pic16c54
Results 1 to 10 of 10
Thread: pic16c54
    Mar 2006
    Hyderabad (India)
    Default pic16c54
    hello
    the clk8.asm files is readily downloadable from microchip as part of AN615b and the same has been used by me ( of course i have locally compiled) and the same is working FINE.
    Here one thing is to be noted . the common cathode wires coming from RA 0-RA-1 ,RA-2 and RA-3 may require rescheduling. Otherwise the display gets jumbled.
    However PIC16C54a is an OTP device. Perhaps it is better if you can try a newer version PIC16F54 instead as this s flash programmable, by managing a suitable programmer
    Thus, Necati may very well use it. ALL the best
    I only wonder whether some has tried to modify this software to work on PIC16f84 and i request for help in this direction.
    sarma
    Wink
    Hi, Sarma
    Seems migrating from C54' to F84' is not so easy ...
    first, have a look to Appendix C from 16F84 Datasheet : main explanations are here.
    BUT ... if the programmer has used its own tricks ... that can be a bit harder !!!
    I experience it on another clock program ( DCF Berliner Clock ) ... "basic" clock works well, but I still can't get the LED multiplexing work properly ...
    it relates to Writing to the PC ... but where ???
    good luck
    Mar 2006
    Hyderabad (India)
    Default application note an615 (low power clock with 16c54)
    hi, necati
    hope you might have adopted the clk8.asm by converting the same to hex code
    if so desired perhaps i could send clk8.hex copy
    Sarma
    Mar 2006
    Hyderabad (India)
    Quote Originally Posted by mvs_sarma
    hello
    sarma
    Hi all and Necati in particular,
    I am now able to modified the an615 (clk8.asm to be able to work on 16F84A and i have two versions-- 1. with display OFF after 8 sec and 2. One to contiuously display-
    i could send the .HEX file if someone wants.
    Enquiries are welcome.
    Sarma
  1. pic16c54a
    By mavi in forum Schematics
    Last Post: - 9th March 2006, 18:10
