Strange A/D conversion...
Results 1 to 5 of 5
    Christos_K's Avatar
    Christos_K Guest
    Default Strange A/D conversion...
    Hi all! Have been trying to do a 10bit A/D conversion using a PIC16f876 but something strange happens...I have a working circuit and send the result through RS232 to my pc...I use a potentiometer with the two ends connected at Vdd and GND and the other end is connected to PORTA.0...Look at some measurements i did..The first values are from my digital multimeter and the second values are the decimal value of the a/d conversion variable...
    5V --> 1023 (5v)
    4V --> 785 (3.8v)
    3V --> 552 (2.7v)
    2V --> 300 (1.47v)
    1v --> 65 (0.3v)
    0v --> 0 (0v)
    As you can see the A/D conversion can show the max and minimum values but it is lost in between..
    Here is my code(reference votlage is set to Vdd = 5V):
    DEFINE HSER_RCSTA 90h '
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_SPBRG 129
    DEFINE HSER_CLROERR 1
    DEFINE OSC 20
    DEFINE ADC_BITS 10
    DEFINE ADC_CLOCK 2 (tried 3 but didn;t work)
    DEFINE ADC_SAMPLEUS 50 (tried increasing but didn;t work)
    adcdata var WORD
    trisa = %11111111
    ADCON1 = %10000010
    ADCIN 0, ADCDATA
    hserout [dec ADCDATA ,13]
    What can be wrong?? I 've also tried a version where you manual set the conversion to start and checking the bit2 of adcon0 etc etc but same results...
    Also tried with 3.3V reference voltage at PortA but still no luck...
    could be some noise on the pot wiper. Have you place a capacitor between PIC input and gnd? What is the impedance of your POT. Should be less than 10K if my memory is good for that PIC.
    Also, make sure your supply line is neat.
    Post
    I suspect a wiring problem since your conversion is dead straight(see ADcurve.gif) with an offset of about 0,75v. That's close to a normal voltage drop over a diode or transistor.
    Christos_K's Avatar
    Christos_K Guest
    Problem solved! Indeed it was wirring problem! Another question now, What do the values for Define ADC_CLOCK repesent and how are they different?
    I know that you can have ADC_CLOCK 0,1,2 or 3...What does its number correspond to?
    The value selects the source of the ADC conversion clock. For a detailed answer to this, look at "Selecting the ADC Conversion Clock" sub-section, in the ADC section of your chosen PICs Datasheet. Some newer PICs have a wider selection range than provided by the DEFINE, in those cases it's best to select by presetting the Registers yourself. If you are unsure what source to use, the RC option (which is an internal ADC option and nothing whatsoever to do with the PICs main Oscillator) is always a safe bet.
  1. A/D conversion with PIC18F67J50
    By ScaleRobotics in forum mel PIC BASIC Pro
    Last Post: - 8th May 2009, 01:48
  2. Fast / low resolution A/D conversion
    By AndrewC in forum General
    Last Post: - 7th April 2009, 12:18
  3. A/D conversion problem in 18F2520, 2523, 2550 etc.
    By selimkara in forum mel PIC BASIC Pro
    Last Post: - 10th March 2008, 16:26
  4. A/D conversion problem on 18F4431
    By ttease in forum mel PIC BASIC Pro
    Last Post: - 10th April 2007, 23:03
  5. A/D converter fails?
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 13th February 2006, 18:57
