Weird problem with Debugin
Results 1 to 10 of 10
    Jan 2010
    Default Weird problem with Debugin
    This is my code and my problem explained. I cannot store a byte into a variable:
    '-----------------------CONFIGURATION----------------------
    DEFINE OSC 20
    Include "modedefs.bas"
        ifdef PM_USED
            device  pic16F877A, xt_osc, wdt_on, lvp_off, protect_off
    	__Config _HS_OSC & _WRT_256 &_WDT_OFF &_PWRTE_ON &_BODEN_ON & _LVP_OFF  & _CP_ALL &_CPD_ON
    @ ERRORLEVEL -306
    DEFINE DEBUG_REG PORTC
    DEFINE DEBUG_BIT 6
    DEFINE DEBUG_BAUD 9600
    DEFINE DEBUG_MODE 1
    DEFINE DEBUGIN_REG PORTC
    DEFINE DEBUGIN_BIT 7
    DEFINE DEBUGIN_MODE 0
    '--------------------REGISTERS-------------------------------
    PAUSE 100
    ADCON1=7
    CMCON=7
    OPTION_REG=%10000111
    TRISA=0 : PORTA=0
    TRISB=0 : PORTB=0
    TRISC=%10000000 : PORTC=0
    TRISD=0 : PORTD=0
    TRISE=0 : PORTE=0
    CCP1CON=0
    LED Var PortD.1
    B0 Var byte
    '--------------------The below does not work i.e. LED does not toggle--------------
    b0=0
    	Debugin [b0] ' Tried STR B0\1 as well but no luck
    	if b0="1" then GoSub TOG
    	Pause 200
    Goto Main
    '--------------------Change the Above with the following : The below works i.e. LED does toggle--------------
    	Debugin [WAIT ("1")] ' I tried many inputs but only when I send 1 it works. So it does realises 1 somehow
    	GoSub TOG
    	Pause 200
    Goto Main
    Tog:
    	Toggle PortD.1
    What am I missing? please help.
    Default Re: Weird problem with Debugin
    You know that the sender is sending '1' but have you verified that it is sending ONLY a '1' - ie a single byte?
    If, for example, the sender is sending 'xyz1abc' then the first example won't work because b0 will then contain 'x'. The second example will work since it automatically discards the 'xyz' part of the string.
    Jan 2010
    Is there any tool available which can be installed on computer and can get all the bytes and may be auto determine the baud rate to check this? (Apart from Microcode Studio with serial communicator as it is not working)
    Google for serial port sniffer and you should find plenty of programs. Another REALLY handy tool is logic analyzer with protocol decoding. I've got a Saleae LOGIC and it's just a great little tool to use for things like this as it lets you see what is ACTUALLY going down the wires.
    Since you have another thread on a similar subject open I suspect the two to be about the same problem. The serial communicator in MCS works just fine, but it can only display ASCII data. If your device isn't sending pure ASCII data then it won't display it properly which MIGHT be why you see the byte count going up but no data being displayed. Then, of course, if the polarity is wrong - as Robert mentioned in the other thread, it won't work either.
    In the code you posted you have the mode (the polarity) set differently for DEBUG vs DEBUGIN.
    Dec 2004
    USA
    You beat me to it Henrik.
    www.saleae.com
    Jan 2010
    Thanks. That makes some sense now. I tried experimenting more with it and realized that ASCII is not the format (blame the Chinese).
    Has anyone used this: http://www.serialmon.com as a serial port sniffer?
    Also Debug and Debugin both work as mode 0. At that time I was only checking Debugin so left debug as mode 1 (please ignore it in the code above)
  1. Weird Random problem
    By Del Tapparo in forum mel PIC BASIC Pro
    Last Post: - 15th August 2012, 23:06
  2. Weird Problem
    By isaac in forum General
    Last Post: - 22nd September 2008, 20:30
  3. DebugIn problem
    By Mutiaz in forum mel PIC BASIC Pro
    Last Post: - 2nd January 2006, 16:51
  4. Weird Oscillator Problem
    By eoasap in forum mel PIC BASIC Pro
    Last Post: - 17th December 2005, 15:21
  5. Debugin problem
    By moby in forum mel PIC BASIC Pro
    Last Post: - 11th September 2004, 16:12
