hex files don't agree
Results 1 to 4 of 4
    Jun 2011
    Indian Harbour Nova Scotia
    Default hex files don't agree
    I compiled a PicBasic Pro program using MicroCode Studio that compiled without error and the program works. When I look at the hex file created through the MELabs programmer under the tab "memory", the codes DO NOT match up with the hex file I open with Notepad.
    Here's the first few lines of memory (whatever that is) in attachment memory.jpgName:  Memory.jpg
    and the first few lines of the *.hex file called hex.jpgName:  hex.jpg
    How come?
    Default Re: hex files don't agree
    They look identical to me.
    Maybe, knowing how the "Intel hex Format" works will help you see the same thing.
    http://en.wikipedia.org/wiki/Intel_HEX
    Jun 2011
    Since one of the files was in Notepad, I did a search for any pattern that looked like a command and came up empty. But you're right, it's my interpretation that is leading to the confusion, as I suspected. I'm quite familiar with Motorola S-records but not Intel.
    In the Wiki you provided there is this statement: "Beware! While addresses are always given as big endian byte addresses, it's unspecified how to interpret the data bytes. Whether they are taken as bytes, 16- or 32 bit little- or big endian words is application specific."
    So what is PBP? big or small endian? bytes? words?
    -Can you break down and maybe highlight one or two commands that are "the same" so I can get my head around this? (I don't need to know this for any particular reason except that I MUST know it).
    -What is the "memory" referred to in the MeLabs programmer popup? Is it program memory IN THE CHIP or is it some kind of buffer memory stored in PBP session, or is it a hex file located on the windows disk?
    Jun 2011
    Ahh...I see it now. 28A2 in the first hex display (from PBP programmer) is shown as A228 in the second hex display (on hard drive).
    The bytes are swapped.
    Long time ago I decided to stick with Motorola assembler and machine code because their's was more intuitive than the backwards logic of Intel. (8080, 8086 stuff).
  1. EasyPic5, PicFlash2 and hex files
    By david1800 in forum Off Topic
    Last Post: - 11th July 2011, 07:11
  2. Creating your own .inc files
    By mjphillips1981 in forum mel PIC BASIC Pro
    Last Post: - 27th May 2009, 12:46
  3. Compiler not creating .hex files for programmer.
    By Teknikum in forum mel PIC BASIC Pro
    Last Post: - 15th May 2009, 10:37
  4. How to use MPASM 'INC' files?
    By circuitpro in forum General
    Last Post: - 30th January 2009, 05:22
  5. Using PBP Hex Files with FED Pic Programmer
    By jrudd in forum mel PIC BASIC Pro
    Last Post: - 20th February 2005, 10:57
