Set configuration bits
Results 1 to 6 of 6
    Default Set configuration bits
    how can I set this things with microcode studio on PIC16f819?
    @ DEVICE INTRC_OSC
    @ DEVICE WDT_OFF
    @ DEVICE PWRT_OFF
    @ DEVICE MCLR_OFF
    @ DEVICE BOD_OFF
    @ DEVICE LVP_OFF
    @ DEVICE CPD_OFF
    @ DEVICE CCPMX_ON
    I can't find the section for configuration bits on the program
    Default Re: Set configuration bits
    Have you looked at the FAQ forum?
    Or used the search feature?
    And there's also several similar threads listed at the bottom.
    Yes, of course and in the previous post you can look at my needed configuration.
    Unfortunately the microcode studio sais that it is incorrect
    As you can see there
    Feb 2010
    USA, New England
    What version of PBP are you using? And, which assembler is MCS using?
    In PBP3, the config settings would be something like:
      __config _INTRC_IO & _WDT_OFF & _PWRTE_OFF & _MCLR_OFF & _BODEN_OFF & _LVP_OFF & _CPD_OFF & _CCP1_RB3
    Best Regards,
    Paul
    Removed wrong answer.
  1. configuration bits
    By Izone1173 in forum mel PIC BASIC
    Last Post: - 18th June 2009, 04:17
  2. Set Configuration from code?
    By kevj in forum mel PIC BASIC Pro
    Last Post: - 26th September 2008, 04:52
  3. Configuration bits
    By Perrin` in forum mel PIC BASIC Pro
    Last Post: - 3rd July 2008, 14:40
  4. Configuration bits
    By DJEE in forum mel PIC BASIC Pro
    Last Post: - 14th June 2007, 19:20
  5. Configuration bits
    By Armando Herjim in forum General
    Last Post: - 5th December 2006, 16:51
