PIC read program
Results 1 to 4 of 4
    TEOWK's Avatar
    TEOWK Guest
    Default Read Program
    Thank you. I use a Microchip PICSTART Plus programmer and try to upload the code from PIC 16F877. There is no response after the READ process. While reading, I saw the running number of the read memory address. I am not if this device is code protected. There is not message coming out from the output window.
    Please help.
    In this case it looks like the PIC is code protected (most sensible commercial devices would be protected) and as such you would be out of luck.
    Also I notice you say you are a new beginner. Even if you did get access to the microcode, it would of limited use to you. You would only be able to reverse compile back into Assembler, and then you will have to understand what the program is attempting to achieve and be familiar with the hardware circuit to get any idea what is going on (since you will have none of the original program comments or notations as they are not saved in the PIC). This is a long, hard and very tedious process for an expert, never mind a beginner. Most probably it would be a lot easier to write new code from the beginning.
  1. Replies: 16
    Last Post: - 3rd November 2008, 20:58
  2. Automatic VB6 to pic serial connection
    By arniepj in forum Code Examples
    Last Post: - 10th January 2008, 08:57
  3. read with a PIC one file stored in a USB Pen
    By Pedro Santos in forum mel PIC BASIC Pro
    Last Post: - 19th August 2006, 20:07
  4. Matching PIC memory and program size?
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 9th August 2006, 09:02
