few milliohms depending on the device chosen. At 5A you wouldn't even need a heat sink. And how does the battery get charged? You might be able to connect the battery charger to the battery and power from the battery at the same time (like a car) depending on your spec. Or you might need to design either a switching supply, or a linear regulator that can work with a very small volt drop - again depending on that spec.
    It's a fun problem.
    Quote Originally Posted by Charlie View Post
    Robert, if your siren needs an absolute minimum of 12 V, it's likely not going to work anyway with a 12V battery, as the battery could get under 12V fairly quickly when being discharged depending on the load and it's capacity. I think you need a proper spec for what the circuit produces i.e. "Must operate from a 12V sealed lead acid battery and/or an external power supply between 12V and 16V and must produce 12 V regulated to +/- 0.5 V"... that sort of thing. Further, you need to specify with tolerances, the current needed and for how long, and under what conditions. If you plan to mount it outside in a garage or something, the temperature range will be important too....
    These are piezo residential alarm sirens, not humungous horns. I have an old DSC1000 system in the house and it works fine using such a horn and a 12V 4Ah battery. I am upgraded to a 12V 7Ah with this project.
    My plan is to make 3 identical systems; house, garage, shed, all interconnected. If one system is triggerred and disabled, the other systems will still be triggerred (making it very difficult for someone to overcome them all quickly). It's also possible the cables between the buildings could get damaged.
    Here is a pic of the current system to give you an idea how the installed system operates:
    ¨... The circuit shown is way too complicated for what it does - effectively switching the load to one supply or another. You would not need 2 FETs for each leg - power VFETS have a saturated resistance of a few milliohms depending on the device chosen. At 5A you wouldn't even need a heat sink. ...
    I liked this circuit because it seemed so much simpler than so many other designs I've googled; some even used mechanical relays. So how would I go about connecting VFETS, and which model? Remember this is my first foray in MOSFET territory so schematics help me understand (I'm visual by nature).
    ¨... And how does the battery get charged? ...
    My initial idea was to keep things simple and bought this universal floating charger:
    http://www.rpelectronics.com/fc-612c...ger-6-12v.html
    I wouldn't mind handling the charging myself if I find a design I can manage.
    ¨... You might be able to connect the battery charger to the battery and power from the battery at the same time (like a car) depending on your spec. ...
    Wouldn't that shorten the life of the battery?
    ¨... Or you might need to design either a switching supply...
    Schematics I've seen so far seem complicated. I would have liked to keep things reliable and simple if at all possible.
    ¨... or a linear regulator that can work with a very small volt drop ...
    I don't think that would be good when the system would run off the battery. I would think I need all the juice I can muster under blackouts.
    I'm embarking on this adventure because the DSC1000 is erratic after 20 years of service. The neighbours and family don't enjoy listening to a siren at 3am. That and it only has 4 zones.
    One issue that is plaguing me is current requirement. The garage needs at least 16 zones (2 stories); that quickly adds up using average 20mA LEDs to show status. I also want to have visibility of the other buildings from any keyboard, even more current required.
    I have several older units of this graphic LCD, mine are 90-100mA:
    http://www.qingyun-it.com/products/y...LCM3202401.pdf
    Much lower current required than LEDs and much more flexible.
    Apr 2011
    If the device is primarily mains-powered there is no real concern for power consumption and a simple RELAY would allow switching of practically any amperage at the cost of a few 10's of mA.
    Sometimes the simplest way is best.
    There's a few reasons why I wanted to stay away from a relay:
    - they must be slower than transistors.
    - mechanical parts mean wear.
    - and I really was looking for an excuse to finally use mosfets.
    I don't know why the design I posted at the top uses 2 mosfets back-to-back. According to this site (and many others) P-channel mosfets are connected "backwards" and you only need one to act as a switch:
    http://www.electronics-tutorials.ws/...or/tran_7.html
    (scroll down to P-channel MOSFET Switch)
    EDIT: Updated design
    Name:  Modified HEXFET switch.JPG
    Apr 2011
    I sympathise with the 'excuse' but the first two resons don't parse..... a simple capacitor will prevent the volt drop for the millisecond(s) the relay switches and relay contact reliability is usually measured in the 'millions' (or 10's of millions) of operations....... Indeed, in this particular application you'll find most manufacturers use relays too - simple and cheap.
    Hi Robert,
    Do you mean you cannot waste the power or do you mean you need to limit the output draw on the PIC?
    Sorry, I meant I can't use columns of LEDs as initially planned.
    I'm switching for the 100mA LCDs that I have on hand. The house has only 1 keypad, the garage will have 2. That means I can live with 1.5A, even only 1A if I must.
    So now I'm looking for improvements on the latest schematic, and a battery-charging circuit is a bonus.
  1. SLA battery charging with PWM but which frequency
    By showtime in forum mel PIC BASIC Pro
    Last Post: - 13th June 2017, 12:41
  2. Without resetting....Switching PIC over to Backup Battery
    By financecatalyst in forum Schematics
    Last Post: - 29th December 2010, 15:23
  3. 4.5V Battery charging circuit....
    By Megahertz in forum Schematics
    Last Post: - 2nd July 2010, 01:33
  4. Safe battery charging?
    By keymuu in forum General
    Last Post: - 29th November 2008, 09:45
  5. Read the level of the Charging battery
    By DragonBall_6 in forum General
    Last Post: - 30th November 2006, 04:47
