Did I get the right device? USB-Serial
Results 1 to 10 of 10
    Dec 2012
    Tennessee
    Default Re: Did I get the right device? USB-Serial
    ok Thanks, Ive got .net enterprise 2010, and Ive confirmed I do have the serial control, will have to do a bit of searching for some example code to start.
    as for the pic side thats great news, I need to send a word at a time, the high byte determines which variable to store the low side byte. it would be great to be able to split it at 6/10 bits and convert the high 6bits to a single byte, and the low 10 to a single word. So...
    "0000110000001111" would end up split up at "000011/0000001111"
    Byte0 = 00000011
    Word0 = 0000000000001111
    Does this look like it might work?
    Chris
    Any man who has accomplished anything in electronics at one time or another has said... " STOP! WAIT! NOOO! Dangit.... Oh Well, Time to start over..."
    Something like this might work then:
    RawWord VAR WORD
    Adress VAR BYTE
    Value VAR WORD
    HSERIN[RawWord.Byte1, RawWord.Byte0]   ' Receive two bytes and store them in RawWord, high byte first
    Adress = (RawWord.Byte1 & 252) >> 2    ' Get the 6 top bits and store them in variable Adress, 0-63. (The &-operation may not be needed)
    Value = RawWord & 1023                 ' Get the bottom 10 bits and store them in variable Value, 0-1023
  1. Replies: 1
    Last Post: - 5th October 2011, 08:59
  2. USB Device Communication
    By Pesticida in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 21:22
  3. usb - device not recognised
    By mpardinho in forum mel PIC BASIC Pro
    Last Post: - 8th January 2007, 17:47
  4. USB device
    By Haitham Rifai in forum USB
    Last Post: - 5th December 2005, 09:07
  5. usb device not recognized
    By NL2TTL in forum mel PIC BASIC Pro
    Last Post: - 2nd June 2005, 05:22
