Serin Serout possible wiring distance
Results 1 to 34 of 34
    Dec 2005
    Default Re: Serin Serout possible wiring distance
    Quote Originally Posted by tasmod View Post
    Thought I posted that. Radio module is available 3.3v only.
    So Pic and radio module are at 3.3v. Voltage reg in photos is 3.3v device.
    That doesn't necessarily mean that RX & TX are at 3.3V. The purpose of chips like the MAX232 is to boost the supply voltage to RS232 levels which can be +/-15V.
    However, since the ARF is an upgrade of Ciseco's XRF, it probably is wired the same and there is documentation for the latter showing RX & TX directly connected to the microcontroller. It would help if they correctly identified their devices as using a low voltage serial link rather than being RS232 which implies much higher voltage levels.
    As Henrik said, the only way to be sure is to try it. The TX level is likely to be ~3V at best. You can check the PIC datasheet to see if that's adequate.
    Dec 2011
    IO93ok
    Thanks Dave,
    Hmmm Ciseco documentation. Good overall, but very confused descriptions with various devices being refered back to each other. Lots of back and forth. It strikes me of someone who knows their products, but forgot to ask someone who doesn't know to look at the site.
    I was reluctant to split the board as it's a nice fit in box but it's now getting too close to deadline, so I'll try the cable route.
    Rob
    Dec 2011
    IO93ok
    Just for information if anyone wants to use these rf modules. I did a range test of the modules with the shown aerials.
    4.687km line of sight with reliable operation.
    Just modding the boards to test serial cable length working between pic and rf module. I will try 5m cable length, as that's what is required on site.
    I'm also looking at providing RSSI on a lcd display. I need to add AT commands in code to switch the other transceiver into test mode where RSSI is sent every second.
    Just need to work it out.
    Very impressive range. Can you give us your antenna calculations?
    I just have succesfully tested a pair of Adeunis ARF7761 modules at 169MHz@500mW that covered over 12Km range. One side used a 42cm l/4 atached on a short RG58 cable and the other a dipole l/4.
    Dec 2011
    IO93ok
    Hi Ioannis,
    I used Yagi Calculator software from here. It's a simple to use but excellent piece of software.
    Yagi has 9.8dbd gain.
    The Moxon Loop also has design software available but I've now changed my mind re the loop as it is hard to make it rigid enough for the application. Loop has 3dbd gain.
    There is of course the frequency difference losses between our module setups but that's pretty impressive range.
    I estimate that line of sight and two yagis will do 12km as well with these units. It's not out of the way to setup two long yagis of say 21 elements 15.5dbd gain each to achieve more range at fixed locations.
    In my use this will be a portable setup. It needs to be erected and taken down quite easily and to maybe signal penetrate a bit of bush. This at much closer range of course.
    I'm currently building the finished yagi in plumbers 15mm copper pipe as the boom and 4mm brake pipe as the elements. Easy to solder in and to bend the dipole out of. It will be used in vertical polarisation as the 'receive' end will be a small vertical colinear with small gain.
    Software for signal strength for setup of yagis is in progress. This is what I have so far in progress and have posted a question re syntax in Ciseco forum.
    I need to work out the lowest values for sigfield/sigcontrol variables , highest value (lowest signal) is around 88-90 as a returned value. Then send to lcd display.
    rssion:
        SEROUT2 PortA.3,84,["BOB",sigon]    ; puts slave module in test mode via code
        PAUSE 1000                                    ; wait 1 second
        SEROUT2 PortA.3,84,["+++"]           ; send guard character
        SEROUT2 PortA.3,84,["ATNT3"]         ; place unit in test mode
        SEROUT2 PortA.3,84,["ATWR"]          ; write to memory
        SEROUT2 PortA.3,84,["ATDN"]          ; exit command mode
    sigstrength:
        SERIN2 PortA.2,84,1000,sigstrength,[WAIT("aSSRSSIS-",sigfield)]       ; get slave sig strength value
        SERIN2 PortA.2,84,1000,sigstrength,[WAIT("aMMRSSIM-",sigcontrol)]  ; get control sig strength value
        IF jump = 0 then rssioff        ; check input to reset to serial
        GOTO sigstrength
    rssioff:
        SEROUT2 PortA.3,84,["ATNT0"]          ; place unit in serial mode
        GOTO main
    Thanks for sharing. Regarding the serial communication, can you use the hardware serial port of the controller?
    The I would suggest to use also the Hserin and wait for the response from the RF module instead of just PAUSE 1000. You can't be sure that the module responded in-time.
    Dec 2011
    IO93ok
    Hi Ioannis,
    The pause 1000 is the 1 second no input then the +++ and then no input for 1 second. This is the format required to put the rf module into 'test' mode for RSSI output.
    Rob
  1. Using SEROUT and SERIN
    By acinorth in forum Test Area
    Last Post: - 20th July 2011, 12:33
  2. Serout -->>> serin
    By larzazral in forum mel PIC BASIC Pro
    Last Post: - 27th February 2010, 04:46
  3. SERIN and SEROUT
    By CumQuaT in forum mel PIC BASIC
    Last Post: - 3rd September 2009, 01:17
  4. serin,serout
    By andrewwaack in forum mel PIC BASIC Pro
    Last Post: - 8th July 2006, 20:21
  5. serin/serout
    By simonr in forum mel PIC BASIC Pro
    Last Post: - 26th September 2003, 19:45
