BOLT 18f2550
Results 1 to 4 of 4
Thread: BOLT 18f2550
    Jul 2013
    Default BOLT 18f2550
    Has anyone got the bolt 18f2550 project kit working with PB3
    Including the LCD display ?
    Can't get the display working at all ? ...
    Post Re: BOLT 18f2550
    What I found is the PB2.6 and earlier versions and using some LCDs, PB is too fast (20m xtal) in the initialisation routine for the LCD, and I have had to edit the appropriate file and insert some NOPs, doing this and the LCDs work fine.
    Before any suggests to use the LCD US defines, these did not appear to work during the initialisation routine, they appear to only come in to effect later. There was a post recently about LCDs if I remember and that also had avice about editing the file. I assume that PB3 has the same routines.
    Jul 2013
    Default Re: BOLT 18f2550
    thank you,
    started to change some of the define lcd command times and it almost works but still not quite
    thanks for the reply using PB3 so will look into it, thanks again
    regards
    leighton
    Jan 2014
    Hi Leightonh,
    I have the Bolt 2550 and would like to program it with PicBasic and use the Bolt 2550 boot-loader. How did you set this up?
    Thanks.
  1. 18F2550 timing
    By sstt1976 in forum mel PIC BASIC Pro
    Last Post: - 22nd August 2008, 00:30
  2. 18f2550 + 24lc512
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 22:02
  3. DS1820 and 18f2550
    By rjones2102 in forum mel PIC BASIC Pro
    Last Post: - 2nd October 2007, 18:11
  4. Madness, 18F2550!
    By tom in forum mel PIC BASIC Pro
    Last Post: - 11th February 2007, 11:00
  5. EasyHid and 18F2550 - why? what? how?
    By Giulio in forum mel PIC BASIC Pro
    Last Post: - 28th December 2006, 07:57
