Assembler Error Msg?
Results 1 to 19 of 19
    Dec 2010
    Melbourne Australia
    Default Assembler Error Msg?
    I've recently upgraded my PBP from 2.6 to 3 but I often receive error messages in the compile process that I didn't previously receive with the same code like:
    [ASM ERROR] My_Program.ASM (48) : CONFIG Directive Error: (setting "DEBUG" not found for the processor 18F13K50)
    Is this because I haven't updated something I should have during the process?
    Troy
    Default Re: Assembler Error Msg?
    The CONFIG command is new. Search the PBP3 subforum for details and your manual.
    Dec 2010
    Melbourne Australia
    Robert,
    Are you referring to the #CONFIG marker to specify an assembly language block as mentioned in the migration notes? I've read through the migration notes reasonably thoroughly and I can't recall it mentioning "config" being used for anything else? To me, the error doesn't appear to be pointing any fingers at "Config" directly, but more to an omission in one of the support files?
    Troy
    I don't have 3.0 yet, I'm only going by the message you posted. Most of the migration problems come from changing the CONFIGs.
    Your best bet is to post your code. Help those with the answers to help you.
    Dec 2010
    Melbourne Australia
    Demon,
    Here's an example:
    Define  OSC 24
    ANSEL = 0    'All ports digital
    ANSELH = 0   'All ports digital
    TRISC.3 = 0
    loop1:
          DTMFout PortC.3,[0,1,2,3,4,5,6,7,8,9,10,11,12,13,14,15]
       Goto loop1
    As you can see, very simple example with no calls to assembler or anything complex. The simple sample programs provided with PBP3 also produces the same error too.
    Troy
    Dec 2010
    Melbourne Australia
    BTW: This is the screen grab I get when I click on the Error Message:
    Troy
    Sep 2010
    Las Vegas, NV
    Define must be in CAPS for it to work. i.e. #DEFINE OSC 24
    Dec 2010
    Melbourne Australia
    Quote Originally Posted by AvionicsMaster1 View Post
    The editor that came with PBP3 -- Microcode Studio MCSX (the apparent successor to MCS) -- appears to automatically adjust/correct the "DEFINE" to lowercase. I'm assuming this is intentional??? Nevertheless, it's not the cause of the compiling error as the error still appears even if I remove that entire line from the code.
    Troy
    Are you sure you have selected the correct chip on the MCSX drop down menu?
    I suppose you have a new version of MPLAB and a new directory you installed PBP. Not over the old one?
    Dec 2010
    I'm not a 3.0 user either, but the 18F13K50 does not have onboard debug support, so the new compiler may give a warning when invoking DEBUG, even if the DEFINE is to turn it off. If you comment out that line, does the error go away?
    Dec 2010
    Melbourne Australia
    Ioannis,
    "Yes" to all those questions except MPLAB. I can't recall installing a new version of MPLAB onto my machine unless it was part of the PBP3 installation process?
    Troy
    Dec 2010
    Melbourne Australia
    Quote Originally Posted by Charlie View Post
    I have considered this, but since it's one of the "system" files(?) ie. not my input, I thought I'd hold off before I received some feedback here 1st. I'll found out how to install a new version of MPLAB onto my machine 1st, then if that does nothing, I'll comment that line out.
    Troy
    Dec 2010
    If you choose to upgrade MPLAB, don't delete your old version of MPLAB, but rather try a fresh install in a different directory. Many people that try MPLAB X go back in short order. YMMV.
    As to my comment - I'm simply suggesting that perhaps Version 3 is less tolerant than 2.6 was of trying to define something that does not exist - certainly that's what the error says to me. Those defines are not sacred. You can add and remove them as you see fit. Don't worry about even editing "system files" - feel free to experiment. Just keep a pristine copy of the original files so you can go back if you mess up, and then experiment to your heart's content. I don't think it is possible to execute a "halt and catch fire" instruction on modern devices. .
    Dec 2010
    Melbourne Australia
    Charlie,
    I commented out that line and it appears to compile without issue - thanks for the great advice.
    The really weird thing is this error would appear for virtually any simple program I tried compiling with that processor selected, but the largest & most complex program I've written (~1000 lines) compiled perfectly - go figure!
    Troy
    It is important to have the latest MPLAB. Download from www.microchip.com/ide the latest as now 8.91 and I feel you will be OK.
    Quote Originally Posted by rocket_troy View Post
    Troy
    Troy,
    Microcode Studio MCSX defaults to lower case for the reserve words, but you can change that. To do so, click on the 'View' menu, then select 'Editor Options'. Now select the 'Highlighter' tab and at the bottom of that tab is the 'Reserve Word Formatting' area. Just select the 'Uppercase all' option and your "DEFINE", as well as all reserve words, will be in caps.
    Dec 2010
    Melbourne Australia
    Quote Originally Posted by Brassfly View Post
    Troy,
    Thanks for the tip Brassfly.
    Cheers,
    Troy
    Dec 2010
    Melbourne Australia
    Ioannis,
    Ok. I've downloaded and (I assume) installed the latest version of MPLAB. The only thing I've notice differently (initially) is that the Error has come back(!); yup, the same error that I commented out previously has returned??? Are there any settings I need to adjust in MCSX to acknowledge this new MPLAB version on my machine?
    Troy.
    As Microchip says, you have to un-install previous version before installing the latest.
    It is in fact strange this problem...
  1. Help with Assembler Error
    By isaac in forum mel PIC BASIC Pro
    Last Post: - 21st March 2012, 19:53
  2. How to resolve assembler error 306?
    Last Post: - 29th September 2011, 07:59
  3. Replies: 2
    Last Post: - 13th March 2011, 19:13
  4. MPLAB 8.33-PBP 2.6 Crash error msg
    By reddog24 in forum mel PIC BASIC Pro
    Last Post: - 23rd October 2009, 02:30
  5. Compiler/Assembler Error
    By LT_Pic in forum General
    Last Post: - 21st July 2005, 09:47
