16F1827 ADC Direct manipulation not working
Results 1 to 6 of 6
    Default 16F1827 ADC Direct manipulation not working
    While using ADCin works fine, using direct register manipulation does not. Can anyone tell me why?
    PORTA = 0
    PORTB = 0
    TRISA = %00000011
    TRISB = %00001011
    ADCON0 = %00000000      'select channel AN0, ADC off
    ADCON1 = %01110000      'Internal Frc, Left justified, Ext. ref.
    ANSELA = %00000001           ' AN0 on Port A analog
    ANSELB = %00000000           ' Digital inputs
    start:
    adcon0.1=1
    while adcon0.1:wend
    hserout ["Adresh: ",#adresh,13,10]
    goto start
    The above does not work. The next one works just fine though...
    start:
    adcin 0,i
    hserout ["Adc: ",#i,13,10]
    goto start
    Default Re: 16F1827 ADC Direct manipulation not working
    Hi Ioannis,
    I think your while loop needs to be
    ADCON0.1=1
    WHILE ADCON0.1=1
    wend
    while adcon0.1 and while adcon0.1=1 are functionally identical.
    However, the A/D module must be turned on before it will perform a conversion.
    ADCON0.0 = 1
    PBP does that automatically.
    Hi Darrel.
    Thanks for looking at this. Well, I do have this line, just did not copy it when posting the thread.
    The strange thing is that, if I use both ways, ADCin and register manipulation, it works!
    Like this works fine:
    high adcon0.0'=1
    start:
    adcon0.1=1
    while adcon0.1:wend
    adcin 0,i
    hserout ["i: ",#i,13,10]
    goto start
    But not when modified to this:
    high adcon0.0'=1
    start:
    adcon0.1=1
    while adcon0.1:wend
    'adcin 0,i
    'hserout ["i: ",#i,13,10]
    goto start
    Cannot figure out why...
    OK, I found something but cannot tell if it is a bug or something I don't understand.
    Setting up the ADCON0 as
    ADCON0.0=1
    PAUSEUS 100
    ADCON0.1=1
    does not work.
    But ADCON0=3 does work just fine!
    Ooops,no bug!
    I got it.
    Wrong label...
    Sorry for the alarm.
    All are OK.
  1. ADC not working - I'm a new member
    By johnbond in forum mel PIC BASIC Pro
    Last Post: - 20th June 2011, 19:13
  2. 16F1827 - Timer1 and ADC Conflict?
    By Ioannis in forum mel PIC BASIC Pro
    Last Post: - 18th March 2011, 17:22
  3. Manipulation of string array
    By Benny007 in forum mel PIC BASIC Pro
    Last Post: - 23rd April 2008, 20:50
  4. String Manipulation
    By Darrenmac in forum mel PIC BASIC Pro
    Last Post: - 8th April 2008, 14:39
  5. Port Manipulation
    By rwskinner in forum mel PIC BASIC Pro
    Last Post: - 5th March 2008, 04:30
