18F46K22 HPWM blips and errors
Results 1 to 5 of 5
    Default 18F46K22 HPWM blips and errors
    hi guys...
    I've been trying to figure this out all weekend and I'm stumped...
    I have a project that I'm doing for my sisters birthday. It uses all 5 hardware PWM on the 18F46K22.
    However, i noticed the channels were 'bliping' and channels that were at 0% suddenly jumping to an on state and then back to off...
    So, i set up some test hardware with two loop back fets to act as voltage regulators and LEDs to find the cause and it was still doing...
    Still, no matter what i hang off the PWM's they blip randomly...
    Even if i set them to a specific value and do not update the pwms', they still blip...
    I have never seen this before and i have used the PWMs many time and not seen this. I tried all my other 46K22's and they do the same with the same firmware on.
    So, I'll include the code from my last test setup... if someone would be so kind as to look over it to see if i have done something stupid...
    @ __config _CONFIG1H, _FOSC_INTIO67_1H & _PLLCFG_ON_1H & _PRICLKEN_ON_1H & _FCMEN_OFF_1H & _IESO_OFF_1H
    @ __config _CONFIG2L, _PWRTEN_ON_2L & _BOREN_SBORDIS_2L & _BORV_220_2L
    @ __config _CONFIG2H, _WDTEN_OFF_2H & _WDTPS_32768_2H & _CCP2MX_PORTC1_3H & _PBADEN_OFF_3H
    @ __config _CONFIG3H, _CCP3MX_PORTE0_3H & _HFOFST_OFF_3H & _T3CMX_PORTC0_3H & _P2BMX_PORTC0_3H & _MCLRE_INTMCLR_3H
    @ __config _CONFIG4L, _STVREN_ON_4L & _LVP_OFF_4L & _XINST_OFF_4L & _DEBUG_OFF_4L
    @ __config _CONFIG5L, _CP0_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L & _CP1_OFF_5L & _CP2_OFF_5L & _CP3_OFF_5L
    @ __config _CONFIG5H, _CPB_OFF_5H & _CPD_OFF_5H
    @ __config _CONFIG6L, _WRT0_OFF_6L
    @ __config _CONFIG6H, _WRTC_OFF_6H & _WRTB_OFF_6H & _WRTD_OFF_6H
    @ __config _CONFIG7L, _EBTR0_OFF_7L & _EBTR1_OFF_7L & _EBTR2_OFF_7L & _EBTR3_OFF_7L
    @ __config _CONFIG7H, _EBTRB_OFF_7H
    Define  OSC				64						' Set clock speed
    OSCCON.7 = 0
    OSCCON.6 = 1
    OSCCON.5 = 1
    OSCCON.4 = 1
    OSCCON.1 = 0
    OSCCON.0 = 0
    OSCTUNE.6 = 1                               ; PLL
    ;INCLUDE "18F46K22 unlock.pbp"
    ANSELA = %00000011
    ANSELB = %00000000
    ANSELC = %00000000
    ANSELD = %00000000
    ANSELE = %00000000
    TRISB = 0
    PORTB = 0
    TRISC = %00000000
    PORTC = 0
    TRISD = %00000000
    PORTD = 255
    TRISE = 0
    PORTE = 255
    TRISA = %00000011
    INCLUDE "DT_INTS-18.bas"        ; Base Interrupt System
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    INT_LIST  macro    ; IntSource,        Label,       Type, ResetFlag?
            INT_Handler   AD_INT,    _ADC_HANDLER,         PBP,  yes
    ;        INT_Handler   HLVD_INT, _HLVD,              PBP,    yes
    VREFCON0 = %10100000
    ADC0 VAR WORD
    REDLEDPWM VAR BYTE
    GREENLEDPWM VAR BYTE
    BLUELEDPWM VAR BYTE
    ADCCHAN VAR BIT
    LOWVOLTAGE VAR BIT
    ALOOP VAR WORD
    BLOOP VAR WORD
    CLOOP VAR WORD
    DLOOP VAR WORD
    TEMPBYTE VAR BYTE
    PAUSETIME VAR WORD
    CLEAR
    VREG1TGT CON 535
    VREG2TGT CON 815
    ADCCHAN = 0
    ADCON2 = %10111111
    ADCON1 = %00001000
    ADCON0 = %00000011
    ;HLVDCON = %00110111
    REDVREGPWM VAR BYTE
    GBWVREGPWM VAR BYTE
    @ INT_ENABLE AD_INT
    ;@ INT_ENABLE HLVD_INT
    REDVREGPWM = 255
    GBWVREGPWM = 255
    REDLEDPWM = 0
    GREENLEDPWM = 0
    BLUELEDPWM = 0
    GOSUB UPDATELEDPWM
    GOSUB UPDATEVREGPWM
    PAUSE 1000
    MAIN:
    ;We do something here to make the LED's produce pretty colors, ramp them up, down, flash them... and then "GOSUB UPDATELEDPWM" to update the PWM's
    ;REDLEDPWM = 0
    ;GREENLEDPWM = 0
    ;BLUELEDPWM = 0
    ;PAUSE 1000
    ;GOSUB UPDATELEDPWM
    ;GOTO MAIN
    ;REDLEDPWM = 128
    ;GREENLEDPWM = 255
    ;BLUELEDPWM = 128
    ;GOSUB UPDATELEDPWM
    ;Pause 1000
    ;REDLEDPWM = 128
    ;GREENLEDPWM = 128
    ;BLUELEDPWM = 255
    ;GOSUB UPDATELEDPWM
    ;Pause 1000
