Inverse of COS
Results 1 to 6 of 6
Thread: Inverse of COS
    uuq1's Avatar
    uuq1 Guest
    Default Inverse of COS
    Can anybody help me find ArcCos?
    uuq
    Dec 2003
    Wichita KS
    Hello uug1,
    In order to do this, you must use the taylor series..
    Go to the bottom of this link... IT gives a LOT of info.
    http://www.picbasic.co.uk/forum/show...ghlight=Taylor
    Dwayne
    Ability to Fly:
    Hurling yourself towards the ground, and missing.
    Engineers that Contribute to flying:
    Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute
    Pilots that are Flying:
    Those who know their limitations, and respect the green side of the grass...
    bot402's Avatar
    bot402 Guest
    Alternatively, look at the PROTON+ compiler.
    This does true floating point calculations including trigonometry.
    uuq1's Avatar
    uuq1 Guest
    Default InvCos
    I tried with Taylor series but no good.
    For angles less than 45 degrees, the code seem to work ok, but for larger angles the deviation is high.
    I have decided to use interpolation with select.
    Appreciate the help I got from this place.
    USA - Arizona
    You may also want to look here:
    http://www.emesys.com/BS2math3.htm
    uuq1's Avatar
    uuq1 Guest
    Thanks languer for the article. I think it will help.
  1. Cordic trig assembly code for PIC18f
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th September 2015, 06:36
  2. ARCOS (inverse cosine)
    By mjphillips1981 in forum mel PIC BASIC Pro
    Last Post: - 8th October 2009, 17:53
  3. Serial Communication Inverse mode
    By titanvision in forum Serial
    Last Post: - 27th October 2008, 03:53
  4. Sin
    By AndyP in forum mel PIC BASIC Pro
    Last Post: - 16th December 2007, 22:06
  5. How to do ARCTAN (inverse tan) in PICBasic Pro
    By guanerrr in forum mel PIC BASIC Pro
    Last Post: - 13th April 2006, 18:27
