Rac_int
Results 1 to 3 of 3
Thread: Rac_int
    Jun 2006
    Default Rac_int
    The interrupt works perfect but if I hold the button down for a little while then let up the interrupt will hang, but if you just wait it will come out of it and start working again.Using a 16F688.
    define OSC 4
    include "ReEnterPBP.bas"
    @ ERRORLEVEL -306   ; turn off crossing page boundary message
    '-----------------------REGISTERS----------------------------------------
    TRISA=%111000                                                   ' RA3,RA4,RA5 inputs
    ANSEL=%00000000                                                 ' All digital
    TRISC=%00000011                                                 ' RC0,RC1, input
    CMCON0=%111                                                     ' Shut off comparators
    ;OPTION_REG.7=0
    WPUA=%111000                                                    ' Weak Pull Ups Enabled
    INTCON.7=1         'Enable Global Interrupts
    IOCA=%110000       'Enable IOC
    'Variables---------------------------------------------------------------------
    Forward var PORTC.0
    ForwardBut var PORTA.4
    Reversed var PORTC.1
    ReverseBut var PORTA.5
    Led var PORTC.2
            INT_Handler    RAC_INT,  _Motor,   PBP,  yes
        INT_ENABLE   RAC_INT    ; enable ioc
     high led
     pause 200
     low led
     pause 200
    Motor:
     if ForwardBut=0 then
     high forward
     do while ForwardBut=0
     loop
     low forward
     if ReverseBut=0 then
     high reversed
     do while ReverseBut=0
     loop
     low reversed
     @ INT_RETURN
    Jun 2006
    Default Re: Rac_int
    I wasn't clear, if I push the button and release it all works fine. Just when I hold it for say 30 seconds it will freeze up as stated.
    Default Re: Rac_int
    I wouldn't pause and loop until the button is released within the interrupt.
    I'd set a flag and handle it back in main logic.
  1. RAC_INT and pic 16F684
    By aratti in forum mel PIC BASIC Pro
    Last Post: - 3rd February 2013, 15:15
  2. Problem with RAC_INT
    By Dick Ivers in forum mel PIC BASIC Pro
    Last Post: - 8th March 2010, 15:15