    ;REDLEDPWM = 255
    ;GREENLEDPWM = 128
    ;BLUELEDPWM = 128
    ;GOSUB UPDATELEDPWM
    ;Pause 1000
    GOTO MAIN
    ADC_HANDLER:
    ADC0.LOWBYTE = ADRESL
    ADC0.HIGHBYTE = ADRESH
    IF ADCCHAN = 0 then
        IF ADC0 < VREG1TGT then
            IF REDVREGPWM > 0 then REDVREGPWM=REDVREGPWM - 1
            IF REDVREGPWM < 255 then REDVREGPWM=REDVREGPWM + 1
        GOSUB UPDATEVREGPWM
        ADCCHAN = 1
        ADCON0 = %00000111
        IF ADC0 < VREG2TGT then
            IF GBWVREGpwm > 0 then GBWVREGpwm = GBWVREGpwm - 1
            IF GBWVREGpwm < 255 then GBWVREGpwm = GBWVREGpwm + 1
        GOSUB UPDATEVREGPWM
        ADCCHAN = 0
        ADCON0 = %0000011
    @ INT_RETURN
    UPDATEVREGPWM:
    HPWM 1,REDVREGPWM,3000
    HPWM 2,GBWVREGpwm,3000
    UPDATELEDPWM:
    TEMPBYTE = 255 - REDLEDPWM
    HPWM 3,TEMPBYTE,3000
    TEMPBYTE = 255 - GREENLEDPWM
    HPWM 4,TEMPBYTE,3000
    TEMPBYTE = 255 - BLUELEDPWM
    HPWM 5,TEMPBYTE,3000
    Be aware, the PWM outputs are in this case inverted due to direct drive of P channel fets. Tried with and without fets, transistors etc etc...
    Also, actual PWM frequency is 12.9KHz due to the 4X PLL bug still present in PBP 2.60C
    All help greatly appreciated...
    Default Re: 18F46K22 HPWM blips and errors
    I see something I don't like. You are making a call to a subroutine that is outside of the interrupt routine you are in. BAD coding practice...
    EN82fn
    Hi Dave,
    Would you care to elaborate a bit on WHY exactly that is such BAD practice (as long as you RETURN of course)?
    Yes, it does put another return adress on the stack but really, that's usually not a problem - certainly not with 18F parts where you can nest 27 levels deep.
    My guess is that the "blips" are comming from the frequent updates of the dutycycle using the HPWM command. It's my understandning that it (the HPWM command) reconfigures the CCP module completely every time it executes even though it's only the dutycycle that changes.
    Another thoguht: I don't know about the "PLL-bug" mentioned but perhaps the HPWM command calculates the dutycycle value based on the wrong frequency so the registers overflows or something?
    Bottom line is, try setting the CCP modules up manually and see if that helps, there should be plenty of examples around the forum.
    I always thought it was best to keep the coding within an interrupt to a minimum. I set flags and then check for them in my main logic.
    If code absolutely has to execute within the interrupt, I'd place it in-line. I would think calling an other subroutine chews cycles needlessly.
    Henrik,
    I agree with you that it must be the HPWM command that is causing the blips since the 46K22 has a buffered PWM.
    However, as you can see from the source code, i do most things by setting the register directly like the ADC scanning. However, i have not yet been able to get the PWMs to work by setting them manually.
    The PLL bug is because certain elements of PBP do not account for the 4 times increase of the clock speed due to enabling of the on-board PLL. It's those elements that ignore "Define OSC" and try to determine clock speed on their own.
    Demon and Dave,
    I agree the code is not optimal, it's the resultant mess of trying to debug the problem and sticking stuff in subroutines so that i can call it anywhere and not have to worry about it coming back correctly.
    I'll go take a look for manual setting of the PWM and see if that sorts it...
    Thanks guys.
  1. 18F46K22 being dyslexic
    By comwarrior in forum mel PIC BASIC Pro
    Last Post: - 7th August 2012, 19:00
  2. SDFS on 18F46K22
    Last Post: - 14th July 2012, 16:27
  3. Possible PicBasic Pro ADC bug with 18F46k22
    By JimAvanti in forum mel PIC BASIC Pro
    Last Post: - 23rd February 2012, 20:20
  4. Replies: 3
    Last Post: - 23rd October 2011, 12:53
  5. Replies: 2
    Last Post: - 10th July 2006, 01:05
