Another RS232 question...
Results 1 to 5 of 5
Threaded View
    Christos_K's Avatar
    Christos_K Guest
    Default Another RS232 question...
    Hi all! Have being trying to send a message from a PIC16F786 to my PC..Have been using the following schematic that was found from the book of C. Hellebuyck "Programming PIC Microcontrollers with PicBasic".
    The code that I have been using is the following:
    include "modedefs.bas"
    define osc 10
    trisb = %00000010
    portb.0 = 1
    serout portb.1, t2400, ["hello", 10, 13]
    In the seiral communications window of Microcode studio something is received but it is a set of characters rather than "hello"
    Is there something wrong with the code?
    What about the RS232 Cable connections??
    I am using the following configuration in my DB9 connector:
    Pins 1,6,4: short-circuit
    Pin 2: T2out
    Pin3: R2in
    Pin 5: Ground
    Pins 7,8: Short circuit
    Pin9: unused
    Would it be better to use the schematic as shown in Help/ICD etc.. of the Microde code studio help and HSEROUT instead? How should I have my DB9 pin configuration in this case?
  1. Universal remote and Rs232
    By Michael in forum mel PIC BASIC Pro
    Last Post: - 7th February 2010, 17:55
  2. UART vs software RS232
    Last Post: - 5th September 2008, 18:27
  3. RS232 into 2 PC ports
    By manxman in forum mel PIC BASIC Pro
    Last Post: - 30th August 2008, 13:33
  4. PIC18F4680 to PC via MAX232 (RS232 serial) no output
    By opticsteam1 in forum mel PIC BASIC Pro
    Last Post: - 14th April 2008, 20:39
  5. Please answer my first question
    By John_001 in forum Off Topic
    Last Post: - 15th September 2006, 06:49
