max frequency on pwm channel 16f88
Results 1 to 5 of 5
    Jun 2011
    Indian Harbour Nova Scotia
    Default max frequency on pwm channel 16f88
    What is the max frequency output on a 16F88 MCU on PB3 (ccp1), the PWM output? Tell me I can go to 38000Hz.
    In the PBP3.0 manual there's a table that shows max frequencies for given oscillator frequencies. For 8Mhz oscillator, this is 489 Hz. Is this true?
    I had 38000Hz output from a LabX1 using a 16F887 MCU. I THINK I had 38000 Hz: my hardware circuit was running (and it's supposed to work at 38000 Hz) but I DID NOT measure the frequency.
    I want to trigger an IR LED and detect the signal with a standard IR detector chip like a TSOP 18. If I can't do it with PWM, should I, can I, just toggle a IR detector at 38000Hz? (I know, detectors have a certain protocol to understand the signal, but there are some that simply detect a 38000 Hz IR signal without any fancy modulation.
    My 16F88 should be putting out 38000 Hz now...it isn't.
    May 2007
    Default Re: max frequency on pwm channel 16f88
    Quote Originally Posted by queenidog View Post
    Very simple, just check the data sheet Table 9-3.
    No, the table in the manual lists the lowest possible frequency obtainable using the HPWM command at the given oscillator frequency.
    Jun 2011
    Thank you all! I can't believe I've been misreading the PBP3.0 manual wrong all this time regarding the LOWEST usable frequency. It is NOT highest. And there in the spec sheet, in table 9-3 which I've not seen before (because I was just letting the HPWM command take of stuff), is a table of frequencies.
    I'm on a roll.
    Thanks again guys.
    May 2007
    BTW, the numbers in table 9-3 are not the highest PWM frequency that the PIC can attain. It can reach much higher frequencies than those stated - depending on the resolution you want.
  1. PWM to Frequency
    Last Post: - 15th October 2011, 02:59
  2. 3 channel PWM with customize duty cycle
    By photoelectric in forum mel PIC BASIC Pro
    Last Post: - 16th May 2011, 13:49
  3. Low frequency PWM
    By Charlie in forum General
    Last Post: - 16th February 2011, 14:31
  4. 16f88 internal osc 8mhz max serial baudrate ?
    Last Post: - 16th December 2008, 23:27
  5. frequency meter from 16f84a to 16f88
    Last Post: - 4th November 2006, 13:28
