PIC12F683, POT & RCTIME not supported?
Results 1 to 8 of 8
    Default PIC12F683, POT & RCTIME not supported?
    Hello.
    I want to read value of potentiometer into that MCU. here's sample code.
    RC var GPIO.0
    test var gpio.5
    RESULT VAR WORD
    :mainloop
    HIGH RC
    PAUSE 1
    pot RC,100,result
    pulsout test,result
    goto mainloop
    the all hook-up is done according to manual. But it does not works, I've hooked oscilloscope to test pin - see no pulses here when I adjust pot.
    Default Re: PIC12F683, POT & RCTIME not supported?
    I've looked with scope at POT pin too, there are fixed pulses, about 84hz frequency, and they don't change when I rotate the pot.
    To be known ...
    POT only works "correctly" @ 4 Mhz and using the components shown in the Holy manual.
    Now, having a Chip with onboard ADC ... it's a shame and a nonsense using such an awful command ( not linear, need special value components ... )
    RCTime works perfectly ... but, here again, response is not linear and the range it must be used calculated with care to get enough granularity ...
    I tested RCTIME with my components on basic stamp 2p module, and it works perfectly, with nice linearity. Tried to move parts and code into PBP - does not works.
    with nice linearity
    sure !!!
    LOL ... I didn't know capacitor charge or discharge was showing something linear
    Have a nice evening.
    Think what happens when you connect two unlinearities
    it's you who has the problem to generate your pulses ... not me ...
    Jun 2013
    I had a problem with RCTIME. Suggest you add a pause after rctime. It gives processor time to finish rctime before moving onto the next line of code.
  1. PULSIN & RCTIME resolution calculation
    Last Post: - 5th January 2010, 14:34
  2. POT and RCTIME instructions
    Last Post: - 14th November 2007, 15:47
  3. can someone help me with RCTIME
    By gandora in forum mel PIC BASIC Pro
    Last Post: - 17th May 2007, 00:30
  4. Using ADCIN or POT/RCTIME?
    By TonyA in forum mel PIC BASIC Pro
    Last Post: - 16th April 2006, 18:37
  5. I'm getting strange Results using POT or RCTIME on PortB (or GPIO Port)
    Last Post: - 15th July 2004, 20:01
