Enabling Comparator / Disabling Comparator PIC 16f1829 Problem
Results 1 to 3 of 3
    Default Enabling Comparator / Disabling Comparator PIC 16f1829 Problem
    Here is a break down of what is going on.
    Using both comparators, one input is C12IN1 (portc.1) and the other is C12IN2 (portc.2).
    I am not having an issue with the comparators functions. They are fine but the issue I am having is that I need to read COUT and if it equals 0, I need to ouput on the comparator input pin. I know some of you may say "why?". Lets just say I am playing middle man with a signal.
    I thought this would be simple enough and wrote 2 sub-routines. One disables the comparator and sets the port up so I can output and the other re-enables the comparator for the next read. This does not seem to work at all. The program locks up and as far as I can tell, it happens after the comparator is disabled or when it is re-enabled.
    Below are my sub-routines for disabling and enabling the comparators and configuring the ports. The comparator enable routine is literally a copy and paste of the configuration at startup that I know works. Again, every part of the program is fine until I have to disable and re-enable comparators then it locks up.
    I use PICBasic PRO
    DISCOMP:
    'DISABLE COMPARATOR
    DACCON0 = %00000000
    DACCON1 = %00000000
    CM1CON0 = %00000000
    PIR2 = %00000000
    CM1CON1 = %00000000
    CM2CON0 = %00000000
    PIR2 = %00000000
    CM2CON1 = %00000000
    ''''''PORTC SETUP''''''''
    ANSELC = %00000000
    WPUC = %11111001
    INLVLC = %00000000
    LATC = %00000000
    TRISC = %11111111
    ENCOMP:
    ANSELC = %00000110
    WPUC = %11111001
    INLVLC = %00000000
    LATC = %00000000
    TRISC = %11111111
    'ENABLE COMPARATOR
    DACCON0 = %00000000
    DACCON1 = %00010000
    CM1CON0 = %10010110
    PIR2 = %00000000
    CM1CON1 = %00010001
    CM2CON0 = %10010110
    PIR2 = %00000000
    CM2CON1 = %00010010
    Default Re: Enabling Comparator / Disabling Comparator PIC 16f1829 Problem
    You need to change your TRISC =00000 during "DISCOMP:" for output?
    Quote Originally Posted by mark_s View Post
    While I am setting the tris bit for portc.1 and portc.2 to an input, after it runs that subroutine it flips it to an output therefore no reason to set the tris bit at the time I disable the comparator.
  1. Use a PIC ADC like a fast interrupt comparator?
    By pxidr84 in forum mel PIC BASIC Pro
    Last Post: - 19th August 2011, 06:33
  2. PIC18F13K22 comparator problem
    By harryweb in forum mel PIC BASIC Pro
    Last Post: - 16th June 2011, 10:42
  3. pic18f analog comparator problem
    By david.silaghi in forum mel PIC BASIC Pro
    Last Post: - 6th May 2009, 10:38
  4. PIC16F616 Comparator problem
    By JimA in forum General
    Last Post: - 15th October 2007, 15:56
  5. need help on comparator
    By bertus in forum General
    Last Post: - 21st October 2003, 11:25
