18f2431 QEI Help
Results 1 to 5 of 5
    krism13's Avatar
    krism13 Guest
    Default 18f2431 QEI Help
    Has anyone figured out the Quadrature Encoder Interface on the 18F2431 (or similar 18FXX31 PIC)? I can successfully work with the position data, but I am unable to get the velocity data to work properly. Does anyone know the correct entries to the configuration registers, or does anyone have any sample code? Thanks.
    krism13's Avatar
    krism13 Guest
    Default Figured it Out
    I have solved the issue regarding velocity feedback.
    May 2007
    Quote Originally Posted by krism13 View Post
    hi krsim, could you share how did you solve qei velocity issue?
    i also successfully work with the position data, but i've tried.
    i set QEICON.7 = 0 ' velocity mode enabled
    VELM VAR QEICON.7
    VELM = 0
    is there a velocity register, o i must calculate it manually?
    "Beethoven had his critics too, see if you can name 3 of them"
    Quote Originally Posted by RodSTAR View Post
    If you'll notice, that user hasn't been on for 2 1/2 years now and the username isn't registered anymore.
    Jun 2013
    Default Re: 18f2431 QEI Help
    Hi every one !!!!
    I am wrking on pic18F4431 and can't figure out on how to measure velocity or position. If you don't mind it would be really helpful if you could share the code with me.
    Thank you !!!!!!!!
  1. Quadrature encoder and loop count
    By phoenix_1 in forum Code Examples
    Last Post: - 8th October 2009, 23:02
  2. pwm 18f2431
    By robertpeach in forum mel PIC BASIC Pro
    Last Post: - 21st August 2009, 09:55
  3. SSPCON and 18F2431 Problem
    By ralfmayr in forum mel PIC BASIC Pro
    Last Post: - 11th November 2008, 17:19
  4. using all pins of pwm in pic 18f2431
    By jorgequesada in forum mel PIC BASIC Pro
    Last Post: - 4th May 2007, 22:43
  5. 18F2431 won't program or erase.
    By HenrikOlsson in forum mel PIC BASIC Pro
    Last Post: - 28th September 2006, 08:55
