Usb work 100%
but hserout not work ... wrong caracters
i use hserout for debug/gsm...
18F25J50
Code:INCLUDE "modedefs.bas" INCLUDE "DT_INTS-18.bas" ; Base Interrupt System INCLUDE "ReEnterPBP-18.bas" ; PBP Re-entry for external interrupt #CONFIG config WDTEN = OFF ;WDT disabled (enabled by SWDTEN bit) config PLLDIV = 2 ;Divide by 2 (8 MHz internal oscillator input) config STVREN = ON ;stack overflow/underflow reset enabled config XINST = OFF ;Extended instruction set disabled config CPUDIV = OSC1 ;No CPU system clock divide config CP0 = ON ;Program memory is not code-protected config OSC = INTOSCPLL ;HSPLL ;INTOSCPLL ;Internal oscillator, PLL enabled, used by USB config T1DIG = OFF ;Sec Osc clock source may not be selected, unless T1OSCEN = 1 config LPT1OSC = OFF ;high power Timer1 mode config FCMEN = OFF ;Fail-Safe Clock Monitor disabled config IESO = OFF ;Two-Sp Start-up disabled config WDTPS = 32768 ;1:32768 config DSWDTOSC = INTOSCREF ;DSWDT uses INTOSC/INTRC as clock config RTCOSC = INTOSCREF ;RTCC uses T1OSC/T1CKI as clock config DSBOREN = OFF ;Zero-Power BOR disabled in Deep Sleep config DSWDTEN = OFF ;Disabled config DSWDTPS = 8192 ;1:8,192 (8.5 seconds) config IOL1WAY = OFF ;IOLOCK bit can be set and cleared config MSSP7B_EN = MSK7 ;7 Bit address masking ;config WPFP = PAGE_1 ;Write Protect Program Flash Page 0 ;config WPEND = PAGE_0 ;Start protection at page 0 ;config WPCFG = OFF ;Write/Erase last page protect Disabled ;config WPDIS = OFF ;WPFP[5:0], WPEND, and WPCFG bits ignored #ENDCONFIG '------------------------------------------------------------------------------- DEFINE HSER_RCSTA 90h DEFINE HSER_TXSTA 20h DEFINE HSER_BAUD 9600 DEFINE HSER_CLROERR 1 '------------------------------------------------------------------------------- ASM INT_LIST macro ; IntSource, Label, Type, ResetFlag? INT_Handler USB_Handler INT_Handler INT_INT, _Leitor, PBP, yes endm INT_CREATE ; Creates the interrupt processor endasm ;@ INT_ENABLE INT_INT ; enable external (INT) interrupts '--- Setup USB ----------------------------------------------------------------- INCLUDE "DT_HID260.pbp" DEFINE USB_VENDORID 6017 DEFINE USB_PRODUCTID 2000 DEFINE USB_VERSION 1 DEFINE USB_VENDORNAME "MICROSOFT" DEFINE USB_PRODUCTNAME "USB HID" DEFINE USB_SERIAL "001" DEFINE USB_INSIZE 8 ; IN report is PIC to PC (8,16,32,64) DEFINE USB_OUTSIZE 8 ; OUT report is PC to PIC DEFINE USB_POLLIN 10 ; Polling times in mS, MIN=1 MAX=10 DEFINE USB_POLLOUT 10 ; --- Each USB status LED is optional, comment them if not used ------------ ; --- They can be assigned to any pin, and no further action is required --- DEFINE USB_LEDPOLARITY 1 ; LED ON State [0 or 1] (default = 1) DEFINE USB_PLUGGEDLED PORTB, 7 ; LED indicates if USB is connected ;DEFINE USB_TXLED PORTD, 1 ; " " data being sent to PC ;DEFINE USB_RXLED PORTD, 2 ; " " data being received from PC '------------------------------------------------------------------------------- Led var PORTB.7 '------------------------------------------------------------------------------- 'DEFINE OSC 8 OSCCON.6 = 1 OSCCON.5 = 1 OSCCON.4 = 1 ANCON0 = %11111111 ' Todas portas digital ANCON1 = %00001111 ADCON0 = 0 ' ADC off ADCON1 = 0 INTCON2.7 = 0 ' Desativa PortB Pullups CM1CON1.7 = 0 CM2CON1.7 = 0 OSCTUNE.6 = 1 ' PLL On PAUSE 10 '------------------------------------------------------------------------------- LATA = 0 LATB = 0 LATC = 0 PORTA = 0 PORTB = 0 PORTC = 0 TRISA = %00011111 TRISB = %01111111 TRISC = %10000000 'INTCON2.4 = 0 ' PORTB.2 - Lo to Hi 'INTCON2.5 = 0 ' PORTB.1 - Lo to Hi INTCON2.6 = 0 ' PORTB.0 - Lo to Hi '------------------------------------------------------------------------------- 'while (Plugged = 0) ' PAUSE 1 'wend hserout["------START------", 13] pause 1000 '------------------------------------------------------------------------------- Inicio hserout["HI", 13] pause 1000 GOTO Inicio .......... ..........
