Inverse of COS
Results 1 to 6 of 6
Thread: Inverse of COS
    bot402's Avatar
    bot402 Guest
    Alternatively, look at the PROTON+ compiler.
    This does true floating point calculations including trigonometry.
    uuq1's Avatar
    uuq1 Guest
    Default InvCos
    I tried with Taylor series but no good.
    For angles less than 45 degrees, the code seem to work ok, but for larger angles the deviation is high.
    I have decided to use interpolation with select.
    Appreciate the help I got from this place.
    USA - Arizona
    You may also want to look here:
    http://www.emesys.com/BS2math3.htm
    uuq1's Avatar
    uuq1 Guest
    Thanks languer for the article. I think it will help.
  1. Cordic trig assembly code for PIC18f
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th September 2015, 06:36
  2. ARCOS (inverse cosine)
    By mjphillips1981 in forum mel PIC BASIC Pro
    Last Post: - 8th October 2009, 17:53
  3. Serial Communication Inverse mode
    By titanvision in forum Serial
    Last Post: - 27th October 2008, 03:53
  4. Sin
    By AndyP in forum mel PIC BASIC Pro
    Last Post: - 16th December 2007, 22:06
  5. How to do ARCTAN (inverse tan) in PICBasic Pro
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 13th April 2006, 18:27
