PIC18F1320 Config Help
Results 1 to 5 of 5
    Jun 2008
    Varese , Italy
    Default PIC18F1320 Config Help
    Good day to all of you in the forum,
    I have to replace the pic16f628 with a PIC18F1320.
    I want to retain the same PBP basic program. I am not able to make it working: probably there is a fault in the configuration of the program.
    It will operate at 20 MHz with an external XTAL. No analog interface is required.
    I am asking if someone could help me in setting up the configuration piece of program using PICbasic Pro.
    Thanks in advance for any help.
    Best regards,
    Ambrogio
    IW2FVO
    Default Re: PIC18F1320 Config Help
    Have you tried the Advanced Search feature using 18F1320 CONFIG?
    http://www.picbasic.co.uk/forum/show...752#post114752
    Jun 2008
    Varese , Italy
    Thanks ,
    but it refers to a different PIC type.
    I would like to define the configuration for using a PIC18F1320 , 20 Mhz Xtal and the possibility to manage very few discretes and an LCD.
    I have the PBP program running on a PIC16F628 but not able to transfer it on PIC18F1320.
    Any help ?
    Thanks for the assistance.
    Ambrogio
    Hmmm, was sure I had the right PIC.
    What about this?
    http://www.picbasic.co.uk/forum/show...124#post112124
    Jun 2008
    Varese , Italy
    Thanks a lot Robert: it is working well now !
    Ambrogio
  1. config bits
    By brianD in forum mel PIC BASIC Pro
    Last Post: - 9th February 2010, 13:45
  2. port config.
    By tamertokgoz in forum mel PIC BASIC Pro
    Last Post: - 25th July 2008, 12:25
  3. config help please?
    By karenhornby in forum mel PIC BASIC Pro
    Last Post: - 17th June 2008, 23:49
  4. Need help with config
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 25th February 2008, 06:57
  5. Compiling error with PIC18F1320
    By mazlan in forum mel PIC BASIC Pro
    Last Post: - 26th November 2004, 01:01
